-   Jeep Builds (http://www.jeepforum.com/forum/f22/)
-   -   Climbit's Daily Driven Weekend Wheeling affair (http://www.jeepforum.com/forum/f22/climbits-daily-driven-weekend-wheeling-affair-1191536/)
Climbit 04-04-2011 12:09 AM
I suppose I've been on here long enough to warrant a build thread on my XJ
the goal of this XJ is to ge a rockcrawler. its not there yet, its not even close. but I'm in college, working as hard as I can and learning as much as I can.
things are starting to pick up.
it al started with a RE 3.5" SF lift a Rusty's 1" drop transmission crossmember, and a Rusty's tie-rod conversion
http://www.nightcrew.org/attachment....8&d=1288251288
here is how it sat, stock tires; just about 4.5" of lift netted.
after a few months, I went with 33x1050 on some pro-comp 1069. no fender trimming: bad idea.
http://i789.photobucket.com/albums/y...t/IMGP4807.jpg
Took it to big bear CA and wheeled on some trails.
http://i789.photobucket.com/albums/y...0/IMG_3133.jpg
http://i789.photobucket.com/albums/y...0/IMG_3148.jpg
http://i789.photobucket.com/albums/y...epflexhuge.jpg
Climbit 04-04-2011 12:11 AM
after forcibly removing the fender flares with the tires. I decided to trim.
http://i789.photobucket.com/albums/y...gpassenger.jpg
I also have a write-up on how I did this trimming in more detail
http://www.jeepforum.com/forum/f11/g...-ever-1107237/
Climbit 04-04-2011 12:15 AM
next up is the upper control arms. the upper bushings were toast so I replaced them with a Currie Johnny Joint upper housing kit. bought through Savvy offroad and installed with the help of Joe Dillard.
the passenger side bushing is cut off about 4" above the tube, the JJ in the 1" flame cut post is welded in.
http://i789.photobucket.com/albums/y...bushingout.jpg
Then the drivers side bushing is pressed out. we used a balljoint press and a piece of the tube that fit around it cut to the right length.
http://i789.photobucket.com/albums/y...ssinginJJ1.jpg
then the JJ is pressed in reverse of the old bushing and CA's mounted up.
http://i789.photobucket.com/albums/y...Jinstalled.jpg
Climbit 04-04-2011 12:18 AM
Installed a Clayton Offroad frame side Track Bar bracket.
I chose this one because they offer it without a drop from factory height but in double shear.
http://i789.photobucket.com/albums/y...t/IMGP4985.jpg
you can see in the first pic that I had to space out the heim with some washers since they only offer their bracket for a 2.5" JJ whearas my TB uses a 5/8" heim with 2" misalignment spacers so I had to take up .5"
http://i789.photobucket.com/albums/y...t/IMGP4994.jpg
Double Shear FTW
Climbit 04-04-2011 12:19 AM
Rokmen uppers and lowers went in.
extended the wheelbase 1.5" to correct a driveshaft issue... I was fully collapsing it at full droop and risking damage to the u-joints or transfer case. dialed pinion angle. replaced all bushings with Johnny Joints.
out with the old... in with the new
http://i789.photobucket.com/albums/y...t/IMGP4995.jpg
2.5" johnny joints replace ****ty RE hourglass bushings
http://i789.photobucket.com/albums/y...t/IMGP4996.jpg
Rokmen uppers.... almost 5 times as thick as stock... these ends go on my already installed upper JJ kit.
http://i789.photobucket.com/albums/y...t/IMGP4997.jpg
Climbit 04-04-2011 12:20 AM
Did some wheeling at a local OHV area called Corral Canyon
notice the lack of flex in the rear... something I need to deal with
http://i789.photobucket.com/albums/y...s/IMGP5154.jpg
http://i789.photobucket.com/albums/y...s/IMGP5159.jpg
http://i789.photobucket.com/albums/y...s/IMGP5160.jpg
http://i789.photobucket.com/albums/y...s/IMGP5165.jpg
Climbit 04-04-2011 12:21 AM
more pics.
