Chester's TJ build - Page 3 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Chester's TJ build
BDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!FREE, FREE, FREE EVENT!! Save big on Lockers now till Apri
Unread 10-08-2012, 08:38 PM   #31
G Beasley
Originally Posted by yellow_snocone View Post
Another fine day at work
What is it ?
G Beasley is offline   Reply With Quote Quick reply to this message
Unread 10-08-2012, 08:45 PM   #32
TJRHD
Slick jeep.. I really like the wheels and tars......
NOT A HATER
TJRHD is offline   Reply With Quote Quick reply to this message
Unread 10-08-2012, 08:54 PM   #33
yellow_snocone
Its a 100K Hyster container handler building a 100K Hyster container handler
Military Jeepers
S.W. New Mexico region
[URL="http://www.jeepforum.com/forum/f22/chesters-tj-build-1420405/"][COLOR="Green"]Chester TJ build[/COLOR][/URL]
[URL="http://www.jeepforum.com/forum/f330/rubicon-trail-august-9th-11th-2014-a-1550022/"][COLOR="Blue"]2014 JF RUBICON TRIP[/COLOR][/URL]
yellow_snocone is offline   Reply With Quote Quick reply to this message
Unread 10-08-2012, 08:56 PM   #34
yellow_snocone
Thanks man the tars are huge
Military Jeepers
Unread 10-10-2012, 09:07 PM   #35
yellow_snocone
Well it seems like I might not be done before the 20th.
I took the jeep out for a drive yesterday to test out my scraping sound solution which worked only to end up finding out I have DW now. I cant figure out how that happened since I didnt do anything to my front end.
Time to run through everything in hopes to fixing it before the 20th
Military Jeepers
Unread 10-11-2012, 06:07 AM   #36
G Beasley
Death wobble is not fun to chase down . Did you check the usual culprits , ie; trac bar and tres ? Mine was a bad balance and the trac bar .
Unread 10-11-2012, 07:03 AM   #37
yellow_snocone
Ya I'm going to check everything out tonight after work. I'm thinking my track bar might be the culprit.
Military Jeepers
Unread 10-12-2012, 12:46 AM   #38
yellow_snocone
Got the DW fixed the track bar bolt on the axle end opened the hole up. I simply drilled a slightly bigger hole and out in a beefy bolt.
Military Jeepers
Unread 10-15-2012, 09:13 AM   #39
yellow_snocone
It will seem my DW is still alive and well. Its back to the cutting board. I'm going to get a 4 wheel alignment and see if my rear is matching up as well as it should be.
Military Jeepers
Unread 10-16-2012, 07:48 AM   #40
yellow_snocone
Got the DW down to a slight shimmy at 45mph which I can deal with so I'm calling it good for a bit. After work I'm going to adjust the rear and move it forward a hair, its kind of touching my gas skid at full bump.
Military Jeepers
Unread 10-16-2012, 01:50 PM   #41
--chris--
Excellent choice on the parts/build so far. Looks great.
--chris-- is offline   Reply With Quote Quick reply to this message
Unread 10-16-2012, 01:54 PM   #42
yellow_snocone
Thanks man, I did alot of research and hope I can keep it up
Military Jeepers
Unread 10-19-2012, 07:09 PM   #43
yellow_snocone
So I tested out the suspension to make sure things were good.
bumbstops are set perfectly
Military Jeepers
Unread 10-20-2012, 06:16 PM   #44
yellow_snocone
The jeep performed great today on the trail.
Here are some pictures. More to come.
Military Jeepers
Unread 10-20-2012, 06:19 PM   #45
gspup
Nice pics I'll be doing some night wheeling this evening !
gspup is offline   Reply With Quote Quick reply to this message
black tj , military jeep , work in progress
