creating timeline - jeep build - JeepForum.com
post #1 of 5 Old 01-27-2016, 12:41 AM Thread Starter
willc86
hey guys its that moment where my jeep is almost repaired fully. few things missing. then, I am going to start a long line of upgrades. my ultimate goals would be to have a stroker engine, coil over shocks, exo skeleton, drive-terrain change...ill list all of the price all of the details... in the long run....might be 3 - 4 years before that happens but I want to start documenting everything and start off small. As I progress, I will upgrade and change parts. I also plan on adding bumpers, repainting suspension parts and body, fixing the dents, adding winch etc.... I do have the income to do so but I also have a house I need to remodel at the same time ha ha and I believe house takes priority.
I am also here to ask for help and guidelines! maybe a newbie can also see this post as a guide one day. I just want to be helpful to the community since you guys helped me. Maybe I can give something back
anyhow....my first (small project) I am going to buy a cheap lift kit (6.5 in) from amazon. Now, I am going to ask for some help.
to get a decent amount of flex, should I get disconnect sway links? (if i called them right) down the road, Ill probably upgrade to a long arm kit. For now, I am just doing moderate light rock crawling trails.
then next year, see if I can get better suspension lift that adds more flex. but for now ill get a cheap lift in amazon.
my current jeep now
which is stock..ill post after photos soon
next year when i get more advanced in rock crawling ill consider this https://waldoch.com/store/performanc...erokee-xj.html
willc86 is offline
post #2 of 5 Old 01-28-2016, 08:54 AM
chris87xj
JF Admin
chris87xj's Avatar
1987 XJ Cherokee
Hello and welcome to the forum Will. I run those same wheels on my 96XJ.
6.5" is a lot of lift for an XJ and I'm not sure there's a good way to do it cheap. That BDS kit you linked is pretty sweet though. For sure you're going to want disco swaybar links for offroading and with any significant lift you're going to need to replace the stock ones anyway.
XJ body styles didn't change a whole lot of the years so I'm not exactly sure what year model you're working with. When you get a minute, fill in your profile information and it'll be a big help towards anyone being able to help you in your quest here. I can't wait to see where this goes!
***Chris***
chris87xj is offline
post #3 of 5 Old 01-30-2016, 06:41 AM Thread Starter
willc86
Thanks for response! disco sway bar is the same is quick disconnect sway bar?
so I decided I am going to purchase this for now until I get more advanced
http://www.amazon.com/Rough-Country-...ywords=xj+lift
ill post pictures after I lift it. then tire time! also plan on painting the coils and maybe leaf springs not sure.
anything else I should add?
i have
-disonnect sway links
-new pitman
going to get this for disconnects
http://www.amazon.com/Rough-Country-..._cd_al_qh_dp_t
might paint them as well. ill post final results
willc86 is offline
post #4 of 5 Old 02-01-2016, 12:35 PM
chris87xj
JF Admin
chris87xj's Avatar
1987 XJ Cherokee
Yes disco swaybar links is my shorthand for quick disconnects.
I'm still not exactly sure what year your jeep is but I can tell by the pic that it's a late generation model. At 6.5" you'll need a SYE for sure, but at 4.5" you might be able to get by for a while with a transfer case drop. Late generation models seem to be a bit less tolerable than early gen in that respect.
I'm thinking at 4.5" you won't want a drop pitman but at 6.5 you will.
***Chris***
post #5 of 5 Old 02-02-2016, 11:39 PM Thread Starter
willc86
oh its a 1998 XJ cherokee sport i6 model. Yeah I might stick to a 4.5 then when I get more advanced ill go with a long arm kit.
anyhow, what is a SYE?
willc86 is offline
