Chester's TJ build - Page 15 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Chester's TJ build
Ruffstuff 10 year saleBDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!
Unread 02-02-2013, 03:58 PM   #211
yellow_snocone
4.88' s
Military Jeepers
S.W. New Mexico region
[URL="http://www.jeepforum.com/forum/f22/chesters-tj-build-1420405/"][COLOR="Green"]Chester TJ build[/COLOR][/URL]
[URL="http://www.jeepforum.com/forum/f330/rubicon-trail-august-9th-11th-2014-a-1550022/"][COLOR="Blue"]2014 JF RUBICON TRIP[/COLOR][/URL]
yellow_snocone is offline   Reply With Quote Quick reply to this message
Unread 02-02-2013, 04:24 PM   #212
NYGLT56
Your Local Body Builder
Originally Posted by yellow_snocone
4.88' s
Good choice haha
Instagramin --> @thatonebeardedbro
2014 TJOTY Winner
NYGLT56 is offline   Reply With Quote Quick reply to this message
Unread 02-02-2013, 04:55 PM   #213
yellow_snocone
Ya I might as well jump right to the proper gear instead of messing with 4.56' s
Military Jeepers
Unread 02-10-2013, 09:18 PM   #214
yellow_snocone
So the regear has began but is far from done. We started with the front knowing it would be the most difficult. Everything got setup up without much trouble minus some issues with the crush sleeve. After some testing and refitting of the pinion shaft we got the right depth and had the front locked in. Now on to the rear which first started off with what we thought was to much pinion depth because we could not move the ring gear if we tried. So we adjusted the pinion shim to .00 form .30 to have a good starting point. The second try gave us great results but the pinion need to come in more so we moved up to .10 on the shim. On the third try we had a great wear pattern but ran into another issue. The ring gear binds at a certain spot. It may be that the ring gear is warped or the carrier . I'm going to repress the bearings on the carrier and maybe drop down the shim on the pinion to .08. I'm hoping the ring and carrier are fine but we'll see.
We had the pinion in to much.
Pretty good wear pattern
The 8.8
Military Jeepers
Unread 02-10-2013, 09:29 PM   #215
NYGLT56
The 8.8
Impressive. I would never touch gearing lol
2014 TJOTY Winner
Unread 02-10-2013, 09:34 PM   #216
yellow_snocone
Neither would I without the help of my friend who is pretty good with gears. I'm learning alot so I can help the next person with their install if their feeling up to it
Military Jeepers
Unread 02-10-2013, 09:44 PM   #217
NYGLT56
Ah that makes sense haha. I would never go at it alone lol
2014 TJOTY Winner
Unread 02-10-2013, 10:03 PM   #218
yellow_snocone
After learning what I have its not that hard to be quite honest. I wouldn't recommend doing it the first time on your own, especially without the proper tools.
Military Jeepers
Unread 02-10-2013, 10:16 PM   #219
NYGLT56
Good to know. What's next??
2014 TJOTY Winner
Unread 02-10-2013, 10:29 PM   #220
yellow_snocone
outboarding frt and rear shocks with my rear spring perch.
Military Jeepers
Unread 02-16-2013, 12:21 PM   #221
G Beasley
Its the weekend wheres the pictures ?
G Beasley is offline   Reply With Quote Quick reply to this message
Unread 02-16-2013, 01:58 PM   #222
yellow_snocone
Well thats not happening until the regear is done. Tomorrow I'm going to try to finish the rear. Today I'm buying a welder, its a hobart 187.
Military Jeepers
Unread 02-16-2013, 02:11 PM   #223
G Beasley
Thats a nice welder , should serve you well . Whats left to finish the rear ?
Unread 02-16-2013, 03:56 PM   #224
yellow_snocone
The ring gear is binding at a certain spot we're trying to figure out why, so I'm going to check my backlash and make sure the ring gear isn't warped. So tomorrow will involve so adjusting and hopefully the rear gearing should be done.
Military Jeepers
Unread 02-17-2013, 07:29 PM   #225
yellow_snocone
ROUND TWO
We swapped the the ring gear 180 on the carrier and adjusted the shims on the carrier and success
Military Jeepers
black tj , military jeep , work in progress
