cuder's 4.25" Zone combo lift - Page 6 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > cuder's 4.25" Zone combo lift
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LinePoison Spyder JK Body Mounted Tire CarrierBaseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft Ki
Unread 05-04-2013, 10:03 PM   #76
Cuder
Taking the shaft out.
2001 ignition switch on top, 2000 on bottom.
2000 without tilt.
2001 with tilt.
My Build Thread:
http://www.jeepforum.com/forum/f22/c...-lift-1268317/
Cuder is online now   Reply With Quote Quick reply to this message
Unread 05-04-2013, 10:09 PM   #77
Cuder
Here is the multifuction switches for the wipers. The 2001 on top with intermitent wiper. And the 2000 W/O intermitent wipers on bottom.
My Build Thread:
Unread 05-11-2013, 09:48 PM   #78
Cuder
I rolled the Monstaliner today after work. I have worked with alot of different coatings over the years and I can say this is some good ****.
After a few days I will put everything back in. Then finish the steering column/cruise control install. I bought a intermittent wiper switch from a wrecking yard also to install.
My Build Thread:
Unread 05-14-2013, 12:16 AM   #79
Cavasar
No Longer DD
Cavasar's Avatar
Looks pretty good man, I just took the seats out of mine in prep for my Monstaliner. Are you heading to the Coyote drive-in?
Cavasar's TJ
Cavasar is offline   Reply With Quote Quick reply to this message
Unread 05-14-2013, 06:42 AM   #80
Cuder
Thanks. I won't do another Jeep in MY garage. My house still smells and it's almost been 3 days. I couldn't put it outside because I had no steering wheel.
I don't know yet about going with the club to the drive-in.
My Build Thread:
Unread 06-10-2013, 03:05 PM   #81
Boog
Jeep looks good. How do you like those Falkens?
Currie, MetalCloak, Bilstien, MB, Goodyear
USAF Heavy Equipment Operator
Air Force Jeep Club #147
My build thread: http://www.jeepforum.com/forum/f22/boogs-slow-tj-build-1469852/
Boog is offline   Reply With Quote Quick reply to this message
Unread 06-10-2013, 09:56 PM   #82
Cuder
Thanks alot. I like them, great on and off road, also quite.
My Build Thread:
Unread 06-14-2013, 10:05 PM   #83
Cuder
I coated a buddy's new JCR bumper for him.
He then asked me if I wanted some Hella Vision Plus headlights that he had bought and didn't like because he didn't like how flat they were. The headlights in my Jeep were'nt the same brand and put off different beams. So, I got these for the labor of coating his bumper.
http://www.jeepforum.com/forum/f217/...ersion-770540/
These are alot better than sealed headlights.
My Build Thread:
Unread 06-17-2013, 10:24 PM   #84
Cavasar
No Longer DD
Cavasar's Avatar
So how do you go about prepping for paint and how do you paint them? Do you have them hanging from something? After my fenders come in and I fit em I'll be ready to spray with self etching primer and bedliner.
Cavasar's TJ
Unread 06-18-2013, 12:25 PM   #85
Cuder
I wipe them down first with MEK, then I use a die grinder with a med grit sanding disc to roughen them some. Then wipe them again with MEK or Acetone. I hung them with coat hangers from the roller rails of my garage doors, I also use twine to make them hang level.
When you spray the bedliner hold the can around a foot away and spray it on in 3-4 light coats. As I said before have a fan ready to blow air on it between coats, especially with the humidity we have now.
My Build Thread:
Unread 07-03-2013, 10:33 PM   #86
gst95dsm
Chop, Wheel and Rebuild..
gst95dsm's Avatar
That red liner came out great man!
My Build Thread
gst95dsm is offline   Reply With Quote Quick reply to this message
Unread 07-04-2013, 07:22 PM   #87
Cuder
Thanks!!!, it's a great coating, I will probably someday spray the whole Jeep with it.
My Build Thread:
Unread 07-06-2013, 09:51 PM   #88
Cuder
I used my winch for the first time today. I had a leak way under ground on one of the sprinkler heads in the front yard. The dummies that poured the driveway had left a big cement block on top of where the leak was. The leak was caused by a big root from the tree in the yard, but I couldn't get to it.
My Build Thread:
Unread 07-09-2013, 05:20 PM   #89
gst95dsm
gst95dsm's Avatar
Nice work! I hate messing with sprinklers! That's a healthy root.
My Build Thread
Unread 10-07-2013, 09:25 AM   #90
j0e
Hey OP,
I'll finally be installing my Zone 4.25" this coming Friday. Which bolts did you have most trouble with? I'm going to start spraying bolts with PB Blaster every day until then.
Thanks a ton for any tips.
j0e is offline   Reply With Quote Quick reply to this message
