Chester's TJ build - Page 23 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Chester's TJ build
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRuffstuff Axle Simple Swap Kit!Nitro Gear Packages Now Available at Rockridge 4wd
Unread 06-09-2013, 12:48 AM   #331
yellow_snocone
Not sure greg, it might be while until I fully enjoy wheeling the trails in my area after being spoiled in moab lol.
Military Jeepers
S.W. New Mexico region
[URL="http://www.jeepforum.com/forum/f22/chesters-tj-build-1420405/"][COLOR="Green"]Chester TJ build[/COLOR][/URL]
[URL="http://www.jeepforum.com/forum/f330/rubicon-trail-august-9th-11th-2014-a-1550022/"][COLOR="Blue"]2014 JF RUBICON TRIP[/COLOR][/URL]
yellow_snocone is offline   Reply With Quote Quick reply to this message
Unread 06-09-2013, 12:51 AM   #332
G Beasley
Jeep-Owner.com
G Beasley's Avatar
Any trail is a good trail
Did I tell you about the three hour trail called Gilligans ?
G Beasley is offline   Reply With Quote Quick reply to this message
Unread 06-09-2013, 12:53 AM   #333
yellow_snocone
You have a point. And I don't believe you mentioned it
Military Jeepers
Unread 06-09-2013, 05:35 AM   #334
gst95dsm
Chop, Wheel and Rebuild..
gst95dsm's Avatar
My Build Thread
gst95dsm is offline   Reply With Quote Quick reply to this message
Unread 06-09-2013, 12:59 PM   #335
yellow_snocone
Great video Nate I love the music choice for everyone, you got me perfectly
Military Jeepers
Unread 06-09-2013, 01:20 PM   #336
gst95dsm
gst95dsm's Avatar
Glad you liked it Kyle!
My Build Thread
Unread 06-09-2013, 04:04 PM   #337
aw12345
Was good hanging out Kyle, maybe some AZ trails this fall? Will keep you posted
aw12345 is offline   Reply With Quote Quick reply to this message
Unread 06-09-2013, 04:16 PM   #338
yellow_snocone
I had a great time as well art. Keep me up to date for sure.
Military Jeepers
Unread 06-16-2013, 10:39 PM   #339
yellow_snocone
I have a bit of a leak coming from my water pump. I'm going to check to see if its my seal or if the water pump is bad. I havent had any cooling issues beyond the leak so I'm thinking the water pump is fine. The jeep is going to have to wait though I just started on my bathroom remodel and discovered termite tracks. They seem old and in-active but I'll have an inspector check them out first.
Military Jeepers
Unread 06-16-2013, 11:59 PM   #340
G Beasley
Jeep-Owner.com
G Beasley's Avatar
Look underneath the Jeep and see if the drip is coming from the weephole , if so you need a waterpump .
As to the termites be prepared to cut out three times more wood than you thought you would have to . Hopefully you got lucky and they have been treated previously , and all you have to do is a little repair .
Unread 06-17-2013, 12:18 AM   #341
yellow_snocone
I'll give it a check then. So far its only a few studs and some supporting beams. The good news is its only in the bathroom part of the wall. I've check other connecting walls and their clear.
Military Jeepers
Unread 06-19-2013, 08:59 PM   #342
yellow_snocone
To funny lots of great products
http://kalecoauto.com/index.php?main...l9at7sf8olfc10
Military Jeepers
Unread 06-23-2013, 10:48 PM   #343
yellow_snocone
Ordered a new OEM water pump and thermostat and should get them in this week. Sadly after that replacement the jeep will go untouched until the house is done. I just dropped a good 2 grand on supplies and tile. So sad I could've used that for the rear stretch
Military Jeepers
Unread 06-28-2013, 04:40 PM   #344
G Beasley
Jeep-Owner.com
G Beasley's Avatar
Did you get the house back under control yet ?
Unread 06-28-2013, 09:30 PM   #345
yellow_snocone
Ya I got the new studs in over the week. I'll be helping a friend replace his transmission this weekend after that its back to the house. I'll see about taking a before and after picture with the wall
Military Jeepers
black tj , military jeep , work in progress
