Danno's DD TJ Build - Page 76 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Danno's DD TJ Build
Forever Wave Flags at JeepHutRubicon Express lift kits w/shocks are on sale!ORS4x4: New Product!
Unread 02-24-2014, 09:49 AM   #1126
Sundowner
Originally Posted by Danno6102 View Post
Thanks Lu! I was inspired by Jay's.
It's going to look slick when it's all painted up.
If it's worth doing, then it's worth [I]over[/I]doing.
The build, the gear, and the mileage: [URL="http://www.jeepforum.com/forum/f22/wasteland-survival-guide-engineering-greta-1344782/"][B]The Wasteland Survival Guide[/B][/URL]
Sundowner is offline   Reply With Quote Quick reply to this message
Unread 02-24-2014, 09:37 PM   #1127
Hendrix
TJOTY 2013
Hendrix's Avatar
Good looking Cage there Danno!
Hendrix is offline   Reply With Quote Quick reply to this message
Unread 02-25-2014, 05:17 AM   #1128
Danno6102
Thanks John! Welding it up is going to be tough. I switched to .030 wire & they look a lot better, but getting that sweeping motion around the tube is not coming to me yet. More practice!
[url="http://www.indyorv.com"][B]IndyORV[/B][/url]
[URL="http://www.jeepforum.com/forum/f22/dannos-dd-tj-build-1320254/"][B][I]My Build[/I][/B][/URL]
"Evolution through carnage, the Jeep will keep what it needs."
Danno6102 is offline   Reply With Quote Quick reply to this message
Unread 02-25-2014, 01:37 PM   #1129
84jeepcj7rock
Best looking winch guard I have seen. Tucked in nice. Great lines. Doesn't block the lights. Integrates the clevis mounts really well. Very impressed.
84jeepcj7rock is offline   Reply With Quote Quick reply to this message
Unread 02-25-2014, 07:01 PM   #1130
Danno6102
Thanks!! Let's hope a lot of people feel the same way you do!
Unread 02-26-2014, 06:32 AM   #1131
Danno6102
Got my seat mounting figured out & fab'd last night. Pretty simple. Just used some 2x rectangular tube & coped them over the cross bars. My seat bolts mount down, so I'll drill mounting holes in top of the U brackets to bolt the seats in. They'll be welded on both sides to the cross bars so should be plenty strong. All that's left is the harness bar & the X bracing, harness tabs & some grab handles & we should be ready to pull it for final welding.
Unread 02-26-2014, 06:58 AM   #1132
Sundowner
Looks workable to me!
Unread 02-26-2014, 07:49 AM   #1133
green50gt
green50gt's Avatar
I have a shop vac, do you want to borrow it? Looks good, very jelly!
green50gt is online now   Reply With Quote Quick reply to this message
Unread 02-26-2014, 08:03 AM   #1134
Danno6102
Yea, it really needs a cleaning. My son even commented on it Saturday. I'll get her hosed out before the cage goes in for the final time.
Unread 02-26-2014, 08:25 AM   #1135
janesy86
Cage is coming together nicely! And I dig that winch guard too!
03' Rubi: 2" BDS, 1.25" BL/MML, Hylined rollin' on 35" MTR's
[URL="http://www.jeepforum.com/forum/f22/janesys-03-rubicon-build-1358239"]Hylined '03 Rubi Build[/URL]
[URL="http://www.wm4x4.com/forums/"]Western MA 4x4[/URL]
janesy86 is offline   Reply With Quote Quick reply to this message
Unread 02-26-2014, 10:09 AM   #1136
Danno6102
Thanks! I'm ready to be done with the cage! I want to drive my jeep again!
Unread 02-26-2014, 12:34 PM   #1137
MO2500
MO2500's Avatar
Make sure you weld as much as you can with all corners bolted in tight before you pull it to finish getting the spots you can't reach, just to minimize distortion during welding. trust me, it will still require a little finesse to line it back up again once you drop it back in place.
Looking good
ODonnell Motorsports
Build Thread
Instagram: @omsmike
MO2500 is offline   Reply With Quote Quick reply to this message
Unread 02-26-2014, 02:45 PM   #1138
boilerup1998
Looks like a good time to take the opportunity to line the inside of the Jeep!
Looking good Dan....hope to see you at the BLs soon. Heading out tomorrow afternoon. Hopefully, the ground has frozen again so it's not so muddy....looking forward to it being hot and dusty out there again. This winter sucks!!!
boilerup1998 is offline   Reply With Quote Quick reply to this message
Unread 02-28-2014, 04:59 AM   #1139
Danno6102
I decided to lower my seats a little bit last night. Cut the tacks on the rear seat bar & lowered it about 1/2" & then lowered the front. A little more head room is nice. Seems really tight. Maybe because I never had bars over my head before.
With the seats lowered I was able to locate the harness bar. Located that in bendtech & the subsequent X bracing & cut & bent those pieces up. Going to print the cut templates today & notch & tack everything in tonight. If all goes as planned I should be able to final weld everything tomorrow.
I do need to remove my dash. I've found some write-ups online, but if anyone has any words of advice, things to look out for, or things to make it any easier I would greatly appreciate it. The dash is pretty much loose now, so really the only thing that needs to come off is the steering wheel/column.
My goal is to have it driveable by Sunday evening. Just in time for another big round of mother ****ing snow!
Unread 02-28-2014, 06:24 AM   #1140
84jeepcj7rock
Would you make one for me. I'd like to tie it into my grill hoop to add some stiffness up front around the steering box and winch plate. If so, how much?
caliper flip , ford 8.8 , indyorv , outboard , tube fenders
