Chester's TJ build - Page 54 - JeepForum.com
post #796 of 925 Old 12-22-2013, 06:52 PM
Hendrix
TJOTY 2013
Hendrix's Avatar
Originally Posted by AngryTJ
why not just shorten the upper arms so the brackets sit on the truss just fine?
Yes, this is the best option.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #797 of 925 Old 12-22-2013, 07:11 PM Thread Starter
yellow_snocone
The over hang isn't that bad I'll post a picture showing the other side. It's 1 1/8 at the one corner hanging over.
Military Jeepers
S.W. New Mexico region
yellow_snocone is offline
post #798 of 925 Old 12-22-2013, 09:25 PM Thread Starter
yellow_snocone
Driver side tacked up
Uppers are looking good
Not a bad as it looked
Military Jeepers
post #799 of 925 Old 12-22-2013, 09:50 PM
gst95dsm
Chop, Wheel and Rebuild..
gst95dsm's Avatar
Oh yeah dude that's just fine. It's gonna be hard for me not to redo my rear links when I finish up the axle. I figure if I already have all the joints bought by then, that's the major cost out of the way so why not. Looking forward to it. Looking good though man. Just triple check every possible source of interference before you burn.
gst95dsm is offline
post #800 of 925 Old 12-22-2013, 10:00 PM Thread Starter
yellow_snocone
Definitely I dont want any issues. I think its the right thing to do to for the axle swap, best time to do it.
Military Jeepers
post #801 of 925 Old 12-23-2013, 06:13 PM Thread Starter
yellow_snocone
Ok guys I made some adjustments to the uppers some where down the line I did something wrong and couldnt put the other control arm back in so cut off the brackets and redid the uppers together to make sure things were good.
I checked all my clearances and it seems the upper hit the tube right at the bumpstops, so a hard hit is going to do some damage. The lowers have some more room left until they hit the frame.
Military Jeepers
post #802 of 925 Old 12-23-2013, 09:49 PM
aw12345
Pretty common for the upper links to hit the tub. It either self clearances or you do some sheetmetal surgery
aw12345 is offline
post #803 of 925 Old 12-23-2013, 09:51 PM Thread Starter
yellow_snocone
What's the amount of worrying I should have for self clearance lol. I'm feeling to lazy to work the sheetmetal.
Military Jeepers
post #804 of 925 Old 12-23-2013, 10:02 PM
gst95dsm
gst95dsm's Avatar
Looks like you could easily shave 1/8" off the top of the link mounts…. and then just let it self clearance. If they hit well before the jounce you need to add bumpstop. But if you can take the jounce out and only have about a 1/2" interference or so I'd let it self clearance if it wants to. Getting to FULL compression in the rear might happen in some whoops, but it's not going to constantly be hitting during daily driving or rock crawling.
gst95dsm is offline
post #805 of 925 Old 12-23-2013, 10:11 PM Thread Starter
yellow_snocone
That's a good point Nate. I think it will be fine. I still have almost an inch and a half until the uppers in the axle contact to crossmember
Military Jeepers
post #806 of 925 Old 12-23-2013, 10:11 PM
aw12345
Nate looks like his upper links will hit the floor first right behind the frame mounts. With the longer arms its almost impossible for that not to happen when you use enough link seperation
aw12345 is offline
post #807 of 925 Old 12-23-2013, 10:14 PM
gst95dsm
gst95dsm's Avatar
I'd worry about that even less! haha. That'll just make a nice round link shaped indentation.
gst95dsm is offline
post #808 of 925 Old 12-23-2013, 10:17 PM Thread Starter
yellow_snocone
Then I guess no worries are too be had. I don't mind a little self clearance just as long nothing major occurs I'll be burning everything in tomorrow
Military Jeepers
post #809 of 925 Old 12-24-2013, 04:53 PM Thread Starter
yellow_snocone
I started working on the tank placement. I had to cut some of the tub support to get the fuel pump to clear. I'm going to have to make some brackets for the front mounts since they dont reach the frame. All and all I like where it is and I have some more room from the axle. I may continue work on the rear mount member that tie the tank to the bumper tonight.
Fill tube opening just barely clears
Nice and level
Military Jeepers
post #810 of 925 Old 12-25-2013, 09:22 PM Thread Starter
yellow_snocone
Merry Christmas everyone and Happy New year.
Got some work done today all brackets frame/axle all welded up
Got the rear fuel tank mount welded and drilled as well as the front mounts
Good old cardboard template
Military Jeepers
black tj , military jeep , work in progress
Daddy's power wheel TJ build (Slow build) Ratm Jeep Builds 15 02-04-2014 09:59 PM
JeepWJ26 Build--Johnny Cash Build JeepWJ26 Jeep Builds 31 01-09-2012 11:15 AM
