Chester's TJ build - Page 54 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Chester's TJ build
Ruffstuff 10 year saleBDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!
Unread 12-22-2013, 07:52 PM   #796
Hendrix
TJOTY 2013
Hendrix's Avatar
Originally Posted by AngryTJ
why not just shorten the upper arms so the brackets sit on the truss just fine?
Yes, this is the best option.
Hendrix is offline   Reply With Quote Quick reply to this message
Unread 12-22-2013, 08:11 PM   #797
yellow_snocone
The over hang isn't that bad I'll post a picture showing the other side. It's 1 1/8 at the one corner hanging over.
Military Jeepers
S.W. New Mexico region
[URL="http://www.jeepforum.com/forum/f22/chesters-tj-build-1420405/"][COLOR="Green"]Chester TJ build[/COLOR][/URL]
[URL="http://www.jeepforum.com/forum/f330/rubicon-trail-august-9th-11th-2014-a-1550022/"][COLOR="Blue"]2014 JF RUBICON TRIP[/COLOR][/URL]
yellow_snocone is offline   Reply With Quote Quick reply to this message
Unread 12-22-2013, 10:25 PM   #798
yellow_snocone
Driver side tacked up
Uppers are looking good
Not a bad as it looked
Military Jeepers
Unread 12-22-2013, 10:50 PM   #799
gst95dsm
Chop, Wheel and Rebuild..
gst95dsm's Avatar
Oh yeah dude that's just fine. It's gonna be hard for me not to redo my rear links when I finish up the axle. I figure if I already have all the joints bought by then, that's the major cost out of the way so why not. Looking forward to it. Looking good though man. Just triple check every possible source of interference before you burn.
My Build Thread
gst95dsm is offline   Reply With Quote Quick reply to this message
Unread 12-22-2013, 11:00 PM   #800
yellow_snocone
Definitely I dont want any issues. I think its the right thing to do to for the axle swap, best time to do it.
Military Jeepers
Unread 12-23-2013, 07:13 PM   #801
yellow_snocone
Ok guys I made some adjustments to the uppers some where down the line I did something wrong and couldnt put the other control arm back in so cut off the brackets and redid the uppers together to make sure things were good.
I checked all my clearances and it seems the upper hit the tube right at the bumpstops, so a hard hit is going to do some damage. The lowers have some more room left until they hit the frame.
Military Jeepers
Unread 12-23-2013, 10:49 PM   #802
aw12345
Pretty common for the upper links to hit the tub. It either self clearances or you do some sheetmetal surgery
aw12345 is offline   Reply With Quote Quick reply to this message
Unread 12-23-2013, 10:51 PM   #803
yellow_snocone
What's the amount of worrying I should have for self clearance lol. I'm feeling to lazy to work the sheetmetal.
Military Jeepers
Unread 12-23-2013, 11:02 PM   #804
gst95dsm
gst95dsm's Avatar
Looks like you could easily shave 1/8" off the top of the link mounts…. and then just let it self clearance. If they hit well before the jounce you need to add bumpstop. But if you can take the jounce out and only have about a 1/2" interference or so I'd let it self clearance if it wants to. Getting to FULL compression in the rear might happen in some whoops, but it's not going to constantly be hitting during daily driving or rock crawling.
My Build Thread
Unread 12-23-2013, 11:11 PM   #805
yellow_snocone
That's a good point Nate. I think it will be fine. I still have almost an inch and a half until the uppers in the axle contact to crossmember
Military Jeepers
Unread 12-23-2013, 11:11 PM   #806
aw12345
Nate looks like his upper links will hit the floor first right behind the frame mounts. With the longer arms its almost impossible for that not to happen when you use enough link seperation
Unread 12-23-2013, 11:14 PM   #807
gst95dsm
gst95dsm's Avatar
I'd worry about that even less! haha. That'll just make a nice round link shaped indentation.
My Build Thread
Unread 12-23-2013, 11:17 PM   #808
yellow_snocone
Then I guess no worries are too be had. I don't mind a little self clearance just as long nothing major occurs I'll be burning everything in tomorrow
Military Jeepers
Unread 12-24-2013, 05:53 PM   #809
yellow_snocone
I started working on the tank placement. I had to cut some of the tub support to get the fuel pump to clear. I'm going to have to make some brackets for the front mounts since they dont reach the frame. All and all I like where it is and I have some more room from the axle. I may continue work on the rear mount member that tie the tank to the bumper tonight.
Fill tube opening just barely clears
Nice and level
Military Jeepers
Unread 12-25-2013, 10:22 PM   #810
yellow_snocone
Merry Christmas everyone and Happy New year.
Got some work done today all brackets frame/axle all welded up
Got the rear fuel tank mount welded and drilled as well as the front mounts
Good old cardboard template
Military Jeepers
black tj , military jeep , work in progress
