| Wild Boar Products Cargo Rack or Front Bumper Giveaway |
| Register | FAQ | Search | Today's Posts | Mark Forums Read | Search Members |
Thread Tools |
| #1 | |||
Registered User | Custom 2001 Jeep Wrangler Military Project
| #2 | ||
Registered User | Quote:
__________________ The apostrophe key does not mean "Look out, here comes an S"! | |
| #3 | |
Registered User | Thats an awesome Jeep! Keep it up, I'm looking forward to more mods ![]() |
| #4 | |
Registered User | Thanks! I only wish I had documented the build up so far. When I get her back from the Upholstery shop, I'll do a couple write ups on some of the stuff I've done. For instance, I fabricated a steel strap that holds/locks the jerry can to the mount so no one can "borrow" gas from me when parked outside. |
| #5 | |
Point it and go. | Thats awesome. Props. __________________ 2001 Patriot Blue xj- It has an aussie. So when I make turns, every new passenger goes "WTF is that?" http://www.jeepforum.com/forum/f22/my-2001-jeep-xj-build-rattletrap-668339/ |
| #6 | |
Registered User | Get some more pictures up too! |
| #7 | |
Registered User | Awesome ! __________________ Black 2003 Sport TJ SOLD... :( Canadian Jeep Club member # 1337 Black Jeep Club member # 1338 Ex Jeep Club member # 1 |
| #8 | |
Senior Member | nicely done!! congrats! __________________ CJ5 Project finally finished... http://www.jeepforum.com/forum/f22/cj5-project-467967/ ------------------------------------------------------------------------ '77 CJ7 -.232 inline 6,T150,4.10s,35" Mudzilla Tires, '79 CJ7- 305,TH400,NP205,4.10s,35" Creepy Crawlers '61 Chevy Apache 10-all stock '90 Chevy K1500 4x4 Truck-LT245/75R16 BFG All terrains |
| #9 | ||
Registered User | Wow, that looks incredible! __________________ Quote:
Green Jeep Club Member #183 | |
| #10 | |
Registered User | Here is some progress... http://farm4.static.flickr.com/3147/2552520166_4df1b4bb0d.jpg?v=0 Here is the bracket for the bow assembly. Since it does not have a recess in the body for the bow, I had to make a spacer for the bracket. It is spot welded together to give it strength. http://farm4.static.flickr.com/3015/2551697881_1b68ec582e.jpg?v=0 The seats are original wrangler front seats, cut down and squared a little to give that old school feel. I did not want to use military seats because I wanted comfort, funtionality with style. I'll continue progress as it happens. Another view of the bow... http://farm4.static.flickr.com/3160/2551847785_7b8312cb5d.jpg?v=0 From the rear you can see the height at which the top will be. The high back was common on military jeeps because the rear seat was mounted on the floor against the tailgate area. When officers sat in the back, their heads didn't touch the top. Eventually, I'll put a rear seat back there. An updated front end... http://farm4.static.flickr.com/3056/2552691832_c43df11a15.jpg?v=0 Here's an updated photo with the front lifting shackles installed with grade 8 hardware. I added a little white so they didn't cover the decals on the bumper. I thought that was a nice touch. These shackles connect to the frame, not the bumper, for added strength. They are rated at 10,000 pounds each, so I should have no problem getting out of mud holes, ditches, etc. Last edited by tatooweeny : 06-04-2008 at 08:40 PM.Reason: more pics & descriptions |
| #11 | |
Registered User | that looks sweet |
| #12 | |
Registered User | Here is the window channel... ![]() Here is a pic of the windshield channel. It will be nearly invisible when finished. The edges of the canvas will have snaps on each side of the window frame. This will keep it centered & tight. Keep in mind that everything metal will be painted Lusterless Olive Drab when complete. The bow to windshield support (front)... ![]() The windshield soft top door seal is from a CJ7 (I believe). The rod just slips into this, & is held in place by the Bow assembly. Bow to windshield support (rear)... ![]() A new hole had to be drilled to keep an even plum line. There were 2 holes drilled near this, so we had to fill those to keep the bow strong. Side curtain drop rod (top)... ![]() This is an interesting photo because it shows what one can do with a little bit of ingenuity! Notice what it is? It's a brass pipe T-bar fitting that's been drilled out to slip the windshield rod through, then connected with a blind rivet. The other rod ( drop rod) just sits inside both top & bottom so I can disassemble everything and store it easily. Side curtain drop rod (bottom)... ![]() This is the bottom of the assembly. The hole was already there in the body, so we just welded a washer to the rod & set it in the hole. The black stuff is a rubber based sealant to keep the rattling to a minimum. |
| #13 | |
Akua Tuta | Your Jeep is bad! Nice work ![]() I like the side view mirrors, plus everything else . |
| #14 | ||
!!!!!__________________ Tennessee, Tennessee, There ain't no place I'd rather be! | |
| #15 | ||
| Thread Tools | |
| Thread | Thread Starter | Jeep Forums | Replies | Last Post |
| My 1990 YJ Wrangler Project | zeke6785 | Jeep Registry | 42 | 10-14-2009 10:19 PM |
| my military style jeep in the snow. | Fflintstone | Jeep Registry | 3 | 03-18-2009 06:15 AM |
| My 2001 Jeep Wrangler Sahara | rb1965 | Jeep Registry | 5 | 12-22-2007 10:24 AM |
| 2001 amberfire jeep wrangler | tj2001 | Jeep Registry | 7 | 12-16-2007 08:23 PM |
| Dan's 2001 Jeep Wrangler Sport 4.0 | OhioDan01 | Jeep Registry | 0 | 05-29-2005 12:16 PM |
Previous Thread
Next Thread
