cuder's 4.25" Zone combo lift - Page 7 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > cuder's 4.25" Zone combo lift
Only 2 Days left to win $3,800 Jeep Parts!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineAttention seahawks fans!!! Want to save some $$$ ??!!
Unread 10-10-2013, 08:38 PM   #91
Cuder
The body mount bolts above the fuel tank were the worst, but I live in a pretty dry area. You will like the ride.
My Build Thread:
http://www.jeepforum.com/forum/f22/c...-lift-1268317/
Cuder is offline   Reply With Quote Quick reply to this message
Unread 10-10-2013, 08:46 PM   #92
freaknajeep
1971 DJ
how much did you have to thin the monstaliner in order to spray it?..or is it a different kit?
Be carefull while Hugging the Trees...They leave dents on your Jeep....
Shhhhhh I'm not crazy...It's just the voices in my head
freaknajeep is offline   Reply With Quote Quick reply to this message
Unread 10-10-2013, 09:05 PM   #93
Cuder
I'm a painter, but didn't want to have the overspray on the walls of the garage, so I rolled it on. It's the same coating to spray, but you thin it with MEK.
My Build Thread:
Unread 11-01-2013, 12:04 AM   #94
BABrax
Originally Posted by Cuder View Post
I wipe them down first with MEK, then I use a die grinder with a med grit sanding disc to roughen them some. Then wipe them again with MEK or Acetone. I hung them with coat hangers from the roller rails of my garage doors, I also use twine to make them hang level.
When you spray the bedliner hold the can around a foot away and spray it on in 3-4 light coats. As I said before have a fan ready to blow air on it between coats, especially with the humidity we have now.
How did you handle overspray? just let it fall on the floor or tape off an area for it?
BABrax is offline   Reply With Quote Quick reply to this message
Unread 11-01-2013, 08:58 AM   #95
Cuder
I use a painters drop cloth, but I'm not too worried about getting anything on my garage floor. You can see the floor in the pictures above, it's stained from the water heater leaking before I bought the house.
My Build Thread:
Unread 11-17-2013, 04:13 PM   #96
TheJareDr
Hey Cuder,
Love your build. How much lift did you get from the 3 inch springs when you installed the springs? Did you lose any of that height with the addition of the front bumper and winch? Also wondering how level your jeep sat/sits on flat ground.
Thanks!
TheJareDr is offline   Reply With Quote Quick reply to this message
Unread 11-17-2013, 09:45 PM   #97
Cuder
Thanks!!! It was 3" after they settled. The bumper and winch set it about 1/2" lower, I could probably use some spacers up front.
My Build Thread:
Unread 01-02-2014, 09:29 AM   #98
Cuder
I bought the JCR sliders while they were on sale for black Friday. I finally got around to coating them with the Duplicolor Armor bedliner yesterday.
Self eitching primer
While they were still wet.
My Build Thread:
Unread 01-02-2014, 05:20 PM   #99
Cuder
I installed the sliders today and also got Bestop seat covers last week.
My Build Thread:
Unread 01-02-2014, 06:21 PM   #100
Cavasar
No Longer DD
Cavasar's Avatar
Lookin good
Cavasar's TJ
Cavasar is offline   Reply With Quote Quick reply to this message
Unread 01-12-2014, 09:05 AM   #101
Cuder
Thanks Steven!!
I wanted front floor liners, but I also wanted a M.O.R.E. dead pedal. So, I just put it on top of the liner and used one long sheet metal screw on the bottom. It's sturdy enough with 3 screws and I will only have to take the bottom one out to wash the liner.
My Build Thread:
Unread 01-26-2014, 07:21 PM   #102
Cuder
I took my daughters to Northwest OHV park in Bridgeport today. It was great top down. We tried out a natural RTI ramp and found a few mud holes.
My Build Thread:
Unread 02-14-2014, 09:57 PM   #103
Cuder
I bought an 8.8 today. The start of running 35's.
My Build Thread:
Unread 02-14-2014, 11:21 PM   #104
Cavasar
No Longer DD
Cavasar's Avatar
Get a jy axle or is it ready to bolt in?
Cavasar's TJ
Unread 02-15-2014, 08:24 AM   #105
Cuder
Yes, going to build it with the Artec truss brackets. I have a friend that drag races that is going to help me do the gears and another friend that is going to weld it up for me.
My Build Thread:
