cobrajet94's YJ build - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > cobrajet94's YJ build
USA Standard Chromoly Front Axle Shaft Kits with Dana 30 4Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Wranger BRIGHT License Plate LED! Just $3! Great value
Unread 04-10-2014, 09:40 AM   #1
Cobrajet94
Finaly starting a build thread for my 1992 yj 2.5l. This is my first vehicle having it myself for almost 3 years. My dad got it in 04' drove it for a year or two and used it as a shop truck untill i got my license in 2011. Since then its changed a little.
Here's a little bit about myself. Im 19 recently graduated Lincoln tech in Connecticut for automotive mechanics. My father owns a automotive shop on long island that me and him run. Prior to starting my YJ build me and my father built a 1948 CJ2A my last two years in high school. Restored it to somewhat stock we added our touch here and there. Its sitting on 31x10.5 iroks.
Enough with the chit chat this is what you have come for:
Heres a list of things ive already done
3.5 fabtech springs
James duff front shocks
F350 front shock towers
Rough country rear shocks
Crown extended brake lines
Barnes 4wd front bumper
Whats to come next week:
Ford 9" rear 31 spline
9"front currie housing with d44 inner c's
Inner chromoly shafts
Ford d44 knuckles/brakes etc.
Detroit lockers f/r 4.86 gears
Ruff stuff y link 1 ton steering
current picture:
1948 cj2a
1992 YJ build thread- http://www.jeepforum.com/forum/f22/cobrajet94s-yj-build-2313233/
Cobrajet94 is offline   Reply With Quote Quick reply to this message
Unread 04-11-2014, 01:15 PM   #2
Cobrajet94
ive had a lot of parts sitting around waiting to be installed lol ive come to realize it takes a while to plan and build a jeep
currie 9" front housing custom built to a 65.25" wms
Detroit lockers and 4.86 gears
1948 cj2a
Unread 04-11-2014, 02:01 PM   #3
Louie4
Powah Injanir
Louie4's Avatar
You had me at 9" front custom built.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4's YJ Build
Poison Spyder Fender Install
Warn M8000 Rebuild Adventure
University of Georgia
Louie4 is offline   Reply With Quote Quick reply to this message
Unread 04-11-2014, 03:49 PM   #4
Deepsouth
That looks cool. Is the 9"" front going to be high pinion or low?
Deepsouth is offline   Reply With Quote Quick reply to this message
Unread 04-12-2014, 09:13 AM   #5
Cobrajet94
For now low pinion but eventualy im going to get a hp third member
1948 cj2a
Unread 04-12-2014, 03:47 PM   #6
lovett86
cool jeep
its a rusty one
http://www.jeepforum.com/forum/f22/90-yj-frame-swap-build-up-1434246/
lovett86 is offline   Reply With Quote Quick reply to this message
Unread 04-12-2014, 06:10 PM   #7
Cobrajet94
flex shot from a couple months ago. not much but good for sua 3.5" springs
last weekend wheeling i stuffed my 31s into the fenderwell. i was supprise that i could get the tire that far up!
1948 cj2a
Unread 04-14-2014, 09:59 AM   #8
Cobrajet94
Brown santa brought some presents! My ruffstuff 1 ton y-link steering and the axle mounts and pinion guards from barnes 4wd came this morning
I also picked up 3rd member for the front axle from my friend for 50 bucks.
I ordered 35x12.5 goodyear mtrs they should be here in a couple days. Ill need to do some trimming to the flares so they dont rub too much
1948 cj2a
Unread 04-14-2014, 10:06 AM   #9
Cobrajet94
This third member has 3.50 gears and an open diff and a 1330 yoke. The other 3rd is the same but it has 1310 yoke. Im using stock shafts (1310), Luckily my dad had two yokes for a 9" laying arround. One is a 1310 and its a long yoke, hopefully it will help with my rear driveshaft being stock and short
1948 cj2a
Unread 04-15-2014, 10:02 AM   #10
Cobrajet94
So i started to tackle regearing and installing the lockers. So far i have gotten one third member disassembled, pinion installed and preload set.
I plan on finishing both today
1948 cj2a
Unread 04-16-2014, 05:57 PM   #11
Louie4
Powah Injanir
Louie4's Avatar
Is the preload and backlash set separately on the third members? It appears they are but I have never set up gears in them.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4's YJ Build
Unread 04-17-2014, 10:08 AM   #12
Cobrajet94
pinion preload is the pressure on the bearings on the pinion, backlash is the amount of movement between the ring gear and the pinion gear when the pinion gear is held in place.
this is my first time setting up gears in a 9" its very simple compared to a dana 44 that I set up while I was in school.
1948 cj2a
Unread 04-17-2014, 10:19 AM   #13
Cobrajet94
For my first time setting up my gears and lockers id say i did good. I set the backlash to .007 and firured i needed a .015 pinion shim. Gear pattern checked out perfect! Now i need to setup the rear 3rd member.
My 35x12.5 goodyear mt/r's came in today!
1948 cj2a
Unread 04-17-2014, 05:45 PM   #14
Cobrajet94
mounted my new tires up today jeep. im going to build the second third member tonight and Saturday the axles will get mocked up, mounts welded and mount everything up. all my brake parts came and will be setup after the axles are mounted
1948 cj2a
Unread 04-17-2014, 08:50 PM   #15
Louie4
Powah Injanir
Louie4's Avatar
I understand that. It just seems like one doesn't affect the other on the 9" unlike non third members. Seems simple enough though.
Keep up the good work.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4's YJ Build
