Cliptfc's 97 Wrangler with 4.8L GM swap - JeepForum.com
post #1 of 19 Old 05-19-2016, 06:17 PM Thread Starter
cliptfc
I thought I would do a write up on my build. I was trying to make this build as budget friendly as possible. I've never done a swap before, and consider myself an average shade tree mechanic. Here's the day I bought the Wrangler last year, for $4200. She was a good running 4cyl with an auto transmission.
cliptfc is offline
post #2 of 19 Old 05-19-2016, 06:20 PM Thread Starter
cliptfc
Taking out the 4cyl, auto transmission and transfer case out in one pull...
Open hole...
cliptfc is offline
post #3 of 19 Old 05-19-2016, 06:22 PM Thread Starter
cliptfc
Here's the 4.8l, 4l60e transmission and the np231 transfer case mounted up. I used the Advance Adapters kit to mate the 4l60e to the np231 t-case.
cliptfc is offline
post #4 of 19 Old 05-19-2016, 06:25 PM Thread Starter
cliptfc
I decided to use the Superior Radiator (out of Michigan) for cooling. I went with one that had the transmission cooler built in.
cliptfc is offline
post #5 of 19 Old 05-19-2016, 06:30 PM Thread Starter
cliptfc
I didn't trust my welding ability enough to weld the new mounts in, so I trailered it over to a friend's place. I used the Advance mounts and they give you a tool to show you right where to weld them in.
cliptfc is offline
post #6 of 19 Old 05-19-2016, 06:35 PM Thread Starter
cliptfc
Fitting the engine, transmission and tcase in. I put them in all in one drop....all mated up. I left the front grill off for the drop in.
cliptfc is offline
post #7 of 19 Old 05-19-2016, 06:42 PM Thread Starter
cliptfc
The Advance kit required you do at least a 1" body lift. I went with the Zone 1.25" and it was a simple install. With the engine in, I realized it would need a suspension lift as well, as the power steering pulley was close to the front diff housing. It would have probably hit if it bottomed out. So keeping things on a budget, I went with Rough Country's 2.5" spring lift, with new shocks.
I realized the tires needed to hit the weight room after the body/suspension lift, so I had a set of 33x12.5x15 Buckshot Murder II's put on.
cliptfc is offline
post #8 of 19 Old 05-19-2016, 06:55 PM Thread Starter
cliptfc
So I was trying to keep it budget friendly.... here's about 95% of the costs that were directly related to the swap.
cliptfc is offline
post #9 of 19 Old 05-19-2016, 08:44 PM Thread Starter
cliptfc
Right now, my stock coolant, fuel, volt and oil pressure gauges work. I'm sure the speedometer will work, but I accidentally cut off and threw away the vss plug...waiting on a new one.
For the coolant, I reused the stock Jeep 3/8 not sensor with a ictbillet.com adapter into the rear of the passenger head. Didn't have to drill or anything, just installed it.
For the oil pressure, there was a plate above the oil filter I took off. It had a spot on the top that look like it was intended to be drilled and tapped for 1/8npt, so that's what I did. The Jeep oil pressure sensor screwed right in.
cliptfc is offline
post #10 of 19 Old 04-18-2017, 05:54 PM Thread Starter
cliptfc
It has been awhile since I posted. I installed a EMP gas tank skid plate as mine was rusted out.
cliptfc is offline
post #11 of 19 Old 04-18-2017, 05:58 PM Thread Starter
cliptfc
I was worried the stock d35 wouldn't hold up, so I swapped in a completely rebuilt 8.8 from East Coast Gears.
cliptfc is offline
post #12 of 19 Old 04-18-2017, 06:02 PM Thread Starter
cliptfc
Ended up with a vibration after installing the 8.8, so I installed a SYE kit with a Tattons driveshaft. Vibration went away.
cliptfc is offline
post #13 of 19 Old 04-18-2017, 06:03 PM Thread Starter
cliptfc
I didn't like the GM transmission mounted to the skid pan, so I bought a genright diy crossmember kit.
cliptfc is offline
post #14 of 19 Old 04-18-2017, 06:06 PM Thread Starter
cliptfc
The 8.8 axle tube was much bigger than the d35.... causing my rear end to be much higher than my front. I slipped some puck spacers in, then realized my caster was off. Purchased a set of Metalcloak lower control arms to fix that.
cliptfc is offline
post #15 of 19 Old 04-18-2017, 06:08 PM Thread Starter
cliptfc
My stock sway bar links were now too short too, so I used a pair of jks adjustable disconnects.
cliptfc is offline
