DaddyJeep 121 day 87 YJ 5.2 LCG 4 link build - Page 7 - JeepForum.com
post #91 of 187 Old 01-23-2014, 08:11 PM Thread Starter
daddyjeep87
1987 YJ Wrangler
Got all the welding done on the bumper tonight. I just need to drill a few holes to mount it and get some paint on it.
Inside view of the D-ring mount welded. The welds look pretty good I think. I just couldn't clean them up very good with the wire brush for the pic. Damn flux core wire is messy.
Back to the radiator... I am thinking I am just going to leave the shroud alone and mount the fan as a pusher. I won't have to worry about clearance that way.
87YJ 5.2/46RH/NP231 D44/9in 4.56 4 link rear, radius arm front
My Build
Start planning for 2014, updated site http://www.bantamjeepfestival.com/
daddyjeep87 is offline
post #92 of 187 Old 01-25-2014, 09:38 PM Thread Starter
daddyjeep87
1987 YJ Wrangler
Painted pics of the bumper.
Duplicolor Self Etching Primer.
Duplicolor Bed Armor
I will get it installed and get the winch permanently mounted tomorrow.
My Build
post #93 of 187 Old 01-25-2014, 10:58 PM
The_Goob
Hell on Wheels
The_Goob's Avatar
Finally got a chance to read up. This thing is going to be a beast!
YJoTM ~April '14 ~June '15 ~April '17
The_Goob is offline
post #94 of 187 Old 01-26-2014, 07:25 PM Thread Starter
daddyjeep87
1987 YJ Wrangler
Thanks Goob. I hope so. This is the Jeep I have wanted to build since I was a little kid.
Got the bumper in place tonight and the winch mounted. The wife thinks i need to paint my shackles green to match the motor and diff cover. I think I will wait until if is over 10 degrees to do that, any opinions?
I also pulled the radiator and got my fan mounted as a pusher.
My Build
post #95 of 187 Old 01-27-2014, 07:21 AM
mike_breaker_5
may want to mesh the backside of your grill with an electric pusher fan. there are lots of things in the woods and mud holes up here that would wreck an e-fan in no time.
Ratmonkey donation page. all proceeds will go to his family.
it's not much to look at... but it's mine.
5.2lswap, metalcloaks, bedliner, tucked belly, d60's, soon to be nv4500 and d300.
mike_breaker_5 is offline
post #96 of 187 Old 01-27-2014, 10:26 AM Thread Starter
daddyjeep87
1987 YJ Wrangler
Yes Mike, I was thinking the same thing. Not sure what to use yet, but I will get to it at some point.
My Build
post #97 of 187 Old 01-27-2014, 12:42 PM
The_Goob
Hell on Wheels
The_Goob's Avatar
I would wait on the paint Need to repaint my shackles too, I was so excited(and hurried) to get them on, I didnt bother to clean or rough them up before I shot some paint+primer in 1 on them and slapped em on. They are peeling bad
The_Goob is offline
post #98 of 187 Old 01-27-2014, 12:50 PM
skyj
The reason your paints not sticking and peeling off is because they've been dipped galvanized. I've heard lots of guys say that plasti-dip works pretty good.
build thread:
skyj is offline
post #99 of 187 Old 01-27-2014, 12:53 PM
The_Goob
Hell on Wheels
The_Goob's Avatar
Maybe so, they were from BESRK. But I was in a hurry to get wheelin and didnt prep at all
The_Goob is offline
post #100 of 187 Old 01-27-2014, 01:17 PM
skyj
Oh I thougt you meant d ring shackles on his bumper. Opps my fault, yea eddys are just steel.
build thread:
skyj is offline
post #101 of 187 Old 01-27-2014, 01:23 PM
The_Goob
Hell on Wheels
The_Goob's Avatar
Im sure that's what he meant but I had a brain fart and thought of mah spring shackles.
/end thread hijack
The_Goob is offline
post #102 of 187 Old 01-27-2014, 03:36 PM Thread Starter
daddyjeep87
1987 YJ Wrangler
Yep, I meant d ring shackles. I no longer have spring shackles.
My Build
post #103 of 187 Old 03-02-2014, 08:48 PM Thread Starter
daddyjeep87
1987 YJ Wrangler
Got the Jeep moved to the new shop today. Hopefully in the next couple weeks I can get back to work on it.
Leaving the tiny old shop.
Arriving at the new shop.
Kinda gets lost in the new shop. Sorry, am I gloating? Maybe a little.
My Build
post #104 of 187 Old 04-30-2014, 09:21 PM Thread Starter
daddyjeep87
1987 YJ Wrangler
Finally got to spend a couples hours in the shop. I even worked on the Jeep. Got the 9in pulled and cut off a bit of the truss and the crappy old mounts. Tomorrow I hope to get it cleaned up and the new Ballistic Fab mounts burned in.
My Build
post #105 of 187 Old 04-30-2014, 09:44 PM Thread Starter
daddyjeep87
1987 YJ Wrangler
Finally got to spend a couple hours in the shop. I even got to work on the Jeep. I pulled the 9 in and cut off part of the truss and the crappy old upper link mounts. Hopefully tomorrow I can get the new Ballistic Fabrication mounts burned and get the axle back in.
My Build
