Chester's TJ build - Page 2 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Chester's TJ build
Forever Wave Flags at JeepHutRubicon Express lift kits w/shocks are on sale!ORS4x4: New Product!
Unread 09-26-2012, 10:24 PM   #16
gspup
Checking in. Looking to do some wheeling your way next spring.
gspup is offline   Reply With Quote Quick reply to this message
Unread 09-26-2012, 10:40 PM   #17
yellow_snocone
By all means come on down. I've been reading your thread great build so far. I would love to come up and wheel in CO sometime too the trails look great.
Military Jeepers
S.W. New Mexico region
[URL="http://www.jeepforum.com/forum/f22/chesters-tj-build-1420405/"][COLOR="Green"]Chester TJ build[/COLOR][/URL]
[URL="http://www.jeepforum.com/forum/f330/rubicon-trail-august-9th-11th-2014-a-1550022/"][COLOR="Blue"]2014 JF RUBICON TRIP[/COLOR][/URL]
yellow_snocone is offline   Reply With Quote Quick reply to this message
Unread 09-28-2012, 09:27 PM   #18
yellow_snocone
Finally got all the mount holes drilled to the right bolt size.
I had to shave a bolt head to allow it to fit pass the shock mount
Axle goes in tomorrow
Military Jeepers
Unread 09-29-2012, 02:39 PM   #19
yellow_snocone
I got the axle in but ran into an issue with one of my upper control arms so I'll wait on cycling the suspension
I couldn't take the center ring out to regrease the bearing
Called RC and got a replacement jonny joint. Thankfully these arms are only temporary I have all new custom JJ arms for my 4 link
I'm going to have to figure out a way to use the stock e-brake cables I have on the 8.8 if not I'll get the kit from ECGS
Military Jeepers
Unread 10-05-2012, 08:58 PM   #20
yellow_snocone
Finally got the rest of my parts in the mail
Brown Dog MML
My new upper CA JJ
I had a hick up with my u-joint with my new flange
Got a new one and was good to go
DV in with CA's adjusted
Finished alot today. Tomorrow I'm going to install the MML/BL with my new skid
Military Jeepers
Unread 10-06-2012, 07:19 PM   #21
yellow_snocone
Got the BL and MML lift in
Not much trouble from the install besides having to file down a few mounts to fit the BL. The motor mounts went in without any issues at all, tough working on the driver side with all lines being there. I didnt get a chance to take any pictures from the install.
Back on all fours. I just need to adjust my shock mounts. A quick grind of and reweld should cover it.
Military Jeepers
Unread 10-06-2012, 07:23 PM   #22
yellow_snocone
I need to finish the jeep before Thursday since the Girlfriend will be in town and I cant work when shes here but I need it done before the 20th for Carnage Canyon.
To Do List
flush brakes
install New UCF skid
Adjust rear pinion angle
Fix Shock mounts on axle
Military Jeepers
Unread 10-06-2012, 10:28 PM   #23
gspup
To Do List
flush brakes
Carnage in CO ?
Unread 10-06-2012, 10:40 PM   #24
yellow_snocone
No in southern New mexico. Its just outside of Oro Grande,NM
Great trail lots of shelves to climb
Military Jeepers
Unread 10-07-2012, 05:08 PM   #25
yellow_snocone
painted the UCF skid
Before
After
Military Jeepers
Unread 10-07-2012, 06:21 PM   #26
G Beasley
Very nice ! The extra clearance is going to let you get even further into trouble
G Beasley is offline   Reply With Quote Quick reply to this message
Unread 10-07-2012, 06:28 PM   #27
yellow_snocone
Driveway shoot
Military Jeepers
Unread 10-07-2012, 06:29 PM   #28
yellow_snocone
Tell me about it
When I went up in tire size I started doing the risker stuff too
Military Jeepers
Unread 10-08-2012, 02:14 PM   #29
yellow_snocone
Today I got the shock mounts fixed and got my ebrake cable setup up.
Only thing left is my pinion angle and now have a noise coming from my rear. Sounds like something is scraping my brake pads. It increases with speed so that might be the problem area.
Military Jeepers
Unread 10-08-2012, 07:00 PM   #30
yellow_snocone
Another fine day at work
Military Jeepers
black tj , military jeep , work in progress
