Chester's TJ build - Page 52 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Chester's TJ build
WIN a Rough Country Forged Track Bar - ExtremeTerrain!1987-2016 Wrangler Jammock Black 2.0 Jeep Hammock (YJ, TJ Rancho rockGEAR promotion gear from January 1-February 29,
Unread 12-17-2013, 08:52 PM   #766
aw12345
If you manage to become a container crane operator at LA harbor you would be set for the rest of your life
aw12345 is offline   Reply With Quote Quick reply to this message
Unread 12-17-2013, 08:55 PM   #767
yellow_snocone
I'll be in michigan after my service so maybe I can work a port there.
Military Jeepers
S.W. New Mexico region
[URL="http://www.jeepforum.com/forum/f22/chesters-tj-build-1420405/"][COLOR="Green"]Chester TJ build[/COLOR][/URL]
[URL="http://www.jeepforum.com/forum/f330/rubicon-trail-august-9th-11th-2014-a-1550022/"][COLOR="Blue"]2014 JF RUBICON TRIP[/COLOR][/URL]
yellow_snocone is offline   Reply With Quote Quick reply to this message
Unread 12-17-2013, 09:01 PM   #768
yellow_snocone
Just need to go to crane school and I'll be set
Military Jeepers
Unread 12-18-2013, 09:40 PM   #769
yellow_snocone
Some more progress slow but steady
getting ready for the 4 link
And rear bumper
Military Jeepers
Unread 12-18-2013, 09:51 PM   #770
Hendrix
TJOTY 2013
Hendrix's Avatar
Originally Posted by yellow_snocone
Some more progress slow but steady getting ready for the 4 link And rear bumper
What kind of rear bumper?
Hendrix is offline   Reply With Quote Quick reply to this message
Unread 12-18-2013, 10:03 PM   #771
gst95dsm
Chop, Wheel and Rebuild..
gst95dsm's Avatar
Looks good Kyle, It should come together quick after you get the rear of the frame buttoned up so you can mount the tank and see where you're at with everything.
My Build Thread
gst95dsm is offline   Reply With Quote Quick reply to this message
Unread 12-18-2013, 10:10 PM   #772
yellow_snocone
Just some 4x4 square tubing with some slight redesigning
Military Jeepers
Unread 12-18-2013, 10:13 PM   #773
Hendrix
TJOTY 2013
Hendrix's Avatar
I see, 4x4? I was going to mention trimming down the bottom of the frame and boxing it flat to accept a 2x3 box with redesigned ends.
Unread 12-18-2013, 10:13 PM   #774
yellow_snocone
I cant wait to have everything buttoned up and rolling again
Military Jeepers
Unread 12-18-2013, 10:16 PM   #775
yellow_snocone
Now that you mention it I forgot I got 2x3 for the bumper the 4x4 tubing was for something else I thought about working on . I was thinking of having it flush with the frame and adding some 3/16 to the bottom to strengthen it. I do like your idea of cutting the frame and boxing it in, that might be a cleaner look.
Military Jeepers
Unread 12-19-2013, 10:57 AM   #776
kyle_craig
2x3 with the frame tapered and boxed to fit would look neat as hell.
kyle_craig is offline   Reply With Quote Quick reply to this message
Unread 12-19-2013, 11:43 AM   #777
gst95dsm
gst95dsm's Avatar
There is still a body mount to contend with. I'd at least make it wide enough to cover that so you can make a nice solid body mount tied into the rear crossmember.
My Build Thread
Unread 12-19-2013, 05:38 PM   #778
yellow_snocone
The bumper will be roughly 48" so I'll have room for the body mount plate. I'm still unsure of the design for the bumper. I definitely want to go for a functional design.
Military Jeepers
Unread 12-19-2013, 06:44 PM   #779
yellow_snocone
I played with the 4 link cal. Here are my results:
Military Jeepers
Unread 12-19-2013, 08:29 PM   #780
aw12345
Try to make the uppers adjustable on the frame side , so you can change anti squad between 75% to 100% Most of the upper frame mount brackets come with multiple holes. Is it do able to place the frame side mounts where you have them
black tj , military jeep , work in progress
