Climbit's Daily Driven Weekend Wheeling affair - Page 2 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Climbit's Daily Driven Weekend Wheeling affair
Savvy Billet LED Tail LightsRough Country Jeep Suspension Deals at Rockridge 4WD!Alloy usa heavy duty ball joint kits
Unread 04-04-2011, 01:31 AM   #16
Climbit
got he carrier bolted together yesterday. when i have some more free tim i will do the D-ring tabs and the hitch.
I'm also going to texture-coat it with some rustoleum hammered when its 100% done.
pics of the tie in brackets to come later
Climbit is offline   Reply With Quote Quick reply to this message
Unread 04-04-2011, 01:32 AM   #17
Climbit
new harmonic balancer went on.
the jeep has looked like this for the last 2 days
the old balancer broke rather than coming off with the puller leaving the pressed on portion still on the crank. using a die grinder I was able to cut a notch in it and pound a chisel into that notch and breaking the remaining part off of the crankshaft.
the old balancer in place
finally off
had to pull the fan clutch, water pump pulley, alternator bracket, and AC bracket to get the timing cover off... cleaned and replaced seal.
the jeep is all back together now; just needs coolant and it should be good to go :knockonwood:
Unread 04-04-2011, 01:32 AM   #18
Joe Dillard
Electric Chair Operator
It's coming along nicely!
Opps, you were posting while I was postin.
Nice carrier.
Joe Dillard is offline   Reply With Quote Quick reply to this message
Unread 04-04-2011, 01:34 AM   #19
Climbit
I don't have pictures of the Brown-dog motor mount install or the new trans mount (OEM replacement)
I am getting a slight vibe from the brown dogs... anyone have any advice.
I am also working on an idea for a raised up trans crossmember that is flat to the uniframe and a flat skid.
all this will happen after the 231 gets SYE and a driveshaft gets built.
then its time to cut the rocker panels out and replace them with some 2x6x3/16" like EricsXJ did.
Unread 04-04-2011, 01:36 AM   #20
Climbit
Nice carrier.
I knew somebody was going to sneak in while I was posting.... it had to be you
yea, thanks for the compliments. I will get in touch with you soon about the D-ring tabs and hitch.
Unread 04-04-2011, 04:51 PM   #21
The_Blacksmith
Genius with this metal
The_Blacksmith's Avatar
1993 XJ Cherokee
looking awesome, glad you made the thread over here
The_Blacksmith is offline   Reply With Quote Quick reply to this message
Unread 05-27-2011, 08:37 PM   #22
'92 vegas YJ
R.I.P. Ratmonkey
'92 vegas YJ's Avatar
sooo any new progress?
i still need to check out that tire carrier you built.
-chris
~'92 YJ with many upgrades and many more calling my name..... it never ends
~'07.5 Dodge Ram Megacab 2500, 6.7L Cummins turbo diesel
April 2012, May 2013, May 2014 YJ of the month
'92 vegas YJ is offline   Reply With Quote Quick reply to this message
Unread 05-28-2011, 12:42 AM   #23
Climbit
-chris
well, I went to the stealership and get the necessary T-case swap stuff ordered. my SYE has been ordered, and I need to finish up my new Xmember and skid plate for the attempt at going to a flat belly.
several guys on NAXJA have gone flat with a 231 t-case behind the AW4, so I'm hoping it works for me.
the tire carrier is in pieces, it will get welded back together soon, maybe tomorrow. I made a few modifications.
Unread 05-28-2011, 01:44 AM   #24
1990JEEPXJ
1990 XJ Cherokee
about time you make a build thread! geez. you going to drill new holes in the transmission for the t-case to clock it?
My POS
1990JEEPXJ is offline   Reply With Quote Quick reply to this message
Unread 05-28-2011, 01:50 AM   #25
Climbit
I shouldn't need to drill new holes with the new crossmember that I am building. I really don't want to screw with that.
Unread 05-28-2011, 02:08 AM   #26
1990JEEPXJ
1990 XJ Cherokee
ah. so a t-case raise is all. gotcha. i still need to stop by and check out the tire carrier
My POS
Unread 05-28-2011, 02:47 PM   #27
The_Blacksmith
1993 XJ Cherokee
i knew youd be re doing that carrier once you finished it hehe
<3 miss chatting ya about crazy jeep stuff.
Unread 05-28-2011, 07:00 PM   #28
Climbit
hahaha.... just a few minor issues, one of them being a license plate bracket.
Unread 07-02-2011, 02:10 PM   #29
Climbit
went from this
to this
I still have to drill and tap the hole in the output shaft, but I ran out of time.
its a dirtbound offroad SYE FWIW.
its a little bit long for my taste, but I think it will be fine. only time will tell I suppose.
Unread 07-02-2011, 06:50 PM   #30
1990JEEPXJ
1990 XJ Cherokee
im sure itll be fine. i wish i had went with an SYE with a yoke like that. makes having one spare driveshhaft that much easier. if you want some help with the t-case swap let me know.
My POS
