Chester's TJ build - Page 37 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Chester's TJ build
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 08-26-2013, 10:17 PM   #541
gspup
Originally Posted by yellow_snocone
Getting some practice in
Dont mind the splatter I'm using up my flux instead of burning my gas
Burn your gas, it's worth the practice. You will learn to loathe flux ! Keep practicing and you'll be confident in no time.
gspup is offline   Reply With Quote Quick reply to this message
Unread 08-26-2013, 10:28 PM   #542
brplatz
X2 flux sucks haha
The Second Amendment is in place in case they ignore the others.
[QUOTE=mrblaine;14089403]That's like saying you wish your boyfriend was a bit less gay.[/QUOTE]
[COLOR="Blue"]MOΛΩN ΛΑΒΕ[/COLOR]
[URL="http://www.nmoffroad.com"][COLOR="DarkRed"]NMOffroad[/COLOR][/URL]
[URL="http://www.overland-motorsports.com/"][COLOR="Gray"]Overland Motorsports[/COLOR][/URL]
[COLOR="DarkSlateBlue"][URL="http://www.jeepforum.com/forum/f22/brplatzs-tj-opv-1240947/#post13888971"]My Build[/URL][/COLOR]
brplatz is offline   Reply With Quote Quick reply to this message
Unread 08-26-2013, 10:30 PM   #543
MO2500
MO2500's Avatar
X3
Much easier to practice and learn puddle control when you can actually see the puddle! Flux sucks!
ODonnell Motorsports
Build Thread
Instagram: @omsmike
MO2500 is online now   Reply With Quote Quick reply to this message
Unread 08-26-2013, 10:39 PM   #544
yellow_snocone
Ya it was a guessing game with all that shielding gas in my face
Military Jeepers
S.W. New Mexico region
[URL="http://www.jeepforum.com/forum/f22/chesters-tj-build-1420405/"][COLOR="Green"]Chester TJ build[/COLOR][/URL]
[URL="http://www.jeepforum.com/forum/f330/rubicon-trail-august-9th-11th-2014-a-1550022/"][COLOR="Blue"]2014 JF RUBICON TRIP[/COLOR][/URL]
yellow_snocone is offline   Reply With Quote Quick reply to this message
Unread 08-26-2013, 10:58 PM   #545
gspup
Hahah
Unread 08-26-2013, 11:44 PM   #546
gst95dsm
Chop, Wheel and Rebuild..
gst95dsm's Avatar
They already said it... but X4. Once you get the gas flowing that flux is torture. Haha.
My Build Thread
gst95dsm is offline   Reply With Quote Quick reply to this message
Unread 08-27-2013, 12:29 PM   #547
yellow_snocone
I finished up the flux last night and have a new spool of .30 waiting to get ran thru so tonight I'll burn some gas
Military Jeepers
Unread 08-27-2013, 05:31 PM   #548
jermeyg
THis is going to be awesome! Nate's transformation was fun to follow I am sure yours will be too!
jermeyg is offline   Reply With Quote Quick reply to this message
Unread 08-27-2013, 06:59 PM   #549
yellow_snocone
Now we're cooking with spice . I ran a few lines tiring both slow and slower and slightly faster then slow. I also welded a piece to my larger piece. So fellows whatcha think?
Military Jeepers
Unread 08-27-2013, 07:03 PM   #550
brplatz
Definitely better, I am by far an amateur welder, but I would say slow down, the fillet weld should sit more flush with the plates.
Kinda shows, but you can google a better pic.
Unread 08-27-2013, 07:40 PM   #551
gst95dsm
gst95dsm's Avatar
Mess around with the settings, crank it way up so you can see what it's like, and turn it way down. How thick is your practice material? What I found that practice was cool to learn how to see the puddle and to play with the settings but just when you're able to run a nice looking bead on the bench with it sitting in front of you and you're confident...... you get under the jeep, out of position, or vertical..... and it's like you completely suck again. I would definitely practice some vertical, most of the welding you'll be doing is either vertical or over head.
My Build Thread
Unread 08-27-2013, 07:42 PM   #552
yellow_snocone
I've been playing with 3/16 but I'll try all that and see what I get out of it.
Military Jeepers
Unread 08-27-2013, 09:00 PM   #553
jermeyg
looks like your heat is set to low. You want the puddle to sink into the material. What I would do is first set to a medium voltage then play with only the wirespeed. Just shoot it against the material and listen to the sound while moving the feed speed. Once it has that sizzling sound, then adjust your voltage to get the puddle to sink into the metal while looking. Then you can either move faster or slower to adjust your build up.
Unread 08-27-2013, 09:42 PM   #554
yellow_snocone
I feel like an idiot I forgot to change the polarity from when I was welding with flux. Explains why my welds werent really sinking in.
Military Jeepers
Unread 08-28-2013, 05:16 AM   #555
TheDoc25
It should have a nice cracking sound as you weld, you don't want it to sink in the metal to a point you have what is called "undercut" this creates a weak spot that you can bet your arse it will crack.
On the other hand it should not look like a piece of rope laying against each surface, but once you have it you will know. Weave the nozzle and watch the puddle, slight clockwise roll of the wrist will help get that weld looking like a roll of dimes.
TheDoc25 is offline   Reply With Quote Quick reply to this message
black tj , military jeep , work in progress
