Danno's DD TJ Build - Page 55 - JeepForum.com
post #811 of 1319 Old 05-10-2013, 06:27 PM Thread Starter
Danno6102
Originally Posted by Kodiak17
Put me on the list for that HP30.
Unfortunately it's still the LP. But I'll put you at the top of the list if still interested.
"Evolution through carnage, the Jeep will keep what it needs."
Danno6102 is offline
post #812 of 1319 Old 05-10-2013, 06:44 PM
Kodiak17
I'm still in it for the 4.88's
Maintain, wheel, upgrade, repeat.
My build: http://www.jeepforum.com/forum/f22/thor-dd-weekend-warrior-1348534/
Kodiak17 is offline
post #813 of 1319 Old 05-10-2013, 07:48 PM
MO2500
Not to take away from Danno, but if your interested I've got a D30, D35, and 4 linked D44, all with 4.88s, all taking up space in my tiny garage
Instagram: @omsmike
MO2500 is offline
post #814 of 1319 Old 05-10-2013, 07:58 PM
Kodiak17
I'll definitely keep that in mind. The rear end is taken care of. Just looking for some geared HP30'S now.
Kodiak17 is offline
post #815 of 1319 Old 05-11-2013, 07:41 AM Thread Starter
Danno6102
Unit bearings done. Wobble still there. On to the ball joints.
post #816 of 1319 Old 05-11-2013, 12:14 PM Thread Starter
Danno6102
Ball joints done. Driver side bottom was shot. Wobble still there. **** me!!! I feel like a damn retard that I can't figure this out.
Going to try swapping tires around again after my daughter's gymnastics show. Maybe it is a tire wobble.
post #817 of 1319 Old 05-11-2013, 12:32 PM
Kodiak17
I replaced balljoints, TRE's, trackbar bushing, and tires road force balanced. Still have vibes and wobbles. I feel your pain
Kodiak17 is offline
post #818 of 1319 Old 05-11-2013, 03:40 PM
boilerup1998
How bad is the wobble? Is it possible that it's just a "normal" amount for your set-up?
boilerup1998 is offline
post #819 of 1319 Old 05-11-2013, 04:14 PM Thread Starter
Danno6102
It's not too bad now, but annoyingly more than I want.
Got the shroud lowered & the engine skid on & tire rotated. Going to take her for a spin to get some longer bolts for my bandaid rear shock fix.
post #820 of 1319 Old 05-11-2013, 06:47 PM
MO2500
Depends on what you consider to be "normal" or "acceptable." To me, any wobble, shimmy, shake, vibration, ect. is not "normal".
I bet it's tire/wheel related Danno. You have been through just about everything else.
Instagram: @omsmike
MO2500 is offline
post #821 of 1319 Old 05-11-2013, 07:44 PM Thread Starter
Danno6102
I retract my previous statement that its livable. It's just so temperamental. Drove it 15 miles to get bolts. Wobbled pretty good between 50-60 on the way there. On the way back there was hardly a wobble the first half, then suddenly wobbled like it did on the way there. I'm sort of wondering if its a syncing thing between wheels. Like when the balance gets clocked just right to each other they start wobbling. I know none of then are balanced perfect, close, but not perfect.
It was worse after rotating the tires, so I guess I'll switch them back. The thing that throws me is that NOTHING has changed with steering or suspension. All this started after I did the body lift, flat belly & installed the chromo front axles I got from John (boilerup). Which have very few miles on them.
post #822 of 1319 Old 05-11-2013, 07:57 PM
yellow_snocone
I had my DW pop back up after doing a BL and MML as well. It ended up being my tackbar frame side mount. I dont know how they ran into each other but it happened no the less.
Military Jeepers
S.W. New Mexico region
yellow_snocone is offline
post #823 of 1319 Old 05-11-2013, 09:16 PM Thread Starter
Danno6102
What exactly was the issue with the mount? I'm running the currie HD track bar with the big *** bolt that had to have the mount drilled out. It's "blow out your butthole" tight.
post #824 of 1319 Old 05-11-2013, 10:01 PM
Imped
Imped's Avatar
Dan, I'm free in the afternoon tomorrow. Let me know if you can make it over.
OlllllllO
IndyORV
Imped is offline
post #825 of 1319 Old 05-11-2013, 10:02 PM
adamsobi
How are the joints on your control arms? I went though the full gambit with death wobble and my lower control arm bushings were worn, replaced them smooth as can be.
2004 Rubicon
adamsobi is offline
caliper flip , ford 8.8 , indyorv , outboard , tube fenders
JeepWJ26 Build--Johnny Cash Build JeepWJ26 Jeep Builds 31 01-09-2012 11:15 AM
