cobrajet94's YJ build - Page 4 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > cobrajet94's YJ build
1987-2016 Wrangler Jammock Black 2.0 Jeep Hammock (YJ, TJ Rancho rockGEAR promotion gear from January 1-February 29,Zone Offroad Body and Suspension Lift Kits, Brackets, Disc
Unread 05-12-2014, 09:04 PM   #46
Louie4
Sounds like an idea worth entertaining.
Don't forget to update your profile to show the new 9's.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4's YJ Build
Poison Spyder Fender Install
Warn M8000 Rebuild Adventure
University of Georgia
Louie4 is online now   Reply With Quote Quick reply to this message
Unread 05-13-2014, 08:38 AM   #47
Cobrajet94
done
1948 cj2a
1992 YJ build thread- http://www.jeepforum.com/forum/f22/cobrajet94s-yj-build-2313233/
Cobrajet94 is offline   Reply With Quote Quick reply to this message
Unread 05-13-2014, 08:41 AM   #48
Cobrajet94
Originally Posted by warthog312 View Post
Perhaps a 2"-3" stretch is in your future. The ZF5 is an awesome trans, I was looking at them myself but decided on the NP435, which is very short when compared to others and left me with the more rear driveshaft length. If you have the fab skills and facility to get those axles in and set up so quickly, a stretch shouldn't pose much of a challenge to you. All I've heard is that the extra wheelbase makes wheeling significantly better, and with your already wider track width, you should have a well planted rig. Just some food for thought.
I thought about using the 435 but I really need a 5th gear being this is my daily driver. and the gearing difference in-between gears in drastic. ive driven 4 speed pickups and being they have low end torque its fine but with a 4 cylinder I think it would suck
1948 cj2a
Unread 05-13-2014, 09:38 AM   #49
warthog312
Agreed on the 2.5 with the 4 speed. In my case, even with the 1:1 ratio in 4th gear, I'm fine because I now have a v8 and 37's. My math tells me it will be at a decent rpm at highway speed, not that I plan on risking my life on the highway with this thing
[CENTER][I]Click for build thread:[/I] [B][URL="http://www.jeepforum.com/forum/f22/project-honeybadger-1519953/index6.html"][COLOR="Lime"]HONEYBADGER[/COLOR][/URL][/B] - [COLOR="DarkRed"]302//435//20//8.8[/COLOR][/CENTER]
[CENTER] >>>the single greatest investment you can make for your jeep is to buy a good welder, and learn how to use it<<<[/CENTER]
warthog312 is offline   Reply With Quote Quick reply to this message
Unread 05-13-2014, 07:41 PM   #50
Louie4
done
Sweet. I figure if you got it, flaunt it.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4's YJ Build
Unread 05-13-2014, 07:56 PM   #51
Cobrajet94
What gearing are you running in your axles. I looked more into the 435 and other than it not having overdrive it actualy has more pratical gearing than the zf5 2-4th
1948 cj2a
Unread 05-13-2014, 09:53 PM   #52
warthog312
My axles are 4.11:1
Upgraded 30 up front and an 8.8 with welded tubes in the rear.
I wouldn't have gone with the 435 if I didn't have the V8. those extra cylinders and cubes to keep rpm down.
Unread 05-14-2014, 07:22 PM   #53
Cobrajet94
My axles are 4.11:1
I looked all over the internet today. Ive come the the conclusion that im going to use the ax15 i found all the adapter plates. Ill be using a ford truck bellhousing mated to a 2.3 to ford small block adapter and a 5.0 flywheel with a 2.3 bolt pattern. And the ax15 will be mated as if i would be using a small block ford.
Mating the d300 to the ax15 goes as followed: north west fab cable shifters and flip ring/adapter
So 3 adapters needed......if my math is corrext ill be able to get away with the length of this combo
1948 cj2a
Unread 05-20-2014, 11:39 AM   #54
Cobrajet94
after searching for a week I have found and engine and I picked it up this weekend for $280 its a 2.3l turbocharged engine from a 1988 ford thunderbird turbocoupe. stock it makes 190hp and 240ftlbs.
I will be pulling it apart and rebuilding what needs to be rebuilt. 3 angle valve job, head gasket, timing belt, new rings, crank/rod bearings.
more pictures to come during the teardown.
1948 cj2a
Unread 05-20-2014, 06:11 PM   #55
sxysouthtx
Dude, you have a sick YJ. That's sort of the way I want to go with mine. I'm subbed.
Not much motion in the ocean, but I'm the captain.
sxysouthtx is offline   Reply With Quote Quick reply to this message
Unread 05-22-2014, 11:18 AM   #56
Cobrajet94
so looking into doing a 4:1 d300 and I didn't want to have that as my low range all the time, my gearing now is perfect for trail riding but too high of gearing on the rocks so I have come across an underdrive made by behemoth called the strong box, it utilizes the stock 231 planetary gears and combined with the dana 300 low range It will give me a 7.12 low gear or a 2.72 or a 2.62 so basically a 3 speed atlas for $600 plus whatever the tcase costs me. the unit they make is only 4" or so long so it will still be shorter than a np231 with an sye
1948 cj2a
Unread 05-29-2014, 03:33 PM   #57
Cobrajet94
im going to order a jeep 2.5 from jasper engines for now. I have the money and I would rather have a running jeep for the summer than a large paperweight in my shop. also I want to rebuild the 2.3 ford engine and put some performance internals (rods, piston, cam). the dana 300 and the underdrive unit will most likely be installed over the summer before the ax15 and the 2.3 are even thought about.
ill be posting some pictures when I swap the 2.5 out for the rebuild one I a couple of weeks.
1948 cj2a
Unread 05-30-2014, 04:13 AM   #58
DpDave
Is that Jasper engine just a stock rebuild? Be careful of sticking any kind of real power in front of that AX-5, they are famous for being wimpy. I'm curious to see more about this transfer case mod you are looking at. Love to get more gear out of mine, but LoMax is the only real option I've found.
If yer gonna fight, fight like the third monkey on the ramp to Noah's Ark.
My Build Thread:
[URL="http://www.jeepforum.com/forum/f22/third-monkey-yj-overbuild-1521567/"]http://www.jeepforum.com/forum/f22/third-monkey-yj-overbuild-1521567/[/URL]
DpDave is offline   Reply With Quote Quick reply to this message
Unread 05-30-2014, 11:15 AM   #59
Cobrajet94
the engine is rebuilt. all wearable internals are replaced. the ax5 is getting tossed when the turbocharged engine goes in.
I thought about doing a lomax but I love my 2.72:1 low and with having more gear ratios im better prepaired to go anywhere. here's a little bit more information on the underdrive I want to get http://www.behemothdrivetrain.com/ST...RIVE_KITS.html
1948 cj2a
Unread 05-30-2014, 04:01 PM   #60
DpDave
I just had a look at that, and think I'll give him a call. Looks like a very cool setup that will solve a bunch of issues I have in connecting up my drivetrain. Triple sticking looks pretty cool too!
My Build Thread:
