Danno's DD TJ Build - Page 68 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Danno's DD TJ Build
BDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRuffstuff 10 year saleRough Country Lift Kits and Parts!
Unread 11-05-2013, 10:50 AM   #1006
gst95dsm
Chop, Wheel and Rebuild..
gst95dsm's Avatar
Originally Posted by Danno6102
& that's the way it's mounted.
Me too....
My Build Thread
gst95dsm is offline   Reply With Quote Quick reply to this message
Unread 11-05-2013, 12:24 PM   #1007
gst95dsm
gst95dsm's Avatar
Made a new cat hanger, reversed.... 1/2 rod bent in my vise. This should help matters in the front.
My Build Thread
Unread 11-05-2013, 12:32 PM   #1008
AngryTJ
Cats are overrated
[SIZE="5"][COLOR="Blue"]Follow me on Instagram @ Tarantula_TJ[/COLOR][/SIZE]
[URL="http://www.jeepforum.com/forum/f22/angrytjs-97tj-05-rubicon-build-1271051//"][SIZE="4"][B]
Tarantula_TJ Build[/B][/SIZE][/URL]
AngryTJ is offline   Reply With Quote Quick reply to this message
Unread 11-05-2013, 12:36 PM   #1009
gst95dsm
gst95dsm's Avatar
Originally Posted by AngryTJ
Cats are overrated
They are gold in Cali, people actually steal them!
My Build Thread
Unread 11-05-2013, 12:39 PM   #1010
Danno6102
Attachment 817946
Attachment 817954
Are you relocating the cat by doing that somehow? Because that's what really needs to happen so the crossmember can run all the way through.
[url="http://www.indyorv.com"][B]IndyORV[/B][/url]
[URL="http://www.jeepforum.com/forum/f22/dannos-dd-tj-build-1320254/"][B][I]My Build[/I][/B][/URL]
"Evolution through carnage, the Jeep will keep what it needs."
Danno6102 is offline   Reply With Quote Quick reply to this message
Unread 11-05-2013, 12:49 PM   #1011
gspup
Same here in CO.
gspup is offline   Reply With Quote Quick reply to this message
Unread 11-05-2013, 12:58 PM   #1012
gst95dsm
gst95dsm's Avatar
I'm hoping that by getting the hanger out of the way I can fit the support under the exhaust pipe where the hanger was. Getting ready to test fit right now, I just got the exhaust back together.
My Build Thread
Unread 11-05-2013, 01:32 PM   #1013
Danno6102
Gotcha! For me, with the huge 42RLE tranny pan, I don't have the room to do that. That's why I was going to make a bend right in front of the cat. It'd only be about 8" wide, but would sort of pick up where that welded angle left off. Maybe weld a small piece going front to back tying the two together.
Unread 11-05-2013, 01:53 PM   #1014
Danno6102
How thick is the stock cat? I wonder if, for those that need to run a cat, switching to something like this at only 4" diameter would allow enough room for full width bracing to slide underneath.
http://www.summitracing.com/parts/mpe-54955/overview/
Unread 11-05-2013, 02:27 PM   #1015
JJeeper09
I pretty much did what Nate did
[URL="http://www.jeepforum.com/forum/f22/project-do-right-1147962/"][B]Rubicon Build[/B][/URL]
JJeeper09 is offline   Reply With Quote Quick reply to this message
Unread 11-05-2013, 03:33 PM   #1016
gst95dsm
gst95dsm's Avatar
Here's what I'm looking at welding up...
My Build Thread
Unread 11-05-2013, 03:38 PM   #1017
Danno6102
Ok I went back & looked at nate's install pics. The front edge of my skid & subsequently the support angle are further back than his to clear my stupid tranny pan. My support angle runs right into the cat body. I took a quick measurement & there is just over 6" from the top of my skid to the bottom of my tub. The magnaflow above is shorter & smaller diameter & could fit in that space & easily fit a cross member under it. Could even shift it rearward to gain even more room under the pipe. Relatively cheap too. So that would be a relatively easy option for someone who needs to run a cat. I however, I think mine is getting trashed & a full width true crossmember designed up.
This has been some great discussion guys! Thanks!
Unread 11-05-2013, 03:39 PM   #1018
dayriesw
dayriesw's Avatar
Attachment 818402
That is what I was trying to explain this morning but run all the angles into each other so they form a full rectangle (or trapezoid)
06 WK Hemi Overland.. stock DD
87 MJ project on 37s.. Waggy axles, 6 speed, flipped D300 and Bobbed 10" so far. 3 link coming soon.
Sold:
05 LJ.. Low and on 37s
79 FSJ.. 360/4speed on 38s
85 CJ-7 Renegade
Buy my AEV Pintler TJ Beadlocks. See the classifieds.
dayriesw is offline   Reply With Quote Quick reply to this message
Unread 11-05-2013, 03:40 PM   #1019
Danno6102
Originally Posted by dayriesw
That is what I was trying to explain this morning but run all the angles into each other so they form a full rectangle.
Was just going to suggest that from your post!
Maybe even flipping the side angles around to tie in the rectangle tubes to the vertical flanges too.
Unread 11-05-2013, 03:41 PM   #1020
gst95dsm
gst95dsm's Avatar
I was gonna say earlier were all dealing with different things under there, but sharing all of our individual tweaks will help everyone overall. I think that aftermarket cat is a great idea.
My Build Thread
caliper flip , ford 8.8 , indyorv , outboard , tube fenders
