Danno's DD TJ Build - Page 53 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Danno's DD TJ Build
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options! AMP Research Powersteps - A Morris 4x4 Center Promotion
Unread 05-03-2013, 01:33 PM   #781
boilerup1998
Originally Posted by Danno6102
As long as there are some open spots, you can come. It's open to 10 rigs, & those are typically saved for members first. I think we only have 8 right now. I'll be the least built one there.
I'm sure that rig will be fine. You can always take the bypasses on the harder stuff. MI is a cool place man.
If you guys can get my name on the list of 10, then I'll do everything I can to make. I don't want to be sitting around all week though, wondering if I'm going, and not be able to make other plans. Mecum is going on the same weekend and I usually go with my brothers.
boilerup1998 is offline   Reply With Quote Quick reply to this message
Unread 05-03-2013, 02:36 PM   #782
Imped
Imped's Avatar
I'm an IndyORV OG and my efforts to get you on the list were futile.....good luck with all of that. If you go up to Attica that day, I'll definitely wheel with you after MI.
OlllllllO
Float Test Build
IndyORV
Imped is offline   Reply With Quote Quick reply to this message
Unread 05-03-2013, 03:39 PM   #783
boilerup1998
No big deal. I'll hook up with you guys some other time.
Unread 05-03-2013, 07:32 PM   #784
LifeProof
SEMPER FIDELIS
LifeProof's Avatar
OG, double OG, triple OG
LifeProof is offline   Reply With Quote Quick reply to this message
Unread 05-04-2013, 02:38 AM   #785
JJeeper09
Fenders aren't THAT BAD, but I see why you want a change. It's not perfect so it probably catches your eye every time you see the Jeep.
I would work with what you go
[URL="http://www.jeepforum.com/forum/f22/project-do-right-1147962/"][B]Rubicon Build[/B][/URL]
JJeeper09 is offline   Reply With Quote Quick reply to this message
Unread 05-04-2013, 01:12 PM   #786
boilerup1998
Aren't those Connor's old fenders?
Unread 05-04-2013, 01:53 PM   #787
MO2500
MO2500's Avatar
James' fenders I think.
ODonnell Motorsports
Build Thread
Instagram: @omsmike
MO2500 is offline   Reply With Quote Quick reply to this message
Unread 05-04-2013, 04:50 PM   #788
Danno6102
Yea they are James old fenders.
Got the new synthetic line & hawse fair lead on today. Had to cut the permanently fixed hook off so I could use my D ring.
Wobble woes: got the new joint halves installed in the melted side. Made one upper slightly longer to put them in a slight bind. Checked the joints in the track bar, they're fine. Holes seemed slightly oversized, but no signs of any movement at all. I torqued the track bar & lower arm bolts down with a 2' cheater bar, so everything is ridiculously tight. Checked ball joints & unit bearings. Ball joints seemed fine. Had a little play in the driver front unit bearing. Will order two new timkens & get them replaced.
End result: front end was much tighter. Mainly from the new joint halves & the binding, but the wobble is still present. Minor, but still noticeable. Replacement of the unit bearings & an alignment check are next.
[url="http://www.indyorv.com"][B]IndyORV[/B][/url]
[URL="http://www.jeepforum.com/forum/f22/dannos-dd-tj-build-1320254/"][B][I]My Build[/I][/B][/URL]
"Evolution through carnage, the Jeep will keep what it needs."
Danno6102 is offline   Reply With Quote Quick reply to this message
Unread 05-04-2013, 05:11 PM   #789
boilerup1998
What type of synthetic line and where did you buy it?
Unread 05-04-2013, 05:11 PM   #790
gspup
I did the same thing on my synthetic line...I wonder why the hook is standard. Either way...synthetic line is awesome, solid purchase.
gspup is offline   Reply With Quote Quick reply to this message
Unread 05-04-2013, 05:12 PM   #791
gspup
Looks like smitty...cheapest I could find when shopping around. Its held up great for me.
Unread 05-04-2013, 05:59 PM   #792
Danno6102
Yep, it's a smitty. Looked at the higher priced lines, but couldn't justify them in my mind. Like most things I buy, I got it on amazon. $200 for the line, $25 for the hawse fair lead & free two day shipping.
Unread 05-05-2013, 10:02 AM   #793
boilerup1998
100' of 3/8"? Any worry about the winch plate rubbing the line as it exits the back fairlead during "in" pulling? Seems like that could be a sharp, square edge right there.
Unread 05-05-2013, 10:57 AM   #794
Danno6102
The hole in the winch plate is bigger than the hole in the fairlead, so there really isn't any interference. Only place I could see any is when the line is all the way to one side of the drum & that would be minimal with very little pressure.
Unread 05-05-2013, 07:25 PM   #795
boilerup1998
Gotcha
caliper flip , ford 8.8 , indyorv , outboard , tube fenders
