Danno's DD TJ Build - Page 72 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Danno's DD TJ Build
The Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!The Ruffstuff NOT Universal 4 Link Kit!
Unread 12-10-2013, 12:28 PM   #1066
green50gt
green50gt's Avatar
Just spying on that skid - man that thing is flat! Really nice job you did!
green50gt is offline   Reply With Quote Quick reply to this message
Unread 01-02-2014, 10:27 AM   #1067
Danno6102
Just pulled the trigger on some Mastercraft seats & some Crow belts. Putting the 2014 mod list into action!
Here's a rough list of the big mods I'd like to accomplish this year.
Seats & Belts
Cage
Fuel Cell
3 link front
4 link & stretch
From there I'll start putting together the axles sitting in the shop, but those will probably be on the 2015 mod list for install. I'm also toying with the idea of lowering the rig down a little. I have a 3/4" spacer in the front, thought about taking that out & then adjusting the rear height with the coil bucket relocation. Even thought about lowering even more & going to 3" springs in the front. That'd also require high lining the front with some custom hybrid aluminum/steel tube fenders.
[url="http://www.indyorv.com"][B]IndyORV[/B][/url]
[URL="http://www.jeepforum.com/forum/f22/dannos-dd-tj-build-1320254/"][B][I]My Build[/I][/B][/URL]
"Evolution through carnage, the Jeep will keep what it needs."
Danno6102 is offline   Reply With Quote Quick reply to this message
Unread 01-02-2014, 10:41 AM   #1068
kellerumps
Seats & Belts
Cage
Fuel Cell
3 link front
4 link & stretch
My front 3 link has turned into a headache.....
I don't look for problems....They find me.
Member of: [URL="http://www.indyorv.com"][B]IndyOrv[/B][/URL]
kellerumps is offline   Reply With Quote Quick reply to this message
Unread 01-02-2014, 11:03 AM   #1069
G Beasley
I am curious as to what you will come up with for fenders . I have been looking at the DeFenders , but its tough to spend that much money on two fenders .
G Beasley is offline   Reply With Quote Quick reply to this message
Unread 01-02-2014, 11:07 AM   #1070
dayriesw
dayriesw's Avatar
1987 MJ Comanche
Seats & Belts
Cage
Fuel Cell
3 link front
4 link & stretch
Lowering the rig is what all the kids are doing these days.
06 WK Hemi Overland.. stock DD
87 MJ project on 37s.. Waggy axles, 6 speed, flipped D300 and Bobbed 10" so far. 3 link coming soon.
Sold:
05 LJ.. Low and on 37s
79 FSJ.. 360/4speed on 38s
85 CJ-7 Renegade
Buy my AEV Pintler TJ Beadlocks. See the classifieds.
dayriesw is offline   Reply With Quote Quick reply to this message
Unread 01-02-2014, 11:25 AM   #1071
green50gt
green50gt's Avatar
Amen to that.
Well...only the REALLY cool ones that is.
Unread 01-02-2014, 11:32 AM   #1072
Danno6102
Nothing to extravagant. 1 1/2" DOM with aluminum skins fastened to tabs. Including inners. Biggest thing is I'm going to try to develop a full bracket kit to remount all the crap under the hood. So no more zip tying thing to grill supports etc. But as fast as I've been moving all these other items, it'll be a while!
I'm not a die hard LCG guy, but with no back seat or spare, I've noticed it's sitting pretty high. I need to get a new belly measurement, but that'll have to wait until all this snow melts.
Unread 01-02-2014, 11:36 AM   #1073
AngryTJ
How come?
[SIZE="5"][COLOR="Blue"]Follow me on Instagram @ Tarantula_TJ[/COLOR][/SIZE]
[URL="http://www.jeepforum.com/forum/f22/angrytjs-97tj-05-rubicon-build-1271051//"][SIZE="4"][B]
Tarantula_TJ Build[/B][/SIZE][/URL]
AngryTJ is online now   Reply With Quote Quick reply to this message
Unread 01-02-2014, 10:22 PM   #1074
G Beasley
No box aluminum tubing for the edge ? I do like the brackets idea , should make for a cleaner install . A set of box tube struts like Impact Orange LJ has also helps clean things up under the hood .
Unread 01-03-2014, 05:52 AM   #1075
Danno6102
Going with steel where it's needed most. Along the outside where it gets beat on trees & drug against rocks etc. Bending AL tube is a ***** & in that application 6061-T6 would be a must. The current plan is 1 1/2"x.120 wall DOM with 6061-T6 outer panels & 5052 inner fenders.
Unread 01-03-2014, 09:10 AM   #1076
gspup
Honestly I don't see why not just going with all steel except for the inners especially if you are already using DOM anyways ? The steel skins really wouldn't weigh much, I was able to install my steel genrights with 'ease' by myself and they are way lighter than stock fenders. Just food for thought as I was very close to buying alum.
I think on 40 inch tires alum fenders are fine but as all of us on 35's know, we are a lot closer to the rocks.
gspup is offline   Reply With Quote Quick reply to this message
Unread 01-03-2014, 09:35 AM   #1077
kellerumps
How come?
Welp.....its more than just a 3-link. Re-Doing my CO's. Found out on Jan 1 that I have to cut and redo my exhaust (Again). Was hoping I could get rid of the CAT's on the Manifold and 1 of the O2 Sensors(does not appear that you can).
Frameside Upper Link bracket is going to be a PITA to weld.
Truth be told...I'm prolly just being a whiny little baby.
Unread 01-03-2014, 10:12 AM   #1078
Danno6102
Yea, I know it won't eliminate a ton of weight, but one benefit is replaceable panels if they get tore up, or replaceable tubes for that matter. Which you could have a steel skin package as well. I even thought about making all the skins out of 5052-H32 to keep the material more uniform. I don't think 6061 is that critical for the panels. The bending of the inners eliminates 6061 as an easy choice for them.
Unread 01-03-2014, 10:41 AM   #1079
Moabrubi
Any plans for corners/tub rails in the future? I like where your work is going.
Moabrubi is online now   Reply With Quote Quick reply to this message
Unread 01-03-2014, 10:56 AM   #1080
Danno6102
Yep those are on the list for this year as well . I'm looking to skin the whole rear end of the jeep in aluminum. corners, tailgate skin, etc.
caliper flip , ford 8.8 , indyorv , outboard , tube fenders
