Going to start in Index here, so if anyone is looking for anything it'll be easier to find.
Index:
Outboard Rear Shocks = Post #16
Start of the Ford 8.8 Swap = Post #32
LED Tail light wiring info = Post #204
Ford Windstar Cowl Intake Mod = Post #230
Ford front shock towers = Post #282
Removing the Charcoal Canister = Post #308
Trimming Rear Flares = Post #574
Start of Cage Design & Install = Post #1081
RCI 2162 Install in a Late Model TJ = Post #1292
I started this build thread over on IndyORV, but things have been slow & boring here at work & I'm always lurking the build threads here, so I figure I'd start one here to, what the hell right?
I bought this '03 Sport Easter weekend 2011. It was bone stock except for a 4" RC suspension lift. Here she is in the dealer parking lot the day I got it.
It came with the hardtop obviously & one of those half top tonneau cover thingys that I dislike & could not use because of kids & needing the back seat, so first purchase was a Supertop NX. Then some misc stuff like a new passenger door seal & the correct speedo gear.
Here's a list of upgrades so far in chronological order:
Supertop NX
Smitty SRC Classic Front bumper, plan to turn this into a stubby someday
XRC-8 Winch
CB Radio Uniden Pro510XL with 4' Firestik
Skid Row Engine Skid & Steering Box skid
B&M Tranny Cooler
Poison spider Hood Louver
Savvy/Currie Front Lower & Rear Upper Control Arms
Fumoto Oil Drain Valve
Riddler Cover for the D30
Aussie Locker for the D30
Rugged Ridge Mirrors
ZJ tie rod upgrade & replaced drag link because it was bent
Currie 4" progressives in the front with a 3/4" spacer
Currie Adjustable front track bar (CE-9120TJJ)
Installed a stock pitman arm. PO had a drop on it. :nono:
JB Conversions SYE with cut down XJ shaft
RE Adjustable rear track bar with JKS CV bracket
T&T Custom rear cross member with 2" receiver. Still need to get this one on, my welder is busy with some **** called a "pumpkinator" :dunno:
Novak shifter cable
Rokmen Mercenary sliders with no tube, I think I'm the only one...
That's what's done so far & this is how she sat a month ago. The Novak & Rokmen's are going ont his weekend.
One of my better wheeling picks. Red trail at The Badlands. My passenger mirror fell victim to that tree that day.
I've also removed the rear tire carrier & DD without a spare. It gets loaded into the tub when we hit the trail. I'm working on a rack to go above it to mount tools & spares. Something that will resemble this.
Next big project on the list is a Ford 8.8. I picked up one from a 1998 Mercury Mountaineer with 3.73 gears to match the front, & limited slip, but I just got a good deal on a set of 4.88 for the D30, so it will get re-geared to match before it goes in. I was also going to 4-link it, but am putting that on hold due to cash flow & I also want to challenge myself a little so I can learn more about line selection, how the Jeep handles, etc. So, we're going with stock bracket kit & I will move the upper frame coil buckets back when we install the 8.8 to get rid of a the arch.
I also have plans to tummy tuck a little. Originally was going to go with UCF UHC skid, but just picked up a 2'x4' piece of 1/4" plate from work, for free. :thumbsup: I probably won't go completely flat, but plan on getting the UCF Lo-pro & going as flat as easily possible for now & go from there.
There you have it. I'll try to update with Novak & Slider install this weekend.
Index:
Supertop NX
XRC-8 Winch
B&M Tranny Cooler
Novak shifter cable
Image uploading. Refresh page to view
