Danno's DD TJ Build - Page 71 - JeepForum.com
post #1051 of 1319 Old 11-19-2013, 07:52 PM
boilerup1998
Originally Posted by Danno6102
Just measured the wms on the Dana 60 I got. 65.5"! Makes me happy I don't have to mess with narrowing it! That looked a little complex & expensive.
Exactly what mine is
boilerup1998 is offline
post #1052 of 1319 Old 11-22-2013, 05:50 AM Thread Starter
Danno6102
I finally got around to putting together a video of the our club campout we had in September. Much easier than I thought it was going to be. I didn't have a lot of real good footage, so the video isn't the greatest. I'll try to get some more footage of other rigs & have someone take some video of mine from outside the rig next time.
Enjoy!
I also ordered up some new nutserts for my tranny skid from Blaine to replace the one that stripped out & the others while I'm at it.
"Evolution through carnage, the Jeep will keep what it needs."
Danno6102 is offline
post #1053 of 1319 Old 11-22-2013, 10:35 AM
gst95dsm
Chop, Wheel and Rebuild..
gst95dsm's Avatar
Nice vid Danno! Looks like some fun spots.
gst95dsm is offline
post #1054 of 1319 Old 12-05-2013, 05:59 AM Thread Starter
Danno6102
Finally received my parts for the revised skid plate. I really need to invest in my own plasma table.
First order of business was replacing a couple nutserts. One was stripped & the other had broken off. Whipped up this little tool to do the job. 1/2" star washers, 5/8" nut, 7/16" flat washer. Worked perfect on the first one, didn't work worth **** on the second. Nutsert kept spinning, so I just tacked the nutsert to the frame rail, then compressed it with the tool.
Then got to work fitting up the skid & welding. I am really happy with the way this one turned out! I might add a couple reinforcing fins down each side parallel with the frame rails, just need to look & see where I can fit them. Possibly between the exhaust & TC & there is plenty of room on the driver side. It is currently mounted with a new stock transmission mount. NVH was noticeably reduced. I'll research later, but I think it could be done with a lopro mount & no BL. As far as my welding, I had a couple beads that were down right gorgeous, upper left for example if you can see it, the rest were ok. Here she is all welded up. Thoughts? Comments? Constructive criticism?
Mounted. Looks like I have a TC leak I need to address.
I then repositioned my exhaust hanger & welded it. I think I am going to design a new adjustable hanger plate to help position the exhaust perfectly, then drill a couple holes & bolt to permanently lock in the height.
post #1055 of 1319 Old 12-05-2013, 06:14 AM
Imped
Imped's Avatar
Nice dude! Run it.
I'll have to show you what I use to set frame nutserts. It's probably done around 20 of them with no problem.
OlllllllO
IndyORV
Imped is offline
post #1056 of 1319 Old 12-05-2013, 06:37 AM Thread Starter
Danno6102
Nice dude! Run it.
Thanks man!
Tacking the nutsert worked well, as soon as the star washer bites it's fine. Definitely like to see what you use. I still need to do the remaining 4.
post #1057 of 1319 Old 12-05-2013, 09:57 AM
gst95dsm
gst95dsm's Avatar
That's pretty Danno. Nice work!
gst95dsm is offline
post #1058 of 1319 Old 12-05-2013, 10:36 AM
bobthetj03
I'm liking that skid, A LOT!
Bob's boring build:
White Jeep club member #2003
bobthetj03 is offline
post #1059 of 1319 Old 12-05-2013, 10:58 AM Thread Starter
Danno6102
Thanks Gents! I'm pretty happy with how it turned out. Next thing I need to address is the engine skid. It will sit in the little recessed area on the front of the skid so the bottom will be almost smooth with no edges to grab on to stuff.
post #1060 of 1319 Old 12-06-2013, 06:56 PM Thread Starter
Danno6102
Took a few pics of the skid seeing as how I had a bright back drop.
post #1061 of 1319 Old 12-06-2013, 07:03 PM
G Beasley
Thats tucked !
G Beasley is offline
post #1062 of 1319 Old 12-06-2013, 07:14 PM
yellow_snocone
I like how that skid came out
Military Jeepers
S.W. New Mexico region
yellow_snocone is offline
post #1063 of 1319 Old 12-06-2013, 07:52 PM
Kodiak17
Looks solid!
Maintain, wheel, upgrade, repeat.
My build: http://www.jeepforum.com/forum/f22/thor-dd-weekend-warrior-1348534/
Kodiak17 is offline
post #1064 of 1319 Old 12-06-2013, 07:54 PM
Imped
Imped's Avatar
I really like the skid man.
OlllllllO
IndyORV
Imped is offline
post #1065 of 1319 Old 12-07-2013, 11:58 AM
JJeeper09
Nice work! May want one down the road.
JJeeper09 is offline
caliper flip , ford 8.8 , indyorv , outboard , tube fenders
Jeep Build: Minty White Country XJ Build GTEIS300 Jeep Builds 34 01-20-2013 11:42 AM
2000 TJ Build - LCG First Time Build japete01 Jeep Builds 82 06-07-2012 10:50 PM
JeepWJ26 Build--Johnny Cash Build JeepWJ26 Jeep Builds 31 01-09-2012 12:15 PM
WeatherWarrior's "you better not call it a build" build thread. WeatherWarrior Jeep Builds 10 12-12-2011 06:31 PM
JeepDVL45's 'Bruiser' Build -- A Daily Driver's slow build JeepDVL45 Jeep Builds 41 08-11-2011 10:44 AM
