Danno's DD TJ Build - Page 71 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Danno's DD TJ Build
Tactical Recovery Equipment Soft Shackles!!!50% Off Sale at KrawlOff-Road.com50" LED CREE Light Bar Pair With Wiring Kit
Unread 11-19-2013, 06:52 PM   #1051
boilerup1998
Originally Posted by Danno6102
Just measured the wms on the Dana 60 I got. 65.5"! Makes me happy I don't have to mess with narrowing it! That looked a little complex & expensive.
Exactly what mine is
boilerup1998 is offline   Reply With Quote Quick reply to this message
Unread 11-22-2013, 04:50 AM   #1052
Danno6102
I finally got around to putting together a video of the our club campout we had in September. Much easier than I thought it was going to be. I didn't have a lot of real good footage, so the video isn't the greatest. I'll try to get some more footage of other rigs & have someone take some video of mine from outside the rig next time.
Enjoy!
I also ordered up some new nutserts for my tranny skid from Blaine to replace the one that stripped out & the others while I'm at it.
[url="http://www.indyorv.com"][B]IndyORV[/B][/url]
[URL="http://www.jeepforum.com/forum/f22/dannos-dd-tj-build-1320254/"][B][I]My Build[/I][/B][/URL]
"Evolution through carnage, the Jeep will keep what it needs."
Danno6102 is offline   Reply With Quote Quick reply to this message
Unread 11-22-2013, 09:35 AM   #1053
gst95dsm
Chop, Wheel and Rebuild..
gst95dsm's Avatar
Nice vid Danno! Looks like some fun spots.
My Build Thread
gst95dsm is offline   Reply With Quote Quick reply to this message
Unread 12-05-2013, 04:59 AM   #1054
Danno6102
Finally received my parts for the revised skid plate. I really need to invest in my own plasma table.
First order of business was replacing a couple nutserts. One was stripped & the other had broken off. Whipped up this little tool to do the job. 1/2" star washers, 5/8" nut, 7/16" flat washer. Worked perfect on the first one, didn't work worth **** on the second. Nutsert kept spinning, so I just tacked the nutsert to the frame rail, then compressed it with the tool.
Then got to work fitting up the skid & welding. I am really happy with the way this one turned out! I might add a couple reinforcing fins down each side parallel with the frame rails, just need to look & see where I can fit them. Possibly between the exhaust & TC & there is plenty of room on the driver side. It is currently mounted with a new stock transmission mount. NVH was noticeably reduced. I'll research later, but I think it could be done with a lopro mount & no BL. As far as my welding, I had a couple beads that were down right gorgeous, upper left for example if you can see it, the rest were ok. Here she is all welded up. Thoughts? Comments? Constructive criticism?
Mounted. Looks like I have a TC leak I need to address.
I then repositioned my exhaust hanger & welded it. I think I am going to design a new adjustable hanger plate to help position the exhaust perfectly, then drill a couple holes & bolt to permanently lock in the height.
Unread 12-05-2013, 05:14 AM   #1055
Imped
Imped's Avatar
Nice dude! Run it.
I'll have to show you what I use to set frame nutserts. It's probably done around 20 of them with no problem.
OlllllllO
Float Test Build
IndyORV
Imped is offline   Reply With Quote Quick reply to this message
Unread 12-05-2013, 05:37 AM   #1056
Danno6102
Nice dude! Run it.
Thanks man!
Tacking the nutsert worked well, as soon as the star washer bites it's fine. Definitely like to see what you use. I still need to do the remaining 4.
Unread 12-05-2013, 08:57 AM   #1057
gst95dsm
gst95dsm's Avatar
That's pretty Danno. Nice work!
My Build Thread
Unread 12-05-2013, 09:36 AM   #1058
bobthetj03
I'm liking that skid, A LOT!
Bob's boring build:
http://www.jeepforum.com/forum/f22/b...build-1304260/
White Jeep club member #2003
www.norcal-jeeps.com
bobthetj03 is offline   Reply With Quote Quick reply to this message
Unread 12-05-2013, 09:58 AM   #1059
Danno6102
Thanks Gents! I'm pretty happy with how it turned out. Next thing I need to address is the engine skid. It will sit in the little recessed area on the front of the skid so the bottom will be almost smooth with no edges to grab on to stuff.
Unread 12-06-2013, 05:56 PM   #1060
Danno6102
Took a few pics of the skid seeing as how I had a bright back drop.
Unread 12-06-2013, 06:03 PM   #1061
G Beasley
Jeep-Owner.com
G Beasley's Avatar
Thats tucked !
G Beasley is offline   Reply With Quote Quick reply to this message
Unread 12-06-2013, 06:14 PM   #1062
yellow_snocone
I like how that skid came out
Military Jeepers
S.W. New Mexico region
[URL="http://www.jeepforum.com/forum/f22/chesters-tj-build-1420405/"][COLOR="Green"]Chester TJ build[/COLOR][/URL]
[URL="http://www.jeepforum.com/forum/f330/rubicon-trail-august-9th-11th-2014-a-1550022/"][COLOR="Blue"]2014 JF RUBICON TRIP[/COLOR][/URL]
yellow_snocone is offline   Reply With Quote Quick reply to this message
Unread 12-06-2013, 06:52 PM   #1063
Kodiak17
Looks solid!
Maintain, wheel, upgrade, repeat.
My build: http://www.jeepforum.com/forum/f22/thor-dd-weekend-warrior-1348534/
Kodiak17 is offline   Reply With Quote Quick reply to this message
Unread 12-06-2013, 06:54 PM   #1064
Imped
Imped's Avatar
I really like the skid man.
OlllllllO
Float Test Build
IndyORV
Unread 12-07-2013, 10:58 AM   #1065
JJeeper09
Nice work! May want one down the road.
[URL="http://www.jeepforum.com/forum/f22/project-do-right-1147962/"][B]Rubicon Build[/B][/URL]
JJeeper09 is offline   Reply With Quote Quick reply to this message
caliper flip , ford 8.8 , indyorv , outboard , tube fenders
