Danno's DD TJ Build - Page 57 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Danno's DD TJ Build
The Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!The Ruffstuff NOT Universal 4 Link Kit!
Unread 05-16-2013, 08:24 AM   #841
LifeProof
SEMPER FIDELIS
LifeProof's Avatar
"yo dawg, i heard you like outboarding, so i outboarded your outboard"
LifeProof is offline   Reply With Quote Quick reply to this message
Unread 05-16-2013, 08:51 AM   #842
Danno6102
LOL! Nice! Shows the importance of cycling suspension & checking clearances on everything prior to welding. I didn't have that chance seeing as how I welded all the bracket on the axle at my bro in laws house, away from the jeep, so we just measured & then guessed. The axle moves laterally a lot more than I expected.
[url="http://www.indyorv.com"][B]IndyORV[/B][/url]
[URL="http://www.jeepforum.com/forum/f22/dannos-dd-tj-build-1320254/"][B][I]My Build[/I][/B][/URL]
"Evolution through carnage, the Jeep will keep what it needs."
Danno6102 is offline   Reply With Quote Quick reply to this message
Unread 05-22-2013, 06:21 AM   #843
Danno6102
Got out & wheeled Mission Impossible this past weekend. Good time! I was the least built in the group, but kept up with the big boys all day. I tried some climbs I never had the balls to do & made them. We were done at MI around 5:00 or so & headed over to the quarry at the Badlands, where I did some pretty impressive climbs there as well. No videos of those though. cameraman! The flat belly is flat out titties! I might have sraped it maybe twice all day long. She drove smooth at butter all the way there & back at 70 mph. Didn't break anything all day.
I ran the MTR's down at 10psi & didn't have a lick of trouble with popping beads or spinning on the rim. So that's my new psi. All the sidewalls held up fine, so no need to use the Discount Tire warranty this time.
I never really found myself wanting more wheelbase all day long. It's kind of a damned if you do & damned if you don't scenario I think. There were a few obstacles the longer rigs similar to mine, on 35's, struggled a little with, that I one shot, but there were some things they tried that I back down from. Analyzing the obstacles I tackled, there is a lot more I can ask of the Jeep the way it sits. The only thing I really found my self wanting quite a few times all day, was a good cage & seats with a 5 point harness. The windshield is a critical item, that is really in harms way, so it'd be nice to remove that when wheeling, which the cage would allow me to do.
I took some measurements last night & have been looking at some of the cages out there for ideas. I really like the BTF full cage design & will probably copy that with a few changes. I will use the stock B & C pillars.
1. Extend the tube through the dash to the floor. No stanchions.
2. Windshield V bars.
3. Tube gussets on the B pillar.
4. Instead of bending the spreader bars down as the A pillars to the floor, they will run straight to the windshield, then the A pillars will come up through the dash & weld into the spreader bar. Just like their Sport Cage does.
5. Some front grab handles to make it easier for my wife to get in.
Now, let's talk about seats. I'm looking for something good, but affordable. I would like a recliner type seat as I still need relatively easy access to the back seat for my kids. I have not decided against a fixed back & price alone might push me that way. Can anyone comment about rear seat accessiblity with a fixed back seat? I'm looking to stay under $300 per seat.
PRP Daily Driver - In my price range. The lower sides would be nice, but it's fixed back. $280
Corbeau Moabs - Right at my price limit. Cloth version is $80 less. Flipper. Not a lot of hip support. $300/$260
Corbeau Baja SS - very affordable, but is a fixed back seat. Good hip support. $200
Any others I should look at?
Unread 05-22-2013, 09:38 AM   #844
Danno6102
Add another seat to the mix. Another fixed back. Corbeau Baja JP. $200
I also forgot to mention I've been tossing around the idea of revamping my front bumper/winch plate to get a little better approach angle. Right now the bumper sticks out about 2" from the end of the frame rails & then the D ring mount sticks out another 2 1/2" or so. Am thinking about wrapping the bumper tight to the end of the frame rail & then mounting the D ring lugs on top of the bumper just offset of the bumper mounting bolts.
