Cosmo LJ - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Cosmo LJ
Savvy/Currie Aluminum Control ArmsIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineAlloy usa heavy duty ball joint kits
Unread 07-05-2013, 10:48 PM   #1
Gunkel
Gunkel's Avatar
Cosmo LJ
I had been searching iaai and copart for a couple of months before finding another LJ. Picked this one up in late February and built it with my soon to be driving 15yo daughter Christina. 2006 LJ, hit Left front and down, frame bent, transfer case was cracked, and the motor mount bosses were sheared off the driver side. Jeep had 41k on the odometer and I picked it up for $4500ish. The Day we brought her home:
aaa-perris-02-15-13-045-4-.jpg   aaa-perris-02-15-13-046-4-.jpg   aaa-perris-02-15-13-048-4-.jpg   aaa-perris-02-15-13-053-4-.jpg   aaa-perris-02-15-13-061-4-.jpg
aaa-perris-02-15-13-067-4-.jpg   aaa-perris-02-15-13-068-4-.jpg   aaa-perris-02-15-13-070-4-.jpg   aaa-perris-02-15-13-072-4-.jpg   img_3329.jpg
06' LJ, stock, except for a few more items...
Fireproof...jeep build thread
Cosmo Blue LJ...jeep build thread
Gunkel is offline   Reply With Quote Quick reply to this message
Unread 07-05-2013, 11:03 PM   #2
Gunkel
Gunkel's Avatar
We came up with a plan together and she picked Cosmo blue for the color, first order of business was to strip the front end, and put my old 35 under it so that we could move it around:
Unread 07-05-2013, 11:15 PM   #3
Gunkel
Gunkel's Avatar
Got the front end stripped, jeep loaded on the trailer, dropped off at Acaros frame shop, and then we started stripping down the door and fenders....
Unread 07-05-2013, 11:22 PM   #4
Gunkel
Gunkel's Avatar
Got the jeep back from the frame shop, made a new motor mount bracket, then started stripping the body...
Unread 07-05-2013, 11:35 PM   #5
Gunkel
Gunkel's Avatar
More work on the body: windshield removal, rear end stripped, etc.
Unread 07-05-2013, 11:43 PM   #6
Gunkel
Gunkel's Avatar
Wheel lip moldings removed, body mount bolts removed, transfer-case linkage removed, and off with the body!
Unread 07-06-2013, 12:00 AM   #7
Gunkel
Gunkel's Avatar
Body sanded, interior scuffed and prepped for the Raptor liner, and pushed into the booth...
Unread 07-06-2013, 12:06 AM   #8
Gunkel
Gunkel's Avatar
Body masked off, Christina sprayed on the blue tinted Raptor liner, baked in the oven, then un-tapped the body...
Unread 07-06-2013, 12:12 AM   #9
Gunkel
Gunkel's Avatar
While we were working on the body we prepped the small parts, back sides of everything, and my old 15" spyderlock rings were primed, sanded and painted...
Unread 07-06-2013, 12:17 AM   #10
Gunkel
Gunkel's Avatar
Body sanded, painted, cleared, and baked in the oven....
Unread 07-06-2013, 12:20 AM   #11
Gunkel
Gunkel's Avatar
Small parts flipped, primed, sanded, painted, and baked in the oven...
Unread 07-06-2013, 12:24 AM   #12
Gunkel
Gunkel's Avatar
Body mounted...
Unread 07-06-2013, 12:30 AM   #13
Gunkel
Gunkel's Avatar
Re-assembly process begins...
Unread 07-06-2013, 12:35 AM   #14
Gunkel
Gunkel's Avatar
More re-assemby including the Rubicon oem flares...
Unread 07-06-2013, 12:40 AM   #15
Gunkel
Gunkel's Avatar
PSC Ricochet rockers (old Helldorados) arrived, prepped, painted, and installed...
2006 , cosmo blue , currie , lj , savvy
