dana 300/np231 swap - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > dana 300/np231 swap
Jeep Wrangler Bushwacker Flat Fender Flare Sale at BaselinJeep Brake Parts | Zone OffroadSpartan Locker Promo Running now @ ROCKRIDGE 4WD plus FREE
Unread 02-25-2015, 07:21 PM   #1
helpme3342
dana 300/np231 swap
Hello, in need of help. I bought a in line 6 w/automatic transmission and dana 300 transfer case. my front axle is a driver side drop and the 300 is for passenger side. Can I put a np231 on it and roll with that. This is a new hobby for me. Need all the help I can get. Thanks in advance
helpme3342 is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 02:45 PM   #2
dayriesw
dayriesw's Avatar
Yes you should be able to swap to a 231 but the shifter linkage will need to be sorted out. There is cable shifters out there that should correct this. The 300 and 231 have the same bolt pattern which is why you swap them out, but you can also clock a 300 (rotate 180 degree) and run that as a driver drop case. The shifter will have to be corrected and you will have to plug the vent and add another vent in another location. There are threads on this around if you look hard enough. Good luck.
Two jeeps, neither like to work.
dayriesw is online now   Reply With Quote Quick reply to this message
