Danno's DD TJ Build - Page 75 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Danno's DD TJ Build
JKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6Teraflex JK HD Hinged Carrier & Adjustable Spare Tire FREE, FREE, FREE EVENT!! Save big on Lockers now till Apri
Unread 02-14-2014, 06:49 AM   #1111
Danno6102
Originally Posted by green50gt View Post
Looks really good, I like it! When is your gas tank going to fall out?
Thanks man! I'm really happy with how its coming together!
LOL! Recent discussions relating to our primary state of residency may put some build plans on an immediate temporary hold. I'll keep you posted. You're first in line if & when it does fall out.
[url="http://www.indyorv.com"][B]IndyORV[/B][/url]
[URL="http://www.jeepforum.com/forum/f22/dannos-dd-tj-build-1320254/"][B][I]My Build[/I][/B][/URL]
"Evolution through carnage, the Jeep will keep what it needs."
Danno6102 is offline   Reply With Quote Quick reply to this message
Unread 02-14-2014, 12:49 PM   #1112
Danno6102
This whole tube bending & fabrication thing is starting a slippery slope. Thoughts on something along these lines. I would like to maintain everything that is in the stock dash, heat, AC, radio, new gauges, but monitor same things, turn signals, high beam indicator, CEL, 4WD indicator, etc. 12 volt guy has a nice dash panel that I would more than likely incorporate. I'd probably maintain the stock steering column & wheel for each of turn signals etc, & safety.
12 volt guy dash panel
Unread 02-14-2014, 12:54 PM   #1113
Sundowner
I like it.
If it's worth doing, then it's worth [I]over[/I]doing.
The build, the gear, and the mileage: [URL="http://www.jeepforum.com/forum/f22/wasteland-survival-guide-engineering-greta-1344782/"][B]The Wasteland Survival Guide[/B][/URL]
Sundowner is offline   Reply With Quote Quick reply to this message
Unread 02-14-2014, 01:04 PM   #1114
kellerumps
Here is what I am thinking about.....
Next winters project as of right now. My plan is to actually try and diagram my design, then build a Jig to build it, then start acquiring the gauges/switches, then hopefully take out the old dash and replace with the new one.
I don't look for problems....They find me.
Member of: [URL="http://www.indyorv.com"][B]IndyOrv[/B][/URL]
kellerumps is offline   Reply With Quote Quick reply to this message
Unread 02-14-2014, 01:35 PM   #1115
bobthetj03
Wow! Nicely done sir!
Bob's boring build:
http://www.jeepforum.com/forum/f22/b...build-1304260/
White Jeep club member #2003
www.norcal-jeeps.com
bobthetj03 is online now   Reply With Quote Quick reply to this message
Unread 02-14-2014, 01:46 PM   #1116
TJRHD
Holy moly, i have missed so much.
NOT A HATER
TJRHD is offline   Reply With Quote Quick reply to this message
Unread 02-14-2014, 06:29 PM   #1117
G Beasley
Cage is looking really good , cant believe how fast your moving !
G Beasley is offline   Reply With Quote Quick reply to this message
Unread 02-15-2014, 11:20 AM   #1118
84jeepcj7rock
Originally Posted by Sundowner
I'm loving those fastback-styled rear tubes.
Me too. Love that fastback look.
84jeepcj7rock is offline   Reply With Quote Quick reply to this message
Unread 02-23-2014, 08:20 PM   #1119
JJeeper09
Hey, could you pm me your email or phone number? Got a few questions for you
[URL="http://www.jeepforum.com/forum/f22/project-do-right-1147962/"][B]Rubicon Build[/B][/URL]
JJeeper09 is online now   Reply With Quote Quick reply to this message
Unread 02-24-2014, 05:35 AM   #1120
Danno6102
Took a break from cage work to mock up a winch guard for the new bumper. What a pain in the *** to get everything oriented right to tack it. 5 arms would have been helpful here. I'm going to build a jig & cut the tacks & tack it all back together. Now you can all see the reason for the crazy shark fin clevis mounts.
After that was done I got the cross bars for the seat mounts tacked in. Going to get some steel for the seat mounts & work on those tomorrow. Pine Wood Derby tonight, so no Jeep work!
And a shot of my boy playing on his new jungle gym.
Unread 02-24-2014, 07:49 AM   #1121
Sundowner
That winch guard is awesome; as we discussed, it does seem hard to make. Could you straighten the vertical parts to eliminate some of the complexity, or would that screw up the look?
Unread 02-24-2014, 07:59 AM   #1122
Danno6102
I think that would screw up the look. With the jig it'll be a breeze. It was just hard trying to hold 3 tubes that needed to lean forward & then the top tube flat & a mig gun all at once. Bendtech gives me all the notching templates, so that's no big deal. I already have the jig figured out. Just need to build it. It'll locate everything & provide a template to mark the cut angle on the bottom.
Unread 02-24-2014, 08:08 AM   #1123
Sundowner
Very cool.
Unread 02-24-2014, 08:11 AM   #1124
AngryTJ
awesome design Danno!
[SIZE="5"][COLOR="Blue"]Follow me on Instagram @ Tarantula_TJ[/COLOR][/SIZE]
[URL="http://www.jeepforum.com/forum/f22/angrytjs-97tj-05-rubicon-build-1271051//"][SIZE="4"][B]
Tarantula_TJ Build[/B][/SIZE][/URL]
AngryTJ is online now   Reply With Quote Quick reply to this message
Unread 02-24-2014, 08:18 AM   #1125
Danno6102
Thanks Lu! I was inspired by Jay's.
caliper flip , ford 8.8 , indyorv , outboard , tube fenders
