Cj body/ Tj chassis & LS engine - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Cj body/ Tj chassis & LS engine
FS: Wrangler RGB Multicolor Fog Light LEDs: Awesome EffectThanksgiving holiday sale in effect @ oconeeoffroad.comRugged Ridge 8500lb Winch w/ Steel Cable $294.99 Shipped O
Unread 03-19-2012, 02:47 AM   #1
4x4chase
So I lost my built YJ to my ex a little over a year ago and about the same time I picked up a basket case early 80's CJ. Since then I have been been trying to figure out how to build the jeep I want. I thought about just rebuilding the CJ and selling it to get a TJ, Thought about builiding up the CJ with an LS motor but didn't want the leaf sprung suspention or the weak frame & also thought about just selling all the CJ stuff to work towards buying the jeep I want. I have finally decided to put the CJ tub on a TJ chassis and find a LS motor (5.3 or 6.0) with tranny to get my V8 jeep I want.
I got the TJ rolling chassis last week and I am curently working on a lift system in my garage to lift the CJ tub. Preliminary measurements look like this shouldn't be to hard to do. I will probably need to cut off the 6 body mounts on the side of the frame rails and relocate them where I need them. The two mounts under the rear seat look to be in the correct location and the rear most two mounts will need to be slightly moved.
So I want to ask the TJ owners out there, if their is anything I should do to the frame before I get the tub mounted to it. I have read about drainage issues with the frame, and it looks like the upper rear spring mounts shold be angled different. The frame I got was a 4cyl TJ frame in great condition.
Any other thoughts would be appreciated. This is going to be a slow build as funds are tight (darn ex). I still have not decided on axles but would like another 8.8 like I used in my YJ. I am completely up in the air as to which front axle to use. I did get a dana 300 xfer case, with a new 4:1 kit, with the CJ purchase and plan to run it, meaning I need an adapter and possibly a flip kit depending on the front axle I use.
I am hoping to keep this build to a moderate level so that I can drive it regularly but still hit some fun trails. I will post pics in a littlet while althought all I have is a cell phone camera so lets see how those come out.
_/|,[____],
--...-L-[]IIII[]-
.^._.^.-===-
()_) ()_)-o-)_)
4x4chase is offline   Reply With Quote Quick reply to this message
Unread 03-19-2012, 05:32 PM   #2
JLITTY
1946 CJ2A
Thinking this exact same thing with my stretched Willys body. Crawled
JLITTY is offline   Reply With Quote Quick reply to this message
Unread 03-19-2012, 11:22 PM   #3
4x4chase
Working on pics
_/|,[____],
--...-L-[]IIII[]-
.^._.^.-===-
()_) ()_)-o-)_)
Unread 03-19-2012, 11:27 PM   #4
4x4chase
_/|,[____],
--...-L-[]IIII[]-
.^._.^.-===-
()_) ()_)-o-)_)
Unread 03-19-2012, 11:29 PM   #5
4x4chase
_/|,[____],
--...-L-[]IIII[]-
.^._.^.-===-
()_) ()_)-o-)_)
Unread 03-26-2012, 12:10 AM   #6
4x4chase
This is how I rigged the tub to be lifted
YEA I trust the joists
And up we go
Out with the old
In with the new
Moving wheel dollies
This is the forward most mount by the firewall. Probably could just drill a new hole for this to work
2nd mount back. This one will need a new mount.
Next one. Hmm. Some more fab. This one is close to the frame.
Under the rear seat, these lined up just fine. I will use these as a guide.
Under rear seat other side
The rearmost mounts. Im not sure on how to make these work yet. Any Ideas?
The rear of the tub lines up nicely with the rear of the frame!
But of course, the rear axle sets a little far forward for my taste!
AND... off with the old body mounts..
AND... off with the motor mounts.
_/|,[____],
--...-L-[]IIII[]-
.^._.^.-===-
()_) ()_)-o-)_)
Unread 03-26-2012, 12:15 AM   #7
4x4chase
Still haven't heard from any TJ owners if there is anything they would change to the frame while I have this kind of access to it. I am also looking for axles so any help would be apreciated.
_/|,[____],
--...-L-[]IIII[]-
.^._.^.-===-
()_) ()_)-o-)_)
Unread 09-22-2012, 09:15 PM   #8
letchcore
1983 CJ7
Any updates on this? Good looking project
83' CJ7 "Strokie" Patriot blue, 4.6L, NSG370, D300, 4.56 gears, ARB's, Warn FF kit, OME Springs, 35in Kevlars.
83' CJ8 GM Torch red. 2.5in SkyJacker lift. Very stock.
83' CJ7 Slate Blue Met. 49k miles
04 Wrangler Rubicon. Stock
letchcore is offline   Reply With Quote Quick reply to this message
Unread 11-01-2012, 11:10 AM   #9
Strings72
Strings72's Avatar
Starting the same project but with a ford small block, I'm going to outboard the rear shocks and relocate the upper coil buckets to vertical why'll its apart. I'm also dropping the rear track bar and triangulating a rear 4 link but that's just a preference thing. More pics please!
03 TJ: keeping it low
05 Liberty CRD
96 Dodge 2500 CTD
Check out my build: http://www.jeepforum.com/forum/f22/s...build-2163649/
Strings72 is offline   Reply With Quote Quick reply to this message
Unread 11-01-2012, 12:05 PM   #10
redjeep1992
Hey for the back i've heard most people cutting it off and then using that sections as there rear bumper/rear crossmember that way it won't stick out a huge amount. Anyway good luck on the build I would love to put a CJ grill on my TJ one day
2004 Jeep TJ Rubicon- 2"BB with 32" tires- 2nd jeep (current)
1999 jeep TJ SE-1st Jeep. Sold but not forgotten
1991 nissan axxess-First vehicle RIP
redjeep1992 is offline   Reply With Quote Quick reply to this message
Unread 11-05-2012, 08:36 PM   #11
Ohiojeepguy
Interesting build, are you using the factory CJ chassis wiring harness?
Ohiojeepguy is offline   Reply With Quote Quick reply to this message
Unread 11-05-2012, 08:46 PM   #12
contdevelop
What kind of woman takes a man's jeep?? thats bull****!!!
Coming from someone who owns a TJ and a CJ....in my opinion i dont consider a TJ frame stronger than a CJ frame, considering the CJ frame is rusted out. You could either keep the cj rolling frame all together and adapt the TJ body to fit, or since you have the crappy TJ axles...you could the CJ axles and leaf springs and mount them on the TJ frame. its basically 6 to 1, or half a dozen the other. ballistic fab and other companies sell the suspension brackets so you can fab your own set up.
contdevelop is offline   Reply With Quote Quick reply to this message
Unread 04-07-2013, 11:22 AM   #13
FOXXX0126
any updates?
Built Not Bought #704
FOXXX0126 is offline   Reply With Quote Quick reply to this message
Unread 04-07-2013, 11:44 AM   #14
NKOrangeTJ
Originally Posted by contdevelop View Post
What kind of woman takes a man's jeep?? thats bull****!!!.
That's what I'm saying... You know **** wasn't meant to be after that.... Anyway good luck with the build man, sub'd.
You have to love when things work like they're supposed to.. The only problem is that they never do.
NKOrangeTJ is online now   Reply With Quote Quick reply to this message
Unread 04-07-2013, 03:35 PM   #15
M1TJ838
2009 JK Wrangler
This build is going to be bad***. How much lift are you going to put on it?
M1TJ838 is offline   Reply With Quote Quick reply to this message