http://i37.photobucket.com/albums/e6...canyon/064.jpg
http://i37.photobucket.com/albums/e6...canyon/066.jpg
http://i37.photobucket.com/albums/e6...canyon/078.jpg
http://i37.photobucket.com/albums/e6...canyon/074.jpg
http://i37.photobucket.com/albums/e6...canyon/115.jpg
Climbit 04-04-2011 12:22 AM
and since my rusty's 1" drop crossmember and t-case skid hang down so low, things like this happen
http://i37.photobucket.com/albums/e6...canyon/114.jpg
Climbit 04-04-2011 12:24 AM
santa brought jeep presents
http://i789.photobucket.com/albums/y.../IMG_00208.jpg
be a couple weeks before I get them installed :sadnono:
EDIT I have not been able to install the Aussie because my case has too much pre-load. we tried using a home-made spreader to no avail... once I have some extra coin (after taxes) I will get a shop to do it the right way.
got a little trail damage
http://i789.photobucket.com/albums/y...r/IMGP5243.jpg
http://i789.photobucket.com/albums/y...r/IMGP5247.jpg
and just a few gouges.... no big, thats why its got a skid
http://i789.photobucket.com/albums/y...r/IMGP5254.jpg
Climbit 04-04-2011 12:25 AM
the Jeep in Ouray CO
salty roads mean dirty jeep
http://i789.photobucket.com/albums/y...ourayjeep1.jpg
http://i789.photobucket.com/albums/y...ourayjeep2.jpg
Climbit 04-04-2011 12:26 AM
my NP242 has some slack in the chain so I want to get rid of it
so
I picked up this little toy;
http://i789.photobucket.com/albums/y...t/IMGP5281.jpg
NP231 out of a TJ it needs a SYE and a driveshaft before it goes in
I also need a speedo plug, shift indicator plug, shift bezel, and shift gate from an XJ with a 231 to complete the swap if anyone has one lying around.
Climbit 04-04-2011 12:28 AM
began working on a swingout tire carrier
I know its not ideal for a rock crawler. but since I still DD this thing I need to get that tire out of the back.
it is not uncommon for it to see a trip to the mountains fully loaded with climbing gear and 3 or 4 climbers so getting the tire out of the back was essential... plus they look cool :rofl:
here is what I started with; that plate you see will be cut down and sit behind the wheel with the wheel bolted to it.
http://i789.photobucket.com/albums/y...t/IMGP5290.jpg
here is what the main bumper body will be made of: 5"x5"x3/16"...62" long
http://i789.photobucket.com/albums/y...t/IMGP5291.jpg
here is how far I got today; the carrier is 2"x2"x3/16"
http://i789.photobucket.com/albums/y...t/IMGP5294.jpg
Climbit 04-04-2011 12:29 AM
got the spindle from AtoZ today.
finished the main bumper.
once I have some time next week I will get the spinde installed and the carrier on, then its time for prep and paint.
http://i789.photobucket.com/albums/y...t/IMGP5305.jpg
better with the angles
side shot
http://i789.photobucket.com/albums/y...t/IMGP5306.jpg
hows this for Flux core :fu:
vertical
http://i789.photobucket.com/albums/y...t/IMGP5304.jpg
horizontal
http://i789.photobucket.com/albums/y...t/IMGP5303.jpg
Climbit 04-04-2011 12:30 AM
The bumper came off again today. I wanted to add some internal gussets on each side to stiffen up the tire carrier spindle and latch.
spindle side:
http://i789.photobucket.com/albums/y...t/IMGP5314.jpg
I also wanted to take pictures of the unibody tie-in brackets. I used a piece of 1/4" flat bar along the length, a piece of 1/4" 2x2 angle as a stiffener on the body side, and 2 pieces of 1/4"x3" flat as stiffeners inside the bumper. this is the highest clearance system I could come up with while still keeping structure vertically for upward impacts like coming off a ledge and landing on the bumper.
The tie in brackets:
http://i789.photobucket.com/albums/y...t/IMGP5311.jpg
the internal gussets
http://i789.photobucket.com/albums/y...t/IMGP5312.jpg
also, the piece of flat stock that AtoZ sends with their T-handle was not tall enough for the way I welded the spindle on (I wanted the spindle up higher) so I welded it to a piece of scrap 2x2x1/4" angle and welded that to the bumper body.
http://i789.photobucket.com/albums/y...t/IMGP5313.jpg
I am also in the process of repainting it with rustoleum hammered for a light texture look. pics when its done.
The time now is 02:55 AM.
