Chris's LJ "Fred" Build - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Chris's LJ "Fred" Build
FREE, FREE, FREE EVENT!! Save big on Lockers now till Apri2007-2016 Jeep JKU 4" X-series suspension lift **deaThe Cure for your Tie Rod Roll!
Unread 02-06-2013, 10:25 PM   #1
KG6KJS
KG6KJS's Avatar
2006 Jeep Wranlger Unlimited
6-Speed Manual Transmission
Command-Trac NV231 Part-Time 4WD
Stock Dana 30 Front Axle
Stock Heavy Duty Dana 44 Rear Axle
I am starting this build thread late. I am about to change this LJ up dramatically so figured I better start one now.
Mods In Order Of Installation:
(4) Factory Style Rocker Switches (Ebay Seller mlochridge)
Smittybilt Grab Handles (Rear)
4Ft. FireStik CB Antenna
Cobra 29LX Modded CB Radio
Motorola "MBTSN6032A" External CB Speaker
Garmi Nuvi 2797LM
Clarion Surface Mount USB Port "CCAUSB"
LED Dome and Floor Lights (Local Shop)
Quadratec Ultimate All Weather Front and Rear "Tred Lightly Versions"
Poison Spyder LJ Ricochet Rockers
DieHard Platinum Automotive Battery
Poison Spyder LJ Crusher Corners with 3" DeFender Flares
Poison Spyder TJ DeFenders™ - 3" Flares Front Fenders
Poison Spyder DeFender LJ Hood Louver
Drake Off Road Hood Hold Downs
ARB On Board Twin Air Compressor "CKMTA12"
ARB Air Locker Manifold
Centerforce Dual Friction Clutch "DF193890"
Centerforce Throw Out Bearing "N1764"
Mopar Performance Flywheel
Mopar Clutch Hydralic Assembly "52107652AM"
Advanced Adapters Slip Yoke Eliminator "50-7906"
Custom Adams Rear 1310 CV Driveshaft (Ebay Seller adamsdriveshaftoffroadcom)
Truck-Lite Red Supper 44 6" LED Flange Mount Tail lights "44036R"
Truck-Lite Amber Model 33 3/4" LED Marker Lights "33050Y"
Command Amber 3 1/2" Clearance Light "003-1367A"
Warrior Products License Plate Mount with LED Brake Light "2380"
JCR Offroad Wrangler Rear Deluxe Tire Carrier Bumper With 2" Receiver & LED Light Option "SWB-R-DX"
JCR Offroad Frame Tie-Ins "SWB-TI"
RotoPax 2 Gallon Gasoline Pack "RX-2G"
RotoPax 2 Gallon Water Pack "RX-2W"
RotoPax Lox Pack Mounts "RX-LOX-PM"
48" Hi-Lift X-Treme Jack
Hi-Lift Neoprene Jack Cover "NJC"
Hi-Lift Handle Keeper "HK-B"
ARB 10,640lbs D-Ring Shackles ARB207D
Novak Cable Shifter Assembly "SK2XC"
Master Lock 14" Cable Locks "99KADSPT" (Hi-Lift Locks)
Daystar D-ring Isolators "KU70056BK"
JCR Offroad SWB Wrangler Front Stubby Stinger Winch Bumper "SWB-F-STUB-STNG" Courtesy Of Mr_Speakeasy
KC Cyclone Clear LED Lights "KC1350"
Warn M8000-S Winch "87800"
ProLink Loaded Black
Savvy/Currie LJ Johnny Joint 4" Suspension With Aluminum Uppers & Lowers "CE-9801HSR" Call Savvy For JeepForum Discount
Currie Antirock Front Sway Bar kit "CE-9900"
Currie Currectlync HD Tie Rod & Drag Link System "CE-9701"
Rancho RS5000 Steering Damper "RS5407"
Currie Johnny Joint Rear Trac Bar "CE-9120R"
Currie Rear Shock Extensions "CE-9601"
SpiderTrax 1.25" Thick Wheel Spacers "WHS002"
Aurora 10" Dual Row LED Light Bar "LEDBAR10" From JCR Offroad, Front Bumper
JCR Offroad Winch Fairlead Light Bracket
OX Selectable Locker "D30-373-27-AIR"
OX Air Solenoid Kit "OXA1002"
G2 Dana 30 TJ Short 4.56 Ratio Ring & Pinion Set "G/22-2031-456"
G2 Dana 30 TJ Master Installation Kit "G/235-2031"
G2 Dana 44 4.56 Ratio Ring & Pinion Set "G/22-2033-456"
G2 Dana 44 TJ Rubicon Master Installation Kit "G/235-2045"
Eaton Detroit Locker Dana 44 30 Spline 3.92 Up Automatic Locker "EAT187SL16C"
Rigid Industries Dually 2x2 LED Flood Lights "20211" Front Bumper
