Chester's TJ build - Page 22 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Chester's TJ build
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineThe Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!
Unread 05-11-2013, 10:05 PM   #316
G Beasley
Other than an alignment your ready to go now arent you ?
G Beasley is offline   Reply With Quote Quick reply to this message
Unread 05-12-2013, 02:46 AM   #317
yellow_snocone
As far as I can think an alignment and a steering box skid are whats left. I did run into some DW through after the tie rod install that I didnt have after my dry run for the new Trackbar. Hopefully its just out of alignment, I'd hate to go through the check list again being so close to Moab.
Military Jeepers
S.W. New Mexico region
[URL="http://www.jeepforum.com/forum/f22/chesters-tj-build-1420405/"][COLOR="Green"]Chester TJ build[/COLOR][/URL]
[URL="http://www.jeepforum.com/forum/f330/rubicon-trail-august-9th-11th-2014-a-1550022/"][COLOR="Blue"]2014 JF RUBICON TRIP[/COLOR][/URL]
yellow_snocone is offline   Reply With Quote Quick reply to this message
Unread 05-12-2013, 05:11 PM   #318
yellow_snocone
Got everything aligned. I remeasured my axle just to make sure it was centered and it seemed off a bit so I made a slight adjustment but ended up having to take off the jam nut since I couldn't get the rod end to match the hole with it on. If anyone could chime in on if a jam nut will be needed. I might just get one with a smaller width to use.
I used some paracord to make sure my measurements were level and at the same points on the tire rear and front. I ended up having 67 1/16 to the middle lug and 67 in the front. Adjusted the drag link after that and everything is good to go.
Military Jeepers
Unread 05-12-2013, 06:39 PM   #319
gst95dsm
Chop, Wheel and Rebuild..
gst95dsm's Avatar
Jam nut mandatory. The bit of space between the male and female threads will eventually wear until you have a loose fit. The Jam nut prevents that.
My Build Thread
gst95dsm is offline   Reply With Quote Quick reply to this message
Unread 05-12-2013, 07:10 PM   #320
yellow_snocone
Off to ace for a smaller width Jam nut.....or I can grind some off the one I have its only a hair off.
Military Jeepers
Unread 06-01-2013, 04:27 PM   #321
yellow_snocone
Made it safely to moab, but ran into some serious dw right when we came in . The jeep ran smoothly the while trip but sure what bump I hit to cause it but its here to stay until I fix it. I did all the dry steering checks and check both tires while having them lifted. The only thing I haven't replaced from the last time I fixed this issue were my control arms. I tried shaking them to check for loosness but their on there nice and tight.
Military Jeepers
Unread 06-02-2013, 10:45 PM   #322
yellow_snocone
I got the DW fixed it was from my tires wearing wrong from having alittle to much toe in when I needed some toe out instead. I swooped the rears with the worn fronts and reset the toe and I'm good to go.
Military Jeepers
Unread 06-03-2013, 12:23 AM   #323
G Beasley
Unread 06-03-2013, 12:35 PM   #324
gspup
^ Fenders are looking good !
gspup is offline   Reply With Quote Quick reply to this message
Unread 06-03-2013, 09:08 PM   #325
yellow_snocone
Thanks mike soon you get to see them in person, it will be a heart filled reunion lol
Military Jeepers
Unread 06-03-2013, 11:23 PM   #326
G Beasley
I'm too sexy for my Jeep is the theme music for this series of pictures . I had no idea my wife took these and I laughed like heck when I saw them , thanks for being a good sport and putting up with the picture hound !
Unread 06-04-2013, 12:57 AM   #327
yellow_snocone
Always a good time we you get to be to sexy lol
Military Jeepers
Unread 06-06-2013, 08:49 PM   #328
yellow_snocone
Almost home I had a amazing time at moab with the jeep forum build crew. We need to do this again, it was a blast and I have a few trails I need to get knock off the list lol. I'll be sure to put the pictures I have when I get home tonight.
Military Jeepers
Unread 06-08-2013, 01:24 AM   #329
yellow_snocone
Some pictures from our trip
Military Jeepers
Unread 06-09-2013, 12:45 AM   #330
G Beasley
It was a good time , wheres the next wheeling get together ?
black tj , military jeep , work in progress
