Danno's DD TJ Build - Page 56 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Danno's DD TJ Build
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 05-12-2013, 02:37 AM   #826
yellow_snocone
Originally Posted by Danno6102 View Post
What exactly was the issue with the mount? I'm running the currie HD track bar with the big *** bolt that had to have the mount drilled out. It's "blow out your butthole" tight.
I had a PS rustys trackbar with the TRE. I spent some good money on a JKS and fixed it good. Like mentioned earlier check your CAs they are sneaky
Military Jeepers
S.W. New Mexico region
[URL="http://www.jeepforum.com/forum/f22/chesters-tj-build-1420405/"][COLOR="Green"]Chester TJ build[/COLOR][/URL]
[URL="http://www.jeepforum.com/forum/f330/rubicon-trail-august-9th-11th-2014-a-1550022/"][COLOR="Blue"]2014 JF RUBICON TRIP[/COLOR][/URL]
yellow_snocone is offline   Reply With Quote Quick reply to this message
Unread 05-12-2013, 07:25 AM   #827
Danno6102
I have Currie lower arms. They are 2 years old so they may be worn. I'll check them out.
No work today, Mother's Day.
[url="http://www.indyorv.com"][B]IndyORV[/B][/url]
[URL="http://www.jeepforum.com/forum/f22/dannos-dd-tj-build-1320254/"][B][I]My Build[/I][/B][/URL]
"Evolution through carnage, the Jeep will keep what it needs."
Danno6102 is offline   Reply With Quote Quick reply to this message
Unread 05-13-2013, 06:13 PM   #828
boilerup1998
Highly doubt it, but you've been through about everything else. Might as well check!
boilerup1998 is offline   Reply With Quote Quick reply to this message
Unread 05-13-2013, 06:30 PM   #829
Danno6102
Lower arms & tie rod ends (which are almost new currie) are the only things I haven't really checked. I felt them when I did the ball joints this weekend, but not sure how to tell if they are starting to go. I'm meeting Connor Wednesday to get another set of eyes on everything before MI on Saturday. So hopefully I'll drive home wobble free Wednesday night!
Unread 05-13-2013, 09:35 PM   #830
boilerup1998
Good deal. I'm probably going to head to BL on Saturday, regardless if there is space to run MI. I can't stand looking at my rig just sitting in the garage begging to be wheeled.
Unread 05-15-2013, 06:08 AM   #831
Danno6102
Welp, turns out I was wrong. The pesky culprit was tire imbalance. It sure didn't feel like it, but I guess I've never had it that severe. It's 98% better. No wobble at all up to 60mph. There is a VERY slight wobble when I hit some bumps in the road, but it dissipates very quickly & if I'm not trying to feel it, I probably wouldn't notice it. I call that a win! I'm still boggled as to how doing a tummy tuck, BL & MML. would cause my tires to become so imbalanced.
Got my new spare mounted last night & the other four tires balanced. Told them to get them as close to zero as possible & put the two best ones on the front. I also explained my situation about the warranty tire to the sales rep & he sold me their warranty on all five tires. So if I rip a sidewall completely off this weekend, I get a free replacement.
After I got home last night I put together what I am calling my "INDOT tire bar". I used a piece of a speed limit sign pole that fell down in front of my house a few years back. There is a hole in the top of each rear fender that is plugged with a grommet. I cut the sign pole to length. It has holes in inch increments which worked out perfectly. I drilled the necessary ones on each end out to 1/2" & bolted the pole to the top of the fender well & flopped the tire against it & strapped her down. I now have plenty of flat storage area for coolers, tool bag, etc. that is relatively easily accessible. If I have time I'm going to try to bolt down some small D rings for straps to hold everything down secure.
Unread 05-15-2013, 06:59 AM   #832
AngryTJ
glad you got the wobble figured out for the most part. Those type of things are always a *****
[SIZE="5"][COLOR="Blue"]Follow me on Instagram @ Tarantula_TJ[/COLOR][/SIZE]
[URL="http://www.jeepforum.com/forum/f22/angrytjs-97tj-05-rubicon-build-1271051//"][SIZE="4"][B]
Tarantula_TJ Build[/B][/SIZE][/URL]
AngryTJ is online now   Reply With Quote Quick reply to this message
Unread 05-15-2013, 07:46 AM   #833
Danno6102
You're telling me! It's nice to drive the jeep again &, in the words of tommy boy, not want to "jerk the wheel into a God damn bridge abutment!!"
Unread 05-15-2013, 08:49 AM   #834
JJeeper09
Told you! Tires are a pita
[URL="http://www.jeepforum.com/forum/f22/project-do-right-1147962/"][B]Rubicon Build[/B][/URL]
JJeeper09 is offline   Reply With Quote Quick reply to this message
Unread 05-15-2013, 08:57 AM   #835
Danno6102
Yep! You were right man! It'll be the first thing I check next time. These MTR's especially are a PITA to get balanced!
Unread 05-15-2013, 11:53 AM   #836
boilerup1998
You need some Krawlers! No balancing required (or possible!)
Unread 05-15-2013, 03:48 PM   #837
boilerup1998
Btw- what does your plate say?
Unread 05-15-2013, 06:03 PM   #838
Danno6102
7slot tj. For the 7 slots in the jeep grill & it's obviously a tj.
Unread 05-15-2013, 07:39 PM   #839
IEcrawlerTJ01
I run my mtr's on the highway all the time. Been balanced since the first day I got them. I have seem sticky weights fall off and was like thats not good
But. There still driving straight even missing some balance weights. So idk
[CENTER]SAVVY,CURRIE,GOODYEAR
Nuff said...[/CENTER]
IEcrawlerTJ01 is offline   Reply With Quote Quick reply to this message
Unread 05-16-2013, 06:47 AM   #840
Danno6102
Did some more work yesterday. Pretty much all ready for this weekend. Just need to grab some bolts to bolt down my d rings.
I ground down the shelf from N to R on my gear selector. This allows me a quick slap shift into R without having to depress the thumb lock on the handle.
Quick temporary fix for my shock body interference with the frame on full flex. Moved the shock to the outside of the mount & used a longer grade 8 bolt with a crush sleeve stuck in between the old mount. Should hold me over nice until I can get some new mounts welded on.
caliper flip , ford 8.8 , indyorv , outboard , tube fenders