TeraFlex Hand Throttle Kit "4870400"
Kentrol Stainless Steel Windshield Tie Down Kit "30503"
Dorman Windshield Washer Nozzle Kit "47137"
(5) 315/75/R16 Goodyear MTR With Kevlar Tires
(5) Pro Comp La Paz Series 29, 16X8 Satin Black with Machine Lip "5129-6865"
Rigid Industries Dually 2x2 LED Flood Lights "20211" Reverse Lights
Poison Spyder TJ Light Bar Mount - 50" LED "45-28-R54"
Poison Spyder TJ Lower A-Pillar Light Mounts "45-28-RDA2"
Aurora 50" D-Series LED Light Bar, Combo Beam Pattern "ALO-50-P4E4D"
(2) 7" Aurora R-Series LED Light, Combo Beam Pattern "ALO-R-P7E7B"
Poison Spyder TJ/LJ Steering Box Skid
Ricochet Offroad Rock Light Mounting Brackets "999-RL"
Vision X Superwhite LED Strobe and Rock Light Kit "HIL-STW"
Currie Enterprises LJ (Unlimited) 4" Rear Coil Springs "CE--9131RH3P"
TrekArmor Black On Black Front Seat Covers "TATJSC0306FP"
TrekArmor Black On Black Rear Seat Cover "TATJSC0306RB"
Bestop Trektop Black Diamond NX Complete Replacement Soft Top "56821-35"
Rock Hard 4X4 Bolt-In Ultimate Sport Cage "RH-1001"
SoundOff Universal LED Dome Light "ECVDMLTAL00"
JCR Offroad Tailgate Cover Plate "TJ-TGC"
RAM Mounts Strap Clamp Roll Bar Mount For Garmin/GoPro "RAM-B-149Z-2-GOP1U"
Ram Mounts For GPS "RAM-HOL-GA61LU"
UCF Hood Mounting Brackets for 20" LED Light Bar "UCF447"
AMI Billet Fuel Door "ASM6031K"
(2) Front Fox Racing Factory Series Shocks With Adjustable Compression Dampener "980-02-302"
(2) Rear Fox Racing Factory Series Shocks With Adjustable Compression Dampener "980-02-303"
JKS Adjustable Bump Stops "JKS-1100"
(2) Truck-Lite LED Headlights "27270C"
(2) Truck-Lite Red Running Lights "36115R"
(2) Truck-Lite Amber Running Lights "36115Y"
Aurora S1-Series 20" - Single Row Amber LED Light Bar
(2) Rigid Industries SR-M Amber Flood Lights - Hood
(2) Truck-Lite Mounting Flange Covers "44705" (Bezel For LED Tail Lights)
Mishimoto Performance Aluminum Radiator "M/AMMRAD-WRA-87"
FlowKooler High Flow Water Pump "BRS1750"
Mishimoto Thermostat "M/AMMTS-WRA-03L"
Canton Racing Coolant Recovery Tank "CTR-80-291"
Mean Green High-Output Alternator "MG1380"
Derale Waterproof Electric Fan Kit "20162Q"
Hesco High Flow Thermostat Housing "HFTH"
Crown Performance 4" Stainless Steel Brake Line Extensions "JEEP17FR04"
JKS 1 1/4" Body Lift "9904"
JKS 1" Engine Mount Lift "8100"
UCF 1/4" Steel Ultra High-Clearance Cover Skid Plate System
UCF LOPRO Transmission Mount
PowerTank 10lb. Package B System "AASPT10-5250-BK"
(3) Power-Flo II Coupler "ALA-805"
(2) ViAir 2.5 Gallon 200 PSI Tanks "V/A91028"
Mopar Inner Shift Boot "52059661AC"
Dynamat - I used 18 Square Feet to do the Full Floor Tub, No More Hot Feet
Banks Sidewinder Turbo System "24244"
Banks IQ 2.0 With DynaFact "61196"
Banks TorqueTube Header "51306"
Spectra Oil Pan "CRP06C" Darn Rocks
Alpine CD receiver "CDE-HD149BT"
(4) Alpine 5-1/4" 2-Way Type-R Series Component Car Speaker "SPR-50C"
Alpine Single 10" Powered Subwoofer "PWA-S10V"
Alpine Power Pack "KTP-445A"
SiriusXM Tuner "SXV300V1"
Mods Installed Then Removed:
TeraFlex 2" Budget Boost Lift Kit - Sold
Bilstein 5100's Series Shocks - Sold
Color Matched Flares and Bumpers Paint Damaged- Sold
Teraflex CB D.S.Taillight Antenna Mount - Forsale
KC HiLiTES SlimLite 100W Driving Lights "On Front Bumper" - Sold
Jeep Wrangler Rubicon Moab Wheels Painted Black - Sold
Goodyear Wrangler MTR Kevlar 265/75-16 - Sold
KC HiLites Windshield Frame Mount Brackets - Sold
