Climbit's Daily Driven Weekend Wheeling affair - Page 9 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Climbit's Daily Driven Weekend Wheeling affair
Ruffstuff 10 year saleBDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!
Unread 06-17-2013, 01:36 AM   #121
Climbit
Originally Posted by CTeunuch
SICK rims bro.
Right...
Climbit is offline   Reply With Quote Quick reply to this message
Unread 06-25-2013, 01:48 AM   #122
Climbit
Got a lot done on the POS.
Pulled and swapped the Radiator and AC condenser, ditched the factory transmission cooler for a larger one and re-plumbed the lines, and got a power steering cooler mounted up.
everything out... I'm kinda kicking myself for not doing a water-pump and thermostat while i had it open.
everything new
I had to do a little "custom" plumbing on the steering cooler return. the pump has a -6 return welded in, and the cooler I had is -8. so I used a -8 pushlock fitting with a -6 adapter. I ordered the wrong adapter, so I couldn't use my -6 pushlock fitting, so instead I used a peice of 3/8" transmission tube I had cut off the transmission feed to the rad and a 3/8" tube to -6AN adapter fitting and flared the end of the tubing to get a good seal. I've got the -6 male-male adapter now, so if it leaks I can put a real push lock fitting, but I don't see that happening.
and all of that leads up to this: 35" MTRKs
also picked up this little toy: 8.8, 4.56, ARB, Super88 kit.
Unread 06-25-2013, 11:29 AM   #123
ibjeepin95
I dig the stance, but I thought you was going taller?
everything new
ibjeepin95 is offline   Reply With Quote Quick reply to this message
Unread 06-25-2013, 10:24 PM   #124
Grewe02
Guns > Swords
Grewe02's Avatar
1980 CJ5
Is that Joe's 8.8?
Andy, KD8EIA
Originally Posted by Jetscuh
Grewe02 is offline   Reply With Quote Quick reply to this message
Unread 06-25-2013, 11:46 PM   #125
Climbit
I will. the front will probably get another 1 to 2 inches to sit more level with the rear.
the plan is a set of ACOS. I don't want different springs.
then I'll re-do my shock mounts and possibly 3 link it. depends on how much time and money I have.
it will need a ****load of sheet metal work to tuck the 35"s like the 33"s did.
Originally Posted by Grewe02 View Post
Is that Joe's 8.8?
yup
Unread 06-26-2013, 01:51 AM   #126
Grewe02
Guns > Swords
Grewe02's Avatar
1980 CJ5
Dang I didn't realize he had it out already! Good news is you'll never break it
Andy, KD8EIA
Unread 06-26-2013, 11:12 AM   #127
ibjeepin95
yup
What springs do you have that you like so well? As far as 35's on your current height, it's not as much sheet metal work as you think
Unread 06-26-2013, 01:19 PM   #128
Climbit
I run currie 4" TJ springs...
As far as uptravel, I run 12" shocks with 7" of uptravel.
At my height that puts the 35" just under the hood.
Unread 06-28-2013, 07:39 PM   #129
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
Is that Joe's 8.8?
Not any more.
Me gots another axle that needs to be installed that I'm working on.
Joe Dillard is offline   Reply With Quote Quick reply to this message
Unread 07-01-2013, 11:32 AM   #130
ibjeepin95
I must ask, how in the hell are you making 12" shocks work with 4" springs and getting that much up travel? Yesterday I swapped my 3" coils for some 4-4.5" coils to level my XJ out and I still can't get more than about 4" of up travel with 10's! That's with 35's. My lower mounts are moved slightly, but not much.
Unread 07-01-2013, 12:50 PM   #131
Climbit
currie coils have ~11" of travel. I am maxing them out.
go back a few pages, my shock mounts have been moved down a bit and I run short body shocks.
more recently, blew a hub on my first shakedown run. considering getting some CTM drive flanges
Unread 07-01-2013, 09:08 PM   #132
Grewe02
Guns > Swords
Grewe02's Avatar
1980 CJ5
How did you do that, anyway?
Andy, KD8EIA
Unread 07-09-2013, 03:17 PM   #133
Climbit
too much skinny pedal.
Unread 07-09-2013, 05:50 PM   #134
CTeunuch
No such thing.
Think Twice Garage
"Yeah, that might work, pass me the grinder..."
94ZJ AX15/HP44/8.8/5.13's/35'' MTZ's SOLD
99XJ 4.0/AW4/HP30/8.25 build coming soon...
www.undergroundjeeps.net
CTeunuch is offline   Reply With Quote Quick reply to this message
Unread 07-23-2013, 11:23 AM   #135
ibjeepin95
currie coils have ~11" of travel. [/IMG][/URL]
Wow. I need to look into some Currie coils...
