Chester's TJ build - Page 51 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Chester's TJ build
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineWIN a Rough Country Forged Track Bar - ExtremeTerrain!1987-2016 Wrangler Jammock Black 2.0 Jeep Hammock (YJ, TJ
Unread 12-16-2013, 06:20 PM   #751
yellow_snocone
I was thinking about that at work today. I can move the axle forward about a half inch to allow more clearance. I might want to buy one before I button everything back up
Military Jeepers
S.W. New Mexico region
[URL="http://www.jeepforum.com/forum/f22/chesters-tj-build-1420405/"][COLOR="Green"]Chester TJ build[/COLOR][/URL]
[URL="http://www.jeepforum.com/forum/f330/rubicon-trail-august-9th-11th-2014-a-1550022/"][COLOR="Blue"]2014 JF RUBICON TRIP[/COLOR][/URL]
yellow_snocone is offline   Reply With Quote Quick reply to this message
Unread 12-16-2013, 06:36 PM   #752
aw12345
That's what I was getting at, would suck when everything is done and you destroy the diff cover, buy one that can withstand the rigors of wheelin. but doesn't clear the tank
aw12345 is offline   Reply With Quote Quick reply to this message
Unread 12-16-2013, 06:48 PM   #753
yellow_snocone
Good call art
Military Jeepers
Unread 12-16-2013, 07:01 PM   #754
aw12345
Your welcome, sometimes it helps to have been there done that
Unread 12-16-2013, 07:15 PM   #755
yellow_snocone
Definitely I prefer learning from others first before I find out the hard way
Military Jeepers
Unread 12-16-2013, 08:53 PM   #756
yellow_snocone
Some support to add strength to the crossmeber
Started work on the axle
Military Jeepers
Unread 12-16-2013, 09:05 PM   #757
aw12345
Have you played with mr 4 link calculator yet?
Now is a good time to figure out mount placement, link length and angle. You get that right and those Moab ledges become cake
Unread 12-16-2013, 09:09 PM   #758
yellow_snocone
Not yet but after everything is cleaned up I going to measure my mount placement and throw the numbers in and see what needs adjustment.
From your views what are the best numbers to shoot for Art?
Military Jeepers
Unread 12-16-2013, 10:37 PM   #759
aw12345
Connor loves this stuff, so does Mikey. I would try and shoot for adjustable anti squad between 70 to 100% and try to get zero roll steer or close to that. That should make for a Jeep that climbs ledges really well with minimum wheel hopping. I have been pretty happy with numbers in that neighborhood
Unread 12-16-2013, 10:47 PM   #760
JJeeper09
I'm with Art, having some sort of adjustability is good, you may fine preference in a lower or higher AS.
Look foreword to progress
[URL="http://www.jeepforum.com/forum/f22/project-do-right-1147962/"][B]Rubicon Build[/B][/URL]
JJeeper09 is online now   Reply With Quote Quick reply to this message
Unread 12-16-2013, 10:55 PM   #761
yellow_snocone
I like the idea of adjustability as well helps me find that prefect setting to my liking
Military Jeepers
Unread 12-17-2013, 01:43 PM   #762
yellow_snocone
After some mild research I think getting a riddler diff cover for the 8.8 is the plan. From what I've found it provides better clearance then the stock diff cover.
Stock 3" from the matting surface
Riddler 2 7/8" from the matting surface
If push comes to shove I can move the axle forward an inch
Military Jeepers
Unread 12-17-2013, 06:13 PM   #763
yellow_snocone
Off topic but I had to do show and tell from work
Military Jeepers
Unread 12-17-2013, 08:44 PM   #764
aw12345
Man nice toys, I used to love screwing around with cranes and heavy equipment
Unread 12-17-2013, 08:49 PM   #765
yellow_snocone
Best part of my Job, plus good money in the civilian world.
Military Jeepers
black tj , military jeep , work in progress
