Quantcast Custom 2001 Jeep Wrangler Military Project - Page 6 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Custom 2001 Jeep Wrangler Military Project
Old 08-03-2008, 09:35 PM   #76
tatooweeny
I'm working on bridge plates for it as well as mounting side handles to the body. I've decided for now to keep the rear CJ style fenders off, and will begin mounting various footman loops around the vehicle. -jake
tatooweeny is offline   Reply With Quote
Old 08-03-2008, 11:31 PM   #77
tatooweeny
Pictures for sceptical people
Here's some pics of the tailgate with jerry can mount...
Here it is closed...
And opened! The jerry can mount does not interfere with the door handle, but I do have to unlatch the jerry can from mount to lock/unlock door. No big deal, really. I was in the process of rigging something up to lock/unlock from inside the jeep when I decided on the soft top. Now I just roll up the back of top when I need to get to something, so all that work on the door was in vain. For now, I'll just keep it locked. But in the not too distant future, I'll probably remove the hinges, locking mechanism, & handle, weld the door the the body to strengthen the back, and mount the jerry can directly to the body. I also plan on fabricating a pintle hitch mount and the current setup won't work because the spare tire needs to be over to the left (passenger) side & mounted higher to clear the hitch.. It will be a high mounted hitch (1-2 inches up into body line), and it will take a lot of modifying to the rear cross member as well. And I still have to mount the shovel and ax to the sides, modify a split window (M38 style) to fit (weld) into the TJ windshield frame, rework the wipers, and mount a gas tank (inside body) above frame. Then I have to fill all the holes (including gas door) in the body, as well as all the mods inside!
Heres the view from the side of vehicle. That plate on the body directly behind the jerry can mounts was the original location for the tail lights. I put a directional spot light opposite side hooked up to backup light wiring Needless to say, people know when I'm backing up now and the view is great! -jake
Old 08-03-2008, 11:33 PM   #78
RockRodHooligan
Under Construction
RockRodHooligan's Avatar
1989 MJ Comanche
click free, sweet rig man, I'd love to do this to a TJ!
Penis inches...
Good god man. Indyorv :rofl: d**k and fart jokes. :rofl:
I seen a frog once that ate a rolypoly that locked onto it's tongue and I rescued it from starvation by removing the rolypoly.
RockRodHooligan is offline   Reply With Quote
Old 08-05-2008, 10:05 PM   #79
NJblackdeath4x4
seriously thats the baddest tj ive ever seen in my life....you are a talented individual
NJblackdeath4x4 is offline   Reply With Quote
Old 08-06-2008, 03:55 PM   #80
JeepinMass
JeepinMass's Avatar
very nice theme built Jeep. You should be proud.
--Ben--
74CJ5 and 08JK
JeepinMass is offline   Reply With Quote
Old 08-06-2008, 10:14 PM   #81
Barrio
have you taking this to any jeep show or anything? That is award winning no lie
www.offroadjunkies.net
www.pgh-offroad.com
-OD Green/Flat Black 92' 4" Rough Country Lift, tons of crap.
-Rio Red 1995 Ford Mustang- Daily Driver
Originally Posted by alfmoney
i see theres a bunch of toughguys on this forum or internet gangstas
Barrio is offline   Reply With Quote
Old 08-06-2008, 11:37 PM   #82
Roknut
I have to agree, that's the most awesome looking Jeep ever
Roknut is offline   Reply With Quote
Old 08-08-2008, 07:01 PM   #83
WillysEdition04
Amazing work. Especially with that ragtop. Kinda makes my willys edition TJ look like a joke!
04 TJ Willys Edition 41MB-04TJ #4913
The WILLYS Edition Owners Group
Your post count does not represent your knowledge, it represents your use of free time.
WillysEdition04 is offline   Reply With Quote
Old 08-11-2008, 01:52 PM   #84
zeke6785
4wd Sales Rep
zeke6785's Avatar
wow from the back that looks almost like an old MB that looks great
Black 98 Bone Stock TJ
Black Jeep Society
http://www.jeepforum.com/forum/f9/tj-tech-boot-camp-must-read-new-tj-owners-forum-members-722109]TJ Boot Camp
The worlds only '96 wrangler is whats in Area 51
zeke6785 is offline   Reply With Quote
Old 08-11-2008, 01:57 PM   #85
Camo Deere
The detail you put into this is incredible. Great work.
Camo Deere is offline   Reply With Quote
Old 08-12-2008, 07:24 PM   #86
WillysEdition04
The next logical step... lose the roll bar.
A member on this forum actually made his roll bar removable. He posted a pic of it in my thread about my project...
http://www.jeepforum.com/forum/f9/2004-willys-pkg-theme-mods-509189/
that thread might help inspire you with some other ideas as well. I got some pretty good responses when asking for ideas and inspiration.
Old 08-15-2008, 02:27 AM   #87
tatooweeny
The only problem with losing the roll bar is that if you roll the jeep, you lose your head!
Old 08-15-2008, 11:35 AM   #88
WillysEdition04
Not a risk you're willing to take, huh? ...and I thought you were committed.
Old 08-18-2008, 02:43 AM   #89
tatooweeny
More pics
Hello all! another update...
It's HOT in Sacramento, so I decided to take off the side curtains and doors.
I also pushed back the middle bow with a couple of grommets on the side rails to pull the canvas tight & keep the top from "sailing" in the wind.
Still has a problem with high speed though, I'm thinking of adding some kind of removable bow that gives the mid section a little more tension when driving on freeways. Anyone try the Genuine Zuse cover bow? Any other suggestions?
Here's one of the tool boxes I mounted on the rear wheel well (driver's side). It's the smaller of the two...
And here is the passenger side, slightly taller....
These 2 tool boxes will eventually have locks, and will hold my tools and recovery gear. I will also add a brace/frame around the bottom later on when I add the oil canister mount, the first aid box, and the 5 gallon water can. Their low profiles and slightly angular tops has a military look to them. They were purchased at Ace Hardware for something like 16-18 bucks each. At home, I grinded the handle rivits off, and added plastic buttons to fill the holes.Then prepped and painted. The whole thing only took a couple hours, and they turned out nice. I know they are not the most sturdy or secure, but I don't carry any expensive tools, so it'll do. Check back in a week, I'll have more stuff to show! -jeyk
Old 08-20-2008, 11:16 PM   #90
0utback
Excellent continuation. I'm really enjoying your build. How did you attach the tool boxes? Interior pics?
'05 Khaki Rubicon Recce Edition
'93 M101CDN military trailer
Westman Jeep Association
Canadian Jeep Club Mbr #65
You can't be lost if you don't care where you are!
0utback is offline   Reply With Quote
Glock Forum
