Chester's TJ build - Page 39 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Chester's TJ build
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 09-07-2013, 09:22 PM   #571
yellow_snocone
Thanks Art I hope your out having a great time
Military Jeepers
S.W. New Mexico region
[URL="http://www.jeepforum.com/forum/f22/chesters-tj-build-1420405/"][COLOR="Green"]Chester TJ build[/COLOR][/URL]
[URL="http://www.jeepforum.com/forum/f330/rubicon-trail-august-9th-11th-2014-a-1550022/"][COLOR="Blue"]2014 JF RUBICON TRIP[/COLOR][/URL]
yellow_snocone is offline   Reply With Quote Quick reply to this message
Unread 09-07-2013, 09:38 PM   #572
aw12345
I sure did 3 days of great wheelin fun
aw12345 is offline   Reply With Quote Quick reply to this message
Unread 09-14-2013, 03:44 PM   #573
yellow_snocone
Some update I replaced my winch line with some 3/8 synthetic line and started building the frame section add-ons
Military Jeepers
Unread 09-14-2013, 08:06 PM   #574
gst95dsm
Chop, Wheel and Rebuild..
gst95dsm's Avatar
Looks good Kyle, now do some welding on those suckers.
My Build Thread
gst95dsm is offline   Reply With Quote Quick reply to this message
Unread 09-14-2013, 08:15 PM   #575
kyle_craig
I'm looking forward to seeing those the frame section add-ons burned in!
kyle_craig is offline   Reply With Quote Quick reply to this message
Unread 09-14-2013, 10:09 PM   #576
gspup
Jealous
gspup is offline   Reply With Quote Quick reply to this message
Unread 09-14-2013, 10:28 PM   #577
gst95dsm
gst95dsm's Avatar
Inspiration!
My Build Thread
Unread 09-15-2013, 12:03 AM   #578
yellow_snocone
I'm going to have to wait on welding them until Monday hopefully I need some gas.
Military Jeepers
Unread 09-19-2013, 09:31 PM   #579
yellow_snocone
Got some work done tonight
One frame section ready
I got my 4 link brackets done as well
Welds are looking better
Military Jeepers
Unread 09-19-2013, 10:18 PM   #580
MO2500
MO2500's Avatar
Just a few words of advice if I may.
Slow down and let the bead fill in. That's the hardest thing for most when learning is to just slow your movements down and don't move quickly with your pattern, it will give you a more uniform looking bead and you will get better penetration into the material. You want the edge of the bead to be more of a straight line instead of jagged look. I still find myself moving too quickly sometimes and have to remind myself to just slow it down. The slower and steadier, the better.
Are you just advancing and pausing, advancing and pausing or are you zig zagging/making circles/ect.? If advancing and pausing, slowing down will help the most. If you are Zig Zagging it looks like you need to pause a bit longer on the edges of the zig zag and that will slow you down as well.
It also looks like you started to move onto one piece at the end of your weld instead of filling the joint between both pieces. You can see the weld is just touching the piece on the left and not really penetrating so watch your tip angle into a 90* fillet like that. You want to be at a 45* to both pieces being welded together and keep your puddle centered in the joint. It will come with practice. Also, not sure what hood you are using but I had trouble keeping on a straight line with a cheap hood, once I invested in a good 3M speedglass it was like night turned into day. It's incredible the difference when you can see not only the arc, but the joint turning molten and fusing together.
Keep it up!
ODonnell Motorsports
Build Thread
Instagram: @omsmike
MO2500 is offline   Reply With Quote Quick reply to this message
Unread 09-19-2013, 10:36 PM   #581
yellow_snocone
Thanks for the advice Mike. I've been doing the C pattern. And for my helmet I'm not sure if it's bad because I can see the puddle it's just my nozzle was at a weird angle. I may try my friends helmet and see if there's a difference. The helmet came with my welder so I'm unaware of what type it is. What are some of the recommend patterns for each type of welding setup ie fillet and flat surfaces?
Military Jeepers
Unread 09-19-2013, 10:56 PM   #582
gst95dsm
gst95dsm's Avatar
I like a cursive e for fillet, pausing a bit more on the top and going a little quicker on the bottom (gravity), this is with the part sitting right in front of me.... out of position I just do my best to maintain consistently sized circles staying at the leading edge of the puddle. I'm not really qualified to give welding advise...... but that's my preference.
My Build Thread
Unread 09-19-2013, 11:06 PM   #583
yellow_snocone
I'll cut up some more scrap and try some things. I'm sure if I knew what a perfect/good weld from me would look like I can practice to match that speed/pattern everytime.
Military Jeepers
Unread 09-20-2013, 07:36 AM   #584
jermeyg
Check out YouTube videos by welding tips and tricks he shows you what a good weld looks like under the hood and outside the hood.
jermeyg is offline   Reply With Quote Quick reply to this message
Unread 10-01-2013, 09:22 PM   #585
yellow_snocone
Small update
Jeep is going to be on the back burner for a bit. I have a bathroom to finish.
Military Jeepers
black tj , military jeep , work in progress
