DaddyJeep 121 day 87 YJ 5.2 LCG 4 link build - Page 4 - JeepForum.com
post #46 of 187 Old 11-21-2013, 11:22 AM Thread Starter
daddyjeep87
1987 YJ Wrangler
Thanks for looking out for me. I think I can just barely fit the mechanical fan, but I plan on running electric anyway and was also thinking something along the lines of what Mike did if necessary. There is a lot of excess space inside the grill if I need to get radiator that will tuck inside.
Mike, You are running the stock 4.0 radiator? does it cool ok with the 5.2?
daddyjeep87 is offline
post #47 of 187 Old 11-21-2013, 11:38 AM
mike_breaker_5
i'm actually using a stock aluminum radiator from a '99 2.5L TJ.
in the dead of summer, the only time the fan is needed is if i'm not moving or driving slowly around town. other than that the t-stat does all the work. when the fan is needed it cools the motor quite fast. so quick in fact that my temp will dip below 160 at times before the t-stat has a chance to close up.
Ratmonkey donation page. all proceeds will go to his family.
it's not much to look at... but it's mine.
5.2lswap, metalcloaks, bedliner, tucked belly, d60's, soon to be nv4500 and d300.
mike_breaker_5 is offline
post #48 of 187 Old 11-21-2013, 11:43 AM Thread Starter
daddyjeep87
1987 YJ Wrangler
I wish I would have grabbed the radiator out of that parts Jeep I used to have. My 4.2 radiator has seen better days.
87YJ 5.2/46RH/NP231 D44/9in 4.56 4 link rear, radius arm front
My Build
Start planning for 2014, updated site http://www.bantamjeepfestival.com/
post #49 of 187 Old 11-21-2013, 11:50 AM
freaknajeep
1971 DJ
man I thought your motor was quite sexy all green and black....then you bolted all that stuff on it...now you cant even see it...yep you need more paint...lol....I didn't notice your ballistic fab skocks in any of the new pics I was looking forward to seeing them...and as far as the wiring goes you are a braver man than I...I have a carb, a 1 wire gm alternator, a gm style hei distributor, and mechanical gauges on every vehicle I own....only need 5 wires and a fuel line...lol...well you know what I mean...I cant wait to see what comes next keep up the awesome work and get to painting up those accessories...lol
Be carefull while Hugging the Trees...They leave dents on your Jeep....
Shhhhhh I'm not crazy...It's just the voices in my head
freaknajeep is offline
post #50 of 187 Old 11-21-2013, 04:30 PM Thread Starter
daddyjeep87
1987 YJ Wrangler
I thought about painting the accessories, but then I reminded myself that I am not building this to look nice. It is build to perform. I have plenty of more important things to do than spend time painting. Sorry to disappoint you.
My Build
post #51 of 187 Old 11-21-2013, 09:58 PM Thread Starter
daddyjeep87
1987 YJ Wrangler
Still somewhat confused on my gears. I recounted the teeth and was not completely wrong. I marked each tooth with a sharpie this time so I was absolutely sure. 41 teeth on the ring gear and 9 on the pinion, which equals 4.56. Seems all cut and dry...right? Well, not so much. The gears are clearly marked with the precision gear logo. According to their web site the 4.56 gears for a D44 have 50-11 teeth and the 4.56 gears for the D30 have 41-9. Can a D30 Gear set be installed in a D44? What other explanation could there be?
Here is a full pic of my front axle.
My Build
post #52 of 187 Old 11-22-2013, 12:48 AM
mike_breaker_5
measure the ring gear. D30 is 7.20" and a D44 is 8.5". that should tell you what ring gear you have.
post #53 of 187 Old 11-23-2013, 12:54 AM Thread Starter
daddyjeep87
1987 YJ Wrangler
So I measured the ring gear diameter and it measure right around 8.5", or the best I could tell while still in the axle. So they are definately D44 gears. Not sure why the tooth count does not match the precision gear web site, but I am moving on and just be happy that I found a LSD and 4.56 gears in my axles. Not what I was expecting when buying axles off of a scrapped vehicle.
Did some more wiring tonight. Got a bunch of un-needed wires out of there. All ABS stuff is gone and the head light stuff. I will be running the lights off of the YJ harness. Made a lot of progress tonight. Hopefully some time in the near future we can hear this beast roar.
My Build
post #54 of 187 Old 11-24-2013, 09:55 PM Thread Starter
daddyjeep87
1987 YJ Wrangler
I know it is not on the engine, but I added a little color to the front Axle.
Weeded out a few more wires this weekend.
A few more circuits to trace and I will be ready to start connecting the new to the old.
My Build
post #55 of 187 Old 12-06-2013, 10:06 PM Thread Starter
daddyjeep87
1987 YJ Wrangler
Got a little work done on the YJ side of the wiring and mounted the PCM to the fire wall. I know there is some debate on the location I chose, but it just fits there too well. I also temporarily mounted the PDC on the stock battery tray. I will either weld it or bolt it there once I button things up.
My Build
post #56 of 187 Old 12-21-2013, 11:01 PM Thread Starter
daddyjeep87
1987 YJ Wrangler
Finally got back at the Jeep tonight. I think the Grand Cherokee side of the wiring was easier because there are better schematics. I can't find a really good schematic that identifies the circuits and ties them into the bulkhead pin out. I have three red wires from the bulkhead labeled battery. I am not sure where to tie them into the GC wiring. Any insight would be appreciated.
My Build
post #57 of 187 Old 12-21-2013, 11:33 PM
skyj
I wished I knew im getting really confused with my wiring. I have a dodge truck computer and a cherokee harness minus the pdc so I will be looking for one at a upull soon.
build thread:
skyj is offline
post #58 of 187 Old 12-22-2013, 07:51 AM
mike_breaker_5
i have the chilton for the yj and haynes for the GC. i can drop them off to you before i go to work tuesday afternoon if you think they will help.
post #59 of 187 Old 12-22-2013, 08:49 AM Thread Starter
daddyjeep87
1987 YJ Wrangler
Mike, it is worth a look. I have an old Haynes which isn't any more help. I am off Tuesday so any time.
My Build
post #60 of 187 Old 12-22-2013, 09:13 AM
mike_breaker_5
sometime around 2:30 should be when i arrive. there are some highlighted circuits in the YJ manual i think. it was for when i was rewiring the lights and what not.
