Climbit's Daily Driven Weekend Wheeling affair - Page 3 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Climbit's Daily Driven Weekend Wheeling affair
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 07-06-2011, 04:44 PM   #31
Climbit
SYE done
broke the tap that was sent with the kit, didn't even make one full revolution
got my trans Xmember started...
all that needs to happen to it now is to have the holes drilled for the tranny mount and the tie-in brackets built.
Climbit is offline   Reply With Quote Quick reply to this message
Unread 07-17-2011, 02:03 AM   #32
Climbit
231 Transfercase hith H&T sye in
Flat crossmember (it was notched in a couple more places for exhaust hangars and front driveshaft. then all the extra holes were welded closed and then it was painted.
mounted
19" of ground clearance. with 4" lift and 33"s still need to re-build the rear driveshaft and get some shims for the rear end. my pinion angle is about 6* low..
after that is skid plate time.
I think I am going to end up loosing about 1" of clearance because I want the skid to drop down and protect the bolts and whatnot.
Unread 07-18-2011, 04:33 PM   #33
Climbit
Unread 10-18-2011, 10:42 PM   #34
Climbit
Update:
pulled the transfercase again, was getting a nasty clicking from inside, rebuilt case, only to find out that both of the driveshafts CV's went out at the same time, so when I ran the case without the rear shaft in, it still made the noise, and because of how the fixed yokes are, the noise sounded like it was coming from inside the case.
both shafts are at a shop being rebuilt, pics when I get them back
as far as unecessarily disassembling the case: oh well, all I am out is a little bit of ATF and some time, and now I know I can re-build one properly.
Unread 10-19-2011, 01:11 AM   #35
'92 vegas YJ
R.I.P. Ratmonkey
'92 vegas YJ's Avatar
Yea that 231 is real simple on the inside
~'92 YJ with many upgrades and many more calling my name..... it never ends
~'07.5 Dodge Ram Megacab 2500, 6.7L Cummins turbo diesel
April 2012, May 2013, May 2014 YJ of the month
'92 vegas YJ is offline   Reply With Quote Quick reply to this message
Unread 11-29-2011, 01:13 AM   #36
Climbit
suppose I should update this.
got the front end pretty well built.
Warn chromo inner/outers with Warn Lockouts
Vanco 16" brakes
ARB
custom inverted T hi-steer using 3/4" heims. will be swapping the pitman arm heim for a high angle TRE
OTA trackbar. using 7/8" hiems
still waiting on a set of raised sway bar mounts, then I will measure for limit straps.
after some dialing in, I am pretty happy with it. some people are not a fan of the inverted T system because of the inherent dead spot. I haven't found it to be much of a problem. although it is there. I would have rather gone with a full crossover setup, but I couldn't figure out a way of doing that without fabbing a new frame side TB bracket and some sort of double shear knuckle bracket.
the long run plan is to go with hydro assist, which will eliminate the dead spot and tie-rod roll. but first I need to deal with getting some armor on the jeep and then get the rear end dialed in.
the rear driveshaft will probably need to be shortened some, and a rear truss and raised shock mounts to go with shackle relocation brackets.
Unread 01-06-2012, 05:56 PM   #37
Climbit
Here is what I came up with for mounting my ARB switches. I am also going to put this in my build thread for future reference..
I used an ARB flush mount bracket with the 90* tab cut off and a couple extra holes in it.
This sheetmetal panel is behind the dash panel, and here's the dash panel we notched as well.
The paint didn't quite come out how I wanted it to, but I ran into a time constraint so I will go back over it when I get a chance.
Unread 01-13-2012, 06:48 PM   #38
SaxManClay
Dude, nice Cherokee you got going here.
SaxManClay is offline   Reply With Quote Quick reply to this message
Unread 01-13-2012, 06:51 PM   #39
Climbit
thanks! its a work in progress for sure.
in other news...
found out I will be waiting until at least the 24th to get my new shocks.... nobody at polyperformance thought it was wise to tell me that they had a 2-3 week build time, instead they told me they would ship out within the week.
Unread 01-16-2012, 12:20 PM   #40
nickwygant
http://www.ballisticfabrication.com/...8-_p_1684.html
for your cross member bolts so you don't have to drop it a inch just an idea!!!!
if you didn't drop it yet!
nickwygant is offline   Reply With Quote Quick reply to this message
Unread 01-16-2012, 04:03 PM   #41
Climbit
that is brilliant!
no, I haven't dropped it yet since I haven't yet come up with a skid.
Unread 01-16-2012, 04:43 PM   #42
Necromancer_tat
Where'd all my money go?
Necromancer_tat's Avatar
2015 JK Wrangler
Nice build so far!
My newest build: http://www.jeepforum.com/forum/f22/j.../#post32474474
Necromancer_tat is offline   Reply With Quote Quick reply to this message
Unread 01-18-2012, 02:50 AM   #43
1990JEEPXJ
1990 XJ Cherokee
meh. its ok i guess...
My POS
1990JEEPXJ is offline   Reply With Quote Quick reply to this message
Unread 01-18-2012, 11:36 AM   #44
Climbit
I wish I had a chromolly unibody like yours...
Unread 01-18-2012, 11:15 PM   #45
Climbit
well... look what showed up at my house today
Bilstein 7100 Short Body Resivor, 12" Trave, 255/70 valving
I'm hoping to get them installed next week.
