Chris's LJ "Fred" Build - Page 4 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Chris's LJ "Fred" Build
Save on Rancho Products !All Bilstein shocks & struts - Lowest Prices Ever and TERAFLEX JK Speed bump kit AND limiting strap kit!! AT ROC
Unread 03-10-2014, 01:44 PM   #46
OkLaHoMaTJ
What LED mount did you use? How did you wire it in the Jeep?
Looks good!
My Thread - http://www.jeepforum.com/forum/f22/another-lj-rubicon-thread-1516486/
OkLaHoMaTJ is online now   Reply With Quote Quick reply to this message
Unread 03-10-2014, 02:30 PM   #47
KG6KJS
KG6KJS's Avatar
I used the JCR mount, you can use their light or Rigid, etc. The bracket has oval holes on the top, for different lights. The light came with all the wiring and relay but, I cut the wires near the relay and wired the light myself to the switch panel. Here is the link to the bracket...
JCR Offroad Winch Fairlead Light Bracket
2006 Jeep LJ "Fred"
Jeep Build Up <--Click Here
Ram Build Up <--Click Here
KG6KJS is offline   Reply With Quote Quick reply to this message
Unread 03-19-2014, 07:58 PM   #48
KG6KJS
KG6KJS's Avatar
Finally got some more work done in the last couple days.
OX Selectable Locker
OX Air Solenoid Kit
G2 Dana 30 TJ Short 4.56 Ratio Ring & Pinion Set
G2 Dana 30 TJ Master Installation Kit
G2 Dana 44 4.56 Ratio Ring & Pinion Set
G2 Dana 44 TJ Rubicon Master Installation Kit
Eaton Detroit Locker Dana 44 30 Spline 3.92 Up Automatic Locker
Added a lock to my winch cable
RIGID Industries Dually Flood Lights
2006 Jeep LJ "Fred"
Unread 03-19-2014, 08:49 PM   #49
dongalonga
OX lockers are very nice. I had the electrically actuated version in my last TJ.
dongalonga is offline   Reply With Quote Quick reply to this message
Unread 03-19-2014, 09:51 PM   #50
KG6KJS
KG6KJS's Avatar
I was drawn to OX because I can screw in the drive away lock. How did your locker perform?
2006 Jeep LJ "Fred"
Unread 03-19-2014, 10:22 PM   #51
dongalonga
It worked perfectly. Locked and unlocked very fast and stayed locked. What more can you ask for right!?
Unread 03-19-2014, 10:27 PM   #52
KG6KJS
KG6KJS's Avatar
Good to hear, hopefully I get good performance out of mine also.
2006 Jeep LJ "Fred"
Unread 03-19-2014, 10:42 PM   #53
dongalonga
I'm willing to bet you will. My buddy loved the Ox in his 8.8 as well.
Unread 03-20-2014, 05:34 AM   #54
G Beasley
Jeep-Owner.com
G Beasley's Avatar
I had an OX when they first came out and loved it . The cable was the only weak spot as it needed regular adjustment , but with the air setup that is moot .
G Beasley is offline   Reply With Quote Quick reply to this message
Unread 03-20-2014, 09:12 AM   #55
KG6KJS
KG6KJS's Avatar
I can't wait to try it out. But I have to break my gears in first. Plus I haven't mounted my 35 ' s yet because I am waiting on the wheels. So it drives like I am in 4 low all the time and 4 low feels like I could pull out the biggest tree stump in the world out.
2006 Jeep LJ "Fred"
Unread 03-20-2014, 02:17 PM   #56
dongalonga
Good luck you will love it. Just keep the cable in adjustment and gets some graphite cable lube at a motorcycle shop to keep it nice for a long time.
Unread 03-20-2014, 02:47 PM   #57
OkLaHoMaTJ
He's running an air actuated setup. No cable.
Unread 03-20-2014, 03:02 PM   #58
dongalonga
Wow how did I miss that?! Seems like the best of everything then.
Unread 03-20-2014, 03:14 PM   #59
KG6KJS
KG6KJS's Avatar
Yeah its the newer air setup, doesn't use a cable.
2006 Jeep LJ "Fred"
Unread 04-02-2014, 11:39 PM   #60
KG6KJS
KG6KJS's Avatar
Install a TeraFlex Hand Throttle Kit, Easy install.
I also added a Kentrol Windshield Tie Down Kit, my bumpers kept coming off, these bolt in and added a Dorman Windshield Washer Nozzle Kit, I wanted 2 nozzles instead.
2006 Jeep LJ "Fred"
