Climbit's Daily Driven Weekend Wheeling affair - Page 14 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Climbit's Daily Driven Weekend Wheeling affair
Ruffstuff 10 year saleBDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!
Unread 07-13-2014, 12:54 AM   #196
Climbit
before
after: 104"
Climbit is offline   Reply With Quote Quick reply to this message
Unread 08-17-2014, 03:54 PM   #197
MOBBiN
Mall Crawler Level 3
MOBBiN's Avatar
Just went through your whole build. I dig it.
Build Thread
April 2014 & 2015 COTM
MOBBiN is offline   Reply With Quote Quick reply to this message
Unread 01-14-2015, 07:28 PM   #198
ibjeepin95
Originally Posted by Climbit View Post
before
after: 104"
Why only 2" of stretch for all that cutting?
ibjeepin95 is offline   Reply With Quote Quick reply to this message
Unread 01-14-2015, 08:13 PM   #199
Luke95
That looks like ****.
106-108 would look better
Resident XJ lowlife. 35 general reds on 3inches of lift.
Luke95 is offline   Reply With Quote Quick reply to this message
Unread 01-14-2015, 08:16 PM   #200
Climbit
its actually 4" of stretch with the lift. its 104" at ride height
the reason that's as far back as I went is thats where the rear dif begins to hit the tank.
I set it up to fit a 40" tire with a couple more inches of stretch, but that will require raising the tank. which I will do when it comes time for that.
Unread 01-14-2015, 08:20 PM   #201
Climbit
I agree. 106-107 is going to be better, but tell that to the shiny spot on my dif cover from where it rubs the tank skid.
Unread 01-15-2015, 01:38 AM   #202
Grewe02
Guns > Swords
Grewe02's Avatar
1980 CJ5
Don't worry Taylor, I don't think it's ugly.
Andy, KD8EIA
Originally Posted by Jetscuh
Grewe02 is offline   Reply With Quote Quick reply to this message
Unread 01-15-2015, 11:15 AM   #203
Climbit
It really is. But I'm ok with it.
Unread 06-14-2015, 12:35 AM   #204
Climbit
ah the joys of wheeling a cherocar. not having the 2 bottom bolts in the motor mount turns out is not a good plan.
repair time
cut out all of the affected area, both outside and bottom of the unibody completely. replaced all of it with 3/16".
there is also a 3/16" inner plate that is welded to the bottom and the inner part of the unibody that extends from the first steering box bolt all the way to the motor mount. also added a 3/16" stiffener that runs all the way down the bottom to the LCA mount. and is tied in to the rest of the HD offroad frame stiffener
Unread 06-14-2015, 09:45 AM   #205
nickwygant
i see you have a bar from passengar side to driver side track bar mount. did that also break off? i see it has been cut in the last picture.
nice job putting everything back together!
nickwygant is offline   Reply With Quote Quick reply to this message
Unread 06-14-2015, 01:01 PM   #206
Climbit
Originally Posted by nickwygant
i see you have a bar from passengar side to driver side track bar mount. did that also break off? i see it has been cut in the last picture. nice job putting everything back together!
Yes. It tore.
My opinion is that it was really the only thing holding the bracket in the right spot and eventually leverage overcame it and it tore.
Now that everything has been replaced and the outer section has been welded to the inner section that won't happen.
Unread 06-16-2015, 01:40 AM   #207
Grewe02
Guns > Swords
Grewe02's Avatar
1980 CJ5
How bad does your tire rub on that trackbar mount?
Andy, KD8EIA
Unread 06-16-2015, 02:27 AM   #208
Climbit
it shouldn't get anywhere near it.
Unread 11-29-2015, 11:36 PM   #209
Climbit
minor update
Polyperformance 3 link brackets
7075 alum arms
2.5" Johnny Joints on all ends
Unread 02-01-2016, 10:47 PM   #210
Climbit
