Climbit's Daily Driven Weekend Wheeling affair - Page 13 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Climbit's Daily Driven Weekend Wheeling affair
BDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRuffstuff 10 year saleRough Country Lift Kits and Parts!
Unread 03-17-2014, 08:39 PM   #181
Grewe02
Guns > Swords
Grewe02's Avatar
1980 CJ5
I like those fancy triangle corners! Musta taken some sort of genius to figure that out
Andy, KD8EIA
Originally Posted by Jetscuh
Grewe02 is offline   Reply With Quote Quick reply to this message
Unread 03-20-2014, 02:58 PM   #182
ibjeepin95
Originally Posted by Climbit View Post
progress.
Very different take on this than most. I like it.
ibjeepin95 is offline   Reply With Quote Quick reply to this message
Unread 04-01-2014, 12:32 AM   #183
Climbit
passenger tube
bumper mount
Climbit is offline   Reply With Quote Quick reply to this message
Unread 04-03-2014, 12:30 AM   #184
Climbit
just as a for fun project, I decided to make my ruffstuff D30 cover into a housing stiffener. not sure what its going to accomplish, other than being another layer of polish on an already polished turd.
this is the best way we could come up with to do it.
5/16" countersunk bolts drilled out to become 60degree tapered washers.
60* tapered countersink to the holes
11/16" counterbore on the holes to make room
1-1/4" grade 8 bolts.
the plan is to install with RTV, not a lube-locker or other gasket. the idea is to get the two surfaces to actually mate and get some clamp load out of the system. that would not be possible with a flexible gasket.
I wouldn't have bothered, but I won the ruffstuff cover in a naxja raffle, so it seemed like a fun idea.
Unread 04-07-2014, 01:45 PM   #185
Grewe02
Guns > Swords
Grewe02's Avatar
1980 CJ5
Must... Have.... Updates!
Andy, KD8EIA
Unread 04-07-2014, 10:16 PM   #186
Climbit
made good progress over the weekend.
I didn't take any photos. because I am dumb
rear bumper is done-ish.
rear quarters/taillights are welded in.
passenger tube work is 90% done.
shocks are rebuilt and ready to go
next up is front shocks rear stretch, driveshaft, shock mounts, and enclosing the cab.
and probably 10 other things I forgot.
Unread 04-13-2014, 12:27 AM   #187
Climbit
coming along slowly.
can anyone spot my screwup?
Unread 04-13-2014, 10:19 AM   #188
Luke95
That shackle?
Resident XJ lowlife. 35 general reds on 3inches of lift.
Luke95 is offline   Reply With Quote Quick reply to this message
Unread 04-13-2014, 11:23 AM   #189
Climbit
negative. the shackles are good.
Unread 04-26-2014, 11:32 PM   #190
Climbit
updated: ordered a set of springs from National spring here in san diego. they are a couple weeks out and the jeep needs to be weighed before they are built. so I will be running on the RE's for now.
Shock towers are in
back on its own weight. once the new springs are in final ride height will be about 2" lower and the tire will be about 4" back from where it is now.
Unread 04-29-2014, 01:44 AM   #191
Climbit
rear is done. at least until I have the new springs made. just needs some paint and a couple hours with seam sealer.
Unread 05-01-2014, 08:47 PM   #192
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
By chance did you remember about the main ground for the fuel pump that's inside the rear compartment of the vehicle?
If you happen to neglect to properly connect this ground, your jeep will get you just far enough to be stranded when it looses connection...
Joe Dillard is online now   Reply With Quote Quick reply to this message
Unread 05-02-2014, 01:30 AM   #193
Climbit
I totally did remember it
after I got towed home
Unread 05-04-2014, 02:42 AM   #194
Climbit
It's alive again!
Still lots left to do, but so far it works awesome.
I can't say enough about the tuned fox shocks.
What a difference that makes.
Unread 07-13-2014, 12:53 AM   #195
Climbit