KC HiLiTES SlimLite 130W Long Range Lights "On Windshield Mounts" - Sold
Currie Enterprises TJ 4" Rear Coil Spring "CE-9131RH2P" - Sold
Bestop Black Header Windshield Channel "51238-01" - Sold
Bestop Header-style Safari Bikini Black Diamond Top "52544-35" - Sold
Mopar Factory Soft Top and Hardware Back Zipper Is Toast - Sold
Bestop Black Diamond Windjammer Wind Break "80032-35" - Sold
Bestop Black Diamond Duster Deck Cover "90024-35" - Sold
Jeep Stock Steering, Control Arms, Springs, Front & Rear Diffs, Gears - Sold
Tuffy Single Compartment Overhead Console - Forsale $50 Local Pickup Only
AutoPal E4 Headlights (Ebay Seller rimiinc) - Free If You Need, Local Pickup Only
Stock Alternator - Forsale $50 Local Pickup Only
Stock Radiator - Recycled
Coolant Tank - Free If You Need, Local Pickup Only
Stock Fan Shroud - Free If You Need, Local Pickup Only
Clutch & Fan - Free If You Need, Local Pickup Only
Water Pump - Recycled
New Hesco High Flow Thermostat Housing - Free If You Need, Local Pickup Only
Smittybilt Grab Handles (Front) - Free If You Need, Local Pickup Only
New Centerforce Flywheel - Forsale $100 Local Pickup Only
Stock Oil Pan -Recycled
Stock Fuel Pump - Free If You Need, Local Pickup Only
Stock Air Box All The Way To Throttle Body - Free If You Need, Local Pickup Only
Stock Fuel Tank Skid - Recycled
4x6" to 5.25" Dash Speaker Adapters (Ebay Seller floridahandmadecreations1) - Free If You Need, Local Pickup Only
Pioneer "DEH-X9500BHS" Radio - Free If You Need, Local Pickup Only
(4) Pioneer "TS-A1305C" 5.25 Speakers - Free If You Need, Local Pickup Only
Mods In Garage Waiting To Be Installed:
Currie Front End Housing Johnny Joint Kit "CE-9102K" (Need To Find somebody Who Can Weld)
Currie Front Lower Control Arm Brackets "CE-7111" (Need To Find somebody Who Can Weld)
Currie Lower Control Arm Skids "CE-9085MS" (Need To Find somebody Who Can Weld)
Samco XDB Silicone Hoses "TCS458CXDB"
Rokmen Fuel Tank Skid "RM21001"
Bosch Fuel Pump "67756" Dropping Tank Anyway - When In Rome
sPod 8 Circuit SE- Special Edition System with Touchscreen "8-700-TS-TJ"
Future Mods
Banks Power - Intercooler
Rebuilt Forged Engine
Build Hours:
Personal Garage Hours = 328 = Blood, Sweat, Tears
Pro Shop Hours = 9 = Nervousness
Price: NOT FOR SALE!
Parts Approx= $33,653
Labor Approx $840
Vehicle Price = $15,917
Purchase Mileage = 89,000
Current Mileage = 123,500
Total Spent = $50,410
Worth Approx = $27,500 You be the judge?
Good Times = $Priceless
Mods Installed Then Broken = Fail:
Smittybilt Adjustable Door Strap "769401" (Seems Ripped, Poor Quality)
Rancho RS9000XL Rear Shocks "RS999256" (Bump Stops Not Set Right, My Bad)
Rancho RS9000XL Front Shocks "RS999255" (Bump Stops Not Set Right, My Bad)
UltraGauge OBDII Scan Tool and an Information center (Screen Stopped Working)
Mopar Inner Shift Boot "52059661AC" (Ripped The Boot When Installing Tummy Tuck,My Bad)
Trasharoo Spare Tire Trash Bag "CTPGEN2_BLACK" (Plastic Clips Broke)
Trails Completed:
8x Azusa Canyon Obstacle Course & Area
5x LittleRock OHV Area Trails
3x El Mirage Area Trails
2x Lytle Creek Area Trails
1x Skyline Divide Trail
4x Cleghorn Ridge Trail
6x Gold Mountain Trail
2x Holcomb Creek Trail
3x John Bull Trail
1x Horsethief Flat Trail
3x Little John Bull Trail
3x Cougar Buttes, Bullfrog/Cakewalk
1x Onyx Summit Trail
1x Tip Top Mountain Trail
Last edited by KG6KJS; 07-23-2015 at 09:59 PM.. Reason: Some Additions, You Understand Right?
