Chester's TJ build - Page 46 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Chester's TJ build
Rough Country Lift Kits and Parts!Ruffstuff 10 year saleSmittybilt XRC M.O.D Bumper and Brush Guard
Unread 12-03-2013, 10:55 PM   #676
gst95dsm
Chop, Wheel and Rebuild..
gst95dsm's Avatar
It's not a big deal though man, You did a good job integrating the two, I wouldn't fuss with it.
My Build Thread
gst95dsm is offline   Reply With Quote Quick reply to this message
Unread 12-03-2013, 11:11 PM   #677
yellow_snocone
Your probably right Nate I'm sure it's fine
Military Jeepers
S.W. New Mexico region
[URL="http://www.jeepforum.com/forum/f22/chesters-tj-build-1420405/"][COLOR="Green"]Chester TJ build[/COLOR][/URL]
[URL="http://www.jeepforum.com/forum/f330/rubicon-trail-august-9th-11th-2014-a-1550022/"][COLOR="Blue"]2014 JF RUBICON TRIP[/COLOR][/URL]
yellow_snocone is offline   Reply With Quote Quick reply to this message
Unread 12-03-2013, 11:11 PM   #678
JJeeper09
I had A to Z on my last tj. Yes they sit lower but it's due to the bottom of the tub. I think you should extend the rockers and just cut the rocker to fit. Like savvy and other corners do.
[URL="http://www.jeepforum.com/forum/f22/project-do-right-1147962/"][B]Rubicon Build[/B][/URL]
JJeeper09 is offline   Reply With Quote Quick reply to this message
Unread 12-03-2013, 11:16 PM   #679
gst95dsm
gst95dsm's Avatar
That's ALOT of work for a small cosmetic issue. We are all hyper critical when were building. When it's all together (and black) no one will care.
My Build Thread
Unread 12-03-2013, 11:44 PM   #680
JJeeper09
I know. But having an extended rocker may be worth it, with a stretch. But I understand. I'm just saying an extended rocker would look and function better..
Unread 12-04-2013, 12:11 AM   #681
Imped
Imped's Avatar
That would bug the piss out of me, just my opinion. I'd go with LJ-length sliders and blank corners for a very clean end result.
OlllllllO
Float Test Build
IndyORV
Imped is offline   Reply With Quote Quick reply to this message
Unread 12-04-2013, 04:49 AM   #682
yellow_snocone
Honestly it's not too bad but I may modify something to make it flush. If I were to do it all over again I would do the same thing but measure the distance for LJ rockers and have Bryce from MoabFab make the adjustment with the final cut and get some LJ sliders. I'm very happy with my corners and was aware they were going to need some adjusting in this area since I ordered them without pre cuts for the sliders.
Military Jeepers
Unread 12-04-2013, 11:22 AM   #683
kyle_craig
Originally Posted by yellow_snocone View Post
Another slight update.
Very nice looking cut. As far as the gap goes, I say just run it unless it really bugs you that badly. Adding an inch of 3/16" to the bottom of the corner would be a cheap easy fix if it really bugs you. Otherwise, I don't think it will be that glaring once its all painted and on the Jeep.
kyle_craig is offline   Reply With Quote Quick reply to this message
Unread 12-04-2013, 09:41 PM   #684
aw12345
I agree, just extend the bottom of those corners a bit and nobody would ever know the difference, Or if the slider comes up a bit short get some angle and extend it. Adding some steel isn't a big deal period, just a lil time with the glue gun and it's all better
aw12345 is offline   Reply With Quote Quick reply to this message
Unread 12-06-2013, 11:23 AM   #685
yellow_snocone
Ya that's the idea just add to the corners
Military Jeepers
Unread 12-07-2013, 07:44 AM   #686
jermeyg
Hey man nice work so far!
jermeyg is offline   Reply With Quote Quick reply to this message
Unread 12-07-2013, 07:50 AM   #687
yellow_snocone
Thanks Jeremy
Military Jeepers
Unread 12-07-2013, 05:21 PM   #688
yellow_snocone
Little more work and prep. Evap canister deleted
Now to decide where will be the best place to locate it.
EDIT: Heres a good write to look through for the Evap canister
http://www.rubiconownersforum.com/fo...-pictures.html
Military Jeepers
Unread 12-07-2013, 05:26 PM   #689
Imped
Imped's Avatar
Mine is bolted to the bottom of the tub inside of the frame rail. Hidden, protected and clean.
OlllllllO
Float Test Build
IndyORV
Unread 12-07-2013, 05:27 PM   #690
yellow_snocone
Thats a good idea. I'm sure I'll have plenty of room there with the new fuel tank.
Military Jeepers
black tj , military jeep , work in progress