Unread 05-22-2013, 09:39 AM   #845
JJeeper09
I have the btf.i am going to redo the front. I want it to be stronger, and straight through the dash. I will use my own tube so the 1.5 dash spreader will be eliminated. I want to start this soon because I know the sanchions are not that strong .
[URL="http://www.jeepforum.com/forum/f22/project-do-right-1147962/"][B]Rubicon Build[/B][/URL]
JJeeper09 is offline   Reply With Quote Quick reply to this message
Unread 05-22-2013, 09:51 AM   #846
Danno6102
Yea, I have access to a bender & my bro in law can run some sweet tig beads, so I'm saving some cash & just going to build it myself. I plan on 1 3/4" x .120 DOM everywhere except the grab handles & gussets. I just called a place here in Indy, Warner Steel, & got a price of $4.50 a foot for the 1 3/4". She double checked the price.
Unread 05-22-2013, 10:27 AM   #847
Imped
Imped's Avatar
I like Warner......go get that now before the price goes up.
OlllllllO
Float Test Build
IndyORV
Imped is offline   Reply With Quote Quick reply to this message
Unread 05-22-2013, 11:46 AM   #848
bobthetj03
Check out AngryTJ's build. He just recently did a writeup on his cage addition. Something similar to what your thinking of.
Bob's boring build:
http://www.jeepforum.com/forum/f22/b...build-1304260/
White Jeep club member #2003
www.norcal-jeeps.com
bobthetj03 is offline   Reply With Quote Quick reply to this message
Unread 05-22-2013, 11:48 AM   #849
bobthetj03
Not the most popular but it's another affordable option.
http://www.smittybilt.com/product/index/36.htm
Bob's boring build:
Unread 05-22-2013, 01:05 PM   #850
Kodiak17
Genright has two used reclining seats on their closeout section. $200 for the pair.
Maintain, wheel, upgrade, repeat.
My build: http://www.jeepforum.com/forum/f22/thor-dd-weekend-warrior-1348534/
Kodiak17 is offline   Reply With Quote Quick reply to this message
Unread 05-22-2013, 07:01 PM   #851
SwiftJeep
Hey my phone was dead from 2 hours of videos. I think it held up good for that long
SwiftJeep is offline   Reply With Quote Quick reply to this message
Unread 05-22-2013, 07:10 PM   #852
Danno6102
I really should have gotten the gopro out. Next time for sure. I have some ideas for new angles.
Unread 05-22-2013, 08:03 PM   #853
boilerup1998
Danno, I had the Genright sport cage added to my LJ stock cage and it's pretty stout. Tied I the frame, im pretty damn sure its not going anywhere if i flop. I think it looks pretty sweet too.
I would agree that a long wheelbase isn't always better. I actually got pinned at the top of a steep climb (on red trail I think) because I could fit between a tree and a big root sticking out.
boilerup1998 is offline   Reply With Quote Quick reply to this message
Unread 05-31-2013, 01:42 PM   #854
Danno6102
New front bumper/winch plate is underway. Should have the initial bent profile sometime next week. They're going to burn me some 1" D ring mounts too. I'm tossing around a couple different ideas for the D ring mounts to keep them out of the way. It's good to know the right people.
Unread 05-31-2013, 03:29 PM   #855
dayriesw
dayriesw's Avatar
1987 MJ Comanche
Need to see more of this LJ...
06 WK Hemi Overland.. stock DD
87 MJ project on 37s.. Waggy axles, 6 speed, flipped D300 and Bobbed 10" so far. 3 link coming soon.
Sold:
05 LJ.. Low and on 37s
79 FSJ.. 360/4speed on 38s
85 CJ-7 Renegade
Buy my AEV Pintler TJ Beadlocks. See the classifieds.
dayriesw is offline   Reply With Quote Quick reply to this message
caliper flip , ford 8.8 , indyorv , outboard , tube fenders