KG6KJS is offline   Reply With Quote Quick reply to this message
Unread 02-06-2013, 10:27 PM   #2
KG6KJS
KG6KJS's Avatar
Just got these in the mail. Just have to test fir and send them off Powdercoat.
Unread 04-24-2013, 12:04 AM   #3
KG6KJS
KG6KJS's Avatar
Poison Spyder DeFender™ Full Length Side Plates
ARB On Board Twin Air Compressor CKMTA12
Unread 04-24-2013, 09:01 AM   #4
vanillathrilla
How do you like those fenders? Do they include the inner fender?
'99 TJ Sport | Rampage Frameless | 33x12.50x15 Goodyear MTR/K's | Poweraid TBS | Flowmaster 40 series | Herculined | 15% tint | LED interior lighting | AtoZ front/rear bumper | AtoZ tube rocker guards | Kenwood Excelon KDC-X993BT | Kicker 6.5's in soundbar | Alpine Type-R 4x6's in dash.
vanillathrilla is offline   Reply With Quote Quick reply to this message
Unread 04-24-2013, 09:07 AM   #5
dayriesw
dayriesw's Avatar
1987 MJ Comanche
Looks gooooood.
06 WK Hemi Overland.. stock DD
87 MJ project on 37s.. Waggy axles, 6 speed, flipped D300 and Bobbed 10" so far. 3 link coming soon.
Sold:
05 LJ.. Low and on 37s
79 FSJ.. 360/4speed on 38s
85 CJ-7 Renegade
Buy my AEV Pintler TJ Beadlocks. See the classifieds.
dayriesw is offline   Reply With Quote Quick reply to this message
Unread 04-24-2013, 11:05 AM   #6
rusty762
rusty762's Avatar
Nice rig man, the PSC front fenders are by far my favorite.
Rusty
If I had eight hours to chop down a tree, Id spend six sharpening my axe.- Abraham Lincoln
My Build
My Videos
My Work
Have you hugged a Firefighter today?
rusty762 is offline   Reply With Quote Quick reply to this message
Unread 04-24-2013, 11:47 AM   #7
KG6KJS
KG6KJS's Avatar
Thanks, after watching how well PSC parts perform on the trails, the choice was easy. I still need to install the rest.
Sent from my Galaxy Nexus using JeepForum App
Unread 04-24-2013, 11:50 AM   #8
KG6KJS
KG6KJS's Avatar
They have the inner fender option. I choose not to install them because I rather have the tires rub then loose all the room under the hood. That is I assume tires will rub when I get bigger tires.
Unread 04-24-2013, 12:48 PM   #9
yellow_snocone
Nice LJ Any sweet Cali off-road pictures?
Military Jeepers
S.W. New Mexico region
[URL="http://www.jeepforum.com/forum/f22/chesters-tj-build-1420405/"][COLOR="Green"]Chester TJ build[/COLOR][/URL]
[URL="http://www.jeepforum.com/forum/f330/rubicon-trail-august-9th-11th-2014-a-1550022/"][COLOR="Blue"]2014 JF RUBICON TRIP[/COLOR][/URL]
yellow_snocone is offline   Reply With Quote Quick reply to this message
Unread 04-24-2013, 03:28 PM   #10
1320quick
I like it! Some very cool upgrades so far....
My 03 Rubicon build thread ---> http://www.jeepforum.com/forum/f22/1320quicks-03-rubicon-build-1504699/
1320quick is offline   Reply With Quote Quick reply to this message
Unread 04-24-2013, 07:18 PM   #11
G Beasley
Nice looking LJ , keep up the good work .
G Beasley is offline   Reply With Quote Quick reply to this message
Unread 04-24-2013, 07:32 PM   #12
MountainMan864
That is one nice clean LJ.
MountainMan864 is offline   Reply With Quote Quick reply to this message
Unread 04-27-2013, 09:01 AM   #13
Scram
That's sharp....any updated pics?
Scram is offline   Reply With Quote Quick reply to this message
Unread 04-28-2013, 11:05 PM   #14
SkyHigh
I thought the inner fender was only available for the defender xc at this time?
- 97 Sahara -
- 13 Grand Cherokee Trail Hawk Hemi -
SkyHigh is offline   Reply With Quote Quick reply to this message
Unread 05-01-2013, 08:48 PM   #15
KG6KJS
KG6KJS's Avatar
I have the prototype, inner fenders for Non-XC fenders.
