Chester's TJ build - Page 28 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Chester's TJ build
WIN a Rough Country Forged Track Bar - ExtremeTerrain!1987-2016 Wrangler Jammock Black 2.0 Jeep Hammock (YJ, TJ Rancho rockGEAR promotion gear from January 1-February 29,
Unread 07-07-2013, 03:20 PM   #406
yellow_snocone
Top is the 7" stretched. Bottom is stock setup.
Military Jeepers
S.W. New Mexico region
[URL="http://www.jeepforum.com/forum/f22/chesters-tj-build-1420405/"][COLOR="Green"]Chester TJ build[/COLOR][/URL]
[URL="http://www.jeepforum.com/forum/f330/rubicon-trail-august-9th-11th-2014-a-1550022/"][COLOR="Blue"]2014 JF RUBICON TRIP[/COLOR][/URL]
yellow_snocone is offline   Reply With Quote Quick reply to this message
Unread 07-07-2013, 03:29 PM   #407
brplatz
Interesting, I won't get nearly 7" maybe 4-5" but still have to think about it
The Second Amendment is in place in case they ignore the others.
[QUOTE=mrblaine;14089403]That's like saying you wish your boyfriend was a bit less gay.[/QUOTE]
[COLOR="Blue"]MOΛΩN ΛΑΒΕ[/COLOR]
[URL="http://www.nmoffroad.com"][COLOR="DarkRed"]NMOffroad[/COLOR][/URL]
[URL="http://www.overland-motorsports.com/"][COLOR="Gray"]Overland Motorsports[/COLOR][/URL]
[COLOR="DarkSlateBlue"][URL="http://www.jeepforum.com/forum/f22/brplatzs-tj-opv-1240947/#post13888971"]My Build[/URL][/COLOR]
brplatz is offline   Reply With Quote Quick reply to this message
Unread 07-07-2013, 03:33 PM   #408
yellow_snocone
I should be able to pull 7" but to be on the safe side I'm going with 6" since my 8.8 is not a forever deal. Plus I'm using a genright 15G comp tank
Military Jeepers
Unread 07-07-2013, 03:36 PM   #409
gst95dsm
Chop, Wheel and Rebuild..
gst95dsm's Avatar
I'm going to use the genright bezel on the side..... easy solution.
My Build Thread
gst95dsm is offline   Reply With Quote Quick reply to this message
Unread 07-07-2013, 04:05 PM   #410
brplatz
Link? I can't find it
Unread 07-07-2013, 04:18 PM   #411
yellow_snocone
I never knew they had one.
Are you referring to this Nate?
http://www.genright.com/ProductInfo....0#.UdncBW10lXE
Military Jeepers
Unread 07-07-2013, 04:31 PM   #412
gst95dsm
gst95dsm's Avatar
No, you can buy just the plastic bezel they sell in their stretch kits. I'm posting from my phone so I can't provide a link, but I have seen just the bezel listed at several retailers.
My Build Thread
Unread 07-07-2013, 04:37 PM   #413
yellow_snocone
Ok I'll look into it
Military Jeepers
Unread 07-07-2013, 04:38 PM   #414
aw12345
Yup now that you mention it Genright does sell it separate. It's what my bud used when he first stretched his
aw12345 is offline   Reply With Quote Quick reply to this message
Unread 07-07-2013, 04:42 PM   #415
yellow_snocone
Found it
GenRight GFB-2000 Gas Filler Bezel for Stretched Jeep TJ/LJ
http://www.dirtpartsdepot.com/servle...n-Right/Detail
Military Jeepers
Unread 07-07-2013, 04:52 PM   #416
AngryTJ
Found it
Yup that's what came with my genright tank
[SIZE="5"][COLOR="Blue"]Follow me on Instagram @ Tarantula_TJ[/COLOR][/SIZE]
[URL="http://www.jeepforum.com/forum/f22/angrytjs-97tj-05-rubicon-build-1271051//"][SIZE="4"][B]
Tarantula_TJ Build[/B][/SIZE][/URL]
AngryTJ is offline   Reply With Quote Quick reply to this message
Unread 07-07-2013, 04:57 PM   #417
brplatz
That's interesting, I would probably have to make my own custom mounting holes in the corner guards
Unread 07-07-2013, 05:49 PM   #418
AngryTJ
Correction it came with my stretched genright corners with the hole pre cut
Unread 07-07-2013, 08:01 PM   #419
gst95dsm
gst95dsm's Avatar
Yeah that's it, my plan is to make the stretch cut into my existing Metalcloak corner guards, then graft onto the front portion the correct filler piece. I figure a little welding, body filler and grinding and sanding I'll have some stretched corner guards without spending much, and I won't have to drill any new holes in my tub. Lot's more work though than just buying another set. Oh well.
My Build Thread
Unread 07-07-2013, 09:42 PM   #420
yellow_snocone
Heck of alot more work. Why not sell and get new corners?
Military Jeepers
black tj , military jeep , work in progress
