Danno's DD TJ Build - Page 68 - JeepForum.com
post #1006 of 1319 Old 11-05-2013, 10:50 AM
gst95dsm
Chop, Wheel and Rebuild..
gst95dsm's Avatar
Originally Posted by Danno6102
& that's the way it's mounted.
Me too....
gst95dsm is offline
post #1007 of 1319 Old 11-05-2013, 12:24 PM
gst95dsm
gst95dsm's Avatar
Made a new cat hanger, reversed.... 1/2 rod bent in my vise. This should help matters in the front.
gst95dsm is offline
post #1008 of 1319 Old 11-05-2013, 12:32 PM
AngryTJ
Cats are overrated
AngryTJ is offline
post #1009 of 1319 Old 11-05-2013, 12:36 PM
gst95dsm
gst95dsm's Avatar
Originally Posted by AngryTJ
Cats are overrated
They are gold in Cali, people actually steal them!
gst95dsm is offline
post #1010 of 1319 Old 11-05-2013, 12:39 PM Thread Starter
Danno6102
Attachment 817946
Attachment 817954
Are you relocating the cat by doing that somehow? Because that's what really needs to happen so the crossmember can run all the way through.
"Evolution through carnage, the Jeep will keep what it needs."
Danno6102 is offline
post #1011 of 1319 Old 11-05-2013, 12:49 PM
gspup
Same here in CO.
gspup is offline
post #1012 of 1319 Old 11-05-2013, 12:58 PM
gst95dsm
gst95dsm's Avatar
I'm hoping that by getting the hanger out of the way I can fit the support under the exhaust pipe where the hanger was. Getting ready to test fit right now, I just got the exhaust back together.
gst95dsm is offline
post #1013 of 1319 Old 11-05-2013, 01:32 PM Thread Starter
Danno6102
Gotcha! For me, with the huge 42RLE tranny pan, I don't have the room to do that. That's why I was going to make a bend right in front of the cat. It'd only be about 8" wide, but would sort of pick up where that welded angle left off. Maybe weld a small piece going front to back tying the two together.
post #1014 of 1319 Old 11-05-2013, 01:53 PM Thread Starter
Danno6102
How thick is the stock cat? I wonder if, for those that need to run a cat, switching to something like this at only 4" diameter would allow enough room for full width bracing to slide underneath.
http://www.summitracing.com/parts/mpe-54955/overview/
post #1015 of 1319 Old 11-05-2013, 02:27 PM
JJeeper09
I pretty much did what Nate did
JJeeper09 is offline
post #1016 of 1319 Old 11-05-2013, 03:33 PM
gst95dsm
gst95dsm's Avatar
Here's what I'm looking at welding up...
gst95dsm is offline
post #1017 of 1319 Old 11-05-2013, 03:38 PM Thread Starter
Danno6102
Ok I went back & looked at nate's install pics. The front edge of my skid & subsequently the support angle are further back than his to clear my stupid tranny pan. My support angle runs right into the cat body. I took a quick measurement & there is just over 6" from the top of my skid to the bottom of my tub. The magnaflow above is shorter & smaller diameter & could fit in that space & easily fit a cross member under it. Could even shift it rearward to gain even more room under the pipe. Relatively cheap too. So that would be a relatively easy option for someone who needs to run a cat. I however, I think mine is getting trashed & a full width true crossmember designed up.
This has been some great discussion guys! Thanks!
post #1018 of 1319 Old 11-05-2013, 03:39 PM
dayriesw
dayriesw's Avatar
1987 MJ Comanche
Attachment 818402
That is what I was trying to explain this morning but run all the angles into each other so they form a full rectangle (or trapezoid)
16 Taco
87 MJ Chief in pieces
dayriesw is offline
post #1019 of 1319 Old 11-05-2013, 03:40 PM Thread Starter
Danno6102
Originally Posted by dayriesw
That is what I was trying to explain this morning but run all the angles into each other so they form a full rectangle.
Was just going to suggest that from your post!
Maybe even flipping the side angles around to tie in the rectangle tubes to the vertical flanges too.
post #1020 of 1319 Old 11-05-2013, 03:41 PM
gst95dsm
gst95dsm's Avatar
I was gonna say earlier were all dealing with different things under there, but sharing all of our individual tweaks will help everyone overall. I think that aftermarket cat is a great idea.
gst95dsm is offline
caliper flip , ford 8.8 , indyorv , outboard , tube fenders
Jeep Build: Minty White Country XJ Build GTEIS300 Jeep Builds 34 01-20-2013 11:42 AM
2000 TJ Build - LCG First Time Build japete01 Jeep Builds 82 06-07-2012 10:50 PM
JeepWJ26 Build--Johnny Cash Build JeepWJ26 Jeep Builds 31 01-09-2012 12:15 PM
WeatherWarrior's "you better not call it a build" build thread. WeatherWarrior Jeep Builds 10 12-12-2011 06:31 PM
JeepDVL45's 'Bruiser' Build -- A Daily Driver's slow build JeepDVL45 Jeep Builds 41 08-11-2011 10:44 AM
