Danno's DD TJ Build - Page 14 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Danno's DD TJ Build
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineWIN a Rough Country Forged Track Bar - ExtremeTerrain!1987-2016 Wrangler Jammock Black 2.0 Jeep Hammock (YJ, TJ
Unread 04-21-2012, 02:18 PM   #196
Danno6102
I need to vent. So my weekend of wrenching turned to ****. Was planning on working a little last night, a little tonight & then all day tomorrow. Well, for various reasons, that's turned into, no work last night, no work tonight, & maybe, if I'm lucky, 4 hours tomorrow. Frustrating as ****! Venting over.
[url="http://www.indyorv.com"][B]IndyORV[/B][/url]
[URL="http://www.jeepforum.com/forum/f22/dannos-dd-tj-build-1320254/"][B][I]My Build[/I][/B][/URL]
"Evolution through carnage, the Jeep will keep what it needs."
Danno6102 is offline   Reply With Quote Quick reply to this message
Unread 04-21-2012, 04:58 PM   #197
Sgt.Fuzz
I feel your pain. I hate it when life gets in the way of wrenching.
[COLOR="Blue"]My build: [url]http://www.jeepforum.com/forum/f22/fuzzbucket-build-1126577/[/url][/COLOR]
Sgt.Fuzz is offline   Reply With Quote Quick reply to this message
Unread 04-21-2012, 06:54 PM   #198
Danno6102
Well, should have left well enough alone. Tried to get the currie front uppers on. I now have a 7/16" washer & an 11/16" socket in my frame rail. Awesome. Got them on though & rear pinion angle set.
Unread 04-21-2012, 10:00 PM   #199
TJRHD
That sounds like my luck. Did your have to drill yours out?
NOT A HATER
TJRHD is offline   Reply With Quote Quick reply to this message
Unread 04-22-2012, 07:03 AM   #200
Danno6102
Had to drill the axle bushings but the frame end was fine.
Unread 04-22-2012, 10:49 AM   #201
Imped
Imped's Avatar
LOL......get a long flexi magnet. You don't want those rattling around in the frame, it'll drive you nuts.
And FYI, should've just used the stock bolts at the axle end.
OlllllllO
Float Test Build
IndyORV
Imped is offline   Reply With Quote Quick reply to this message
Unread 04-22-2012, 10:58 AM   #202
B2CARPEN
B2CARPEN's Avatar
x2... and i hate it when my jeep eats my tools as well
B2CARPEN is offline   Reply With Quote Quick reply to this message
Unread 04-23-2012, 05:37 AM   #203
Danno6102
Even without an 11/16" socket I managed to get some time yesterday & get some stuff done.
Rebuilt the rear JJ finally. Washed them all up in the parts washer then put them all back together with a good coat of green grease.They'll be good for a while.
Got the Wizard brackets installed finally. Snagged the cables from a ZJ from pull-a-part. Someone said I'd need to grind something if I used ZJ cables, but I didn't have to grind anything. Install was stupid easy. Like 10 minutes per side & that included jacking it up & removing the tire. I do need to take them off again & re-route the cable. The way the cable works now it's yanking on my brake lines pretty good. I'll do that one night this week.
It's the wiz, it's the wiz!
Next we moved onto the shocks. Installed JKS BPE's & the upper stud converters. Some of you may be thinking "why the hell is he doing the stud converters when he's just going to do the Ford towers soon anyway." Well, merely for ease of doing the ford towers. When I did the outboard in the back I did not compensate for the pressure of the bilstien's lifting the *** end up another 1/2", so at the time my travel was off. More up than down by about 1/2" or slightly more. I don't want that on the front. I want it dead nuts. So I installed the stud converters to A. get everything setting where it will be setting with the new shocks installed. B. It'll be easy to locate the height of the towers. I measure my the shock travel I have now, which is 2.5", add 3.5" to get me to 6", then I know the center of the shock eye needs to be 3.5" higher than where it sits now. Plus I want to get the shocks broke in before I do the towers too, just in case they sag any from brand new. Sounds logical in my mind. So, I'll have those JKS upper stud converters for sale in a couple weeks. So, I now have all new springs, except for the ones I got from Brad, & all Bilstein 5125 255/70 shocks all around. She rides like a dream now. Wife made the comment again last night that it rides pretty good.
I also got the Currie front uppers installed Saturday. They had those stupid piece of **** JJ. They didn't even bother putting a zerk in these.
So I guess even with my *****ing about my plans getting all ****ed up on me, I still got a lot done.
Unread 04-23-2012, 07:59 AM   #204
Danno6102
I need some LED light assistance.
I've read this thread here.
http://www.jeepforum.com/forum/f9/le...ation-1081228/
& I have the 3/4" LED lights & blinker from Genright on order that should be here early this week.
So I understand how to do the 2 wire to 3 wire conversion for the front markers/turn signals I am putting in the grill. That seems farily simple. My real question pertains to how I need to wire the 2 wire LED lights I'm getting from Genright for my side markers that I am mounting in the fender well. Do I just hook up the existing wires from the old side marker, to the new light & call it a day? Or do I have to run them a certain way or install resisters/diodes with these too?
Gracias Senors!
Unread 04-23-2012, 09:29 AM   #205
B2CARPEN
B2CARPEN's Avatar
Yes you will need resistors and diodes if you want them to function as turn signals. I initially installed them with the ground and constant wires so they act as marker lights only, but never got around to building my 2 to 3 circuit board.
Here's the thread you will need to review before attempting to make your own resistor / diodes..
http://www.jeepforum.com/forum/f9/2-...ite-up-933239/
Unread 04-23-2012, 10:26 AM   #206
Danno6102
Ok, so I basically do the exact same mod to the side markers & then ground it off to the frame?
Here's is a fancy MS Paint sketch to help. I like pictures. Is this what I need to do. Every LED gets grounded to the frame?
Unread 04-23-2012, 05:38 PM   #207
B2CARPEN
B2CARPEN's Avatar
Yes you can route them that way, but you can also just run one resistor / diode per side and splice the wires for the fender and grill lights together so they run off the same resistor / diode.
Unread 04-24-2012, 10:57 AM   #208
Danno6102
Opinions & thoughts please.
I may have to swap the rig over to use hood pins in the very near future. I've been told I can't use the stock hood latches, but I am holding on to a glimmer of hope that I still can somehow. If not, I will have the huge ugly spot where the hinge used to be. Anyone have any ideas for covering this thing up to make it look nice? I thought about a big light for a side marker/signal, but not a big fan of that. Maybe (2) of those 3/4" LED's I'm getting from genright stacked would look better, instead of putting it inside the fender well? I'm open to anything really, so throw me some ideas.
Unread 04-24-2012, 11:33 AM   #209
B2CARPEN
B2CARPEN's Avatar
Can you somehow run the Drake hood latches and just use a custom base on the fender tube?
Unread 04-24-2012, 11:41 AM   #210
Danno6102
Really not sure. I would think if I could run the Drake's I could run the stockers. I think the problem is going to be where the bolt goes down through the fender. I think it's going to be right on the edge of the tube underneath, so no way to get the nut on or set properly. I'll know more saturday once I get them mounted. I don't mind the hood pins themselves, just the big ugly recess that'll be left.
I'm thinking the dual 3/4" LEDs might not look too bad. They got delivered today, so I'll check it out tonight.
caliper flip , ford 8.8 , indyorv , outboard , tube fenders
