Chester's TJ build - Page 49 - JeepForum.com
post #721 of 925 Old 12-12-2013, 07:18 PM Thread Starter
yellow_snocone
Thanks John
Military Jeepers
S.W. New Mexico region
yellow_snocone is offline
post #722 of 925 Old 12-12-2013, 08:56 PM
kyle_craig
Nice job so far. If I were to stretch again, I'd consider extending the frame like you're doing. I think its a very neat, clean way to do it. I'm really looking forward to seeing how yours turns out.
kyle_craig is offline
post #723 of 925 Old 12-12-2013, 09:12 PM Thread Starter
yellow_snocone
I got the idea from Nate so I can't take credit but I like how easy it went through
Military Jeepers
post #724 of 925 Old 12-14-2013, 06:01 PM Thread Starter
yellow_snocone
Finally making some good progress
I cut off the upper spring perchs while I had the frame out
After some grinding they fit like a glove
Got the frame together..man that was a pain by myself but I got creative with some jack stands
Got it all welded up
...But I forgot to add plug holes for the sides to get welded. I may use my 1/2 in hole saw and go slow
Tomorrow I'll get the perchs back on and the axle in to start the 4 link prep
Military Jeepers
post #725 of 925 Old 12-14-2013, 06:07 PM
AngryTJ
Good stuff Kyle
I never really considered doing my stretch this way. I think I was a little apprehensive because I didnt know how a genright tank would mount after chopping the rear section off.
Glad your making progress!
AngryTJ is offline
post #726 of 925 Old 12-14-2013, 06:10 PM Thread Starter
yellow_snocone
Thank Lou . I'm still trying to plan on how I'll do that but it shouldnt be hard. I might use the stock rear member or add some angle iron to my new bumper for the 4 mounting points in the rear of the tank.
Military Jeepers
post #727 of 925 Old 12-14-2013, 06:15 PM
gst95dsm
Chop, Wheel and Rebuild..
gst95dsm's Avatar
Kyle that looks great man. The welding looks damn good. The plug welds are important IMO so I'm hoping you can get those in somehow. Also I was hoping you'd do your shock towers with the rear frame out. It would be much easier. Oh well. Did you cut out the crossmember? Whewww… you did a lot today!
gst95dsm is offline
post #728 of 925 Old 12-14-2013, 06:20 PM Thread Starter
yellow_snocone
Thanks Nate
I thought about doing all that with the frame out but wasn't feeling confident that it would match up right so I'll do it after the 4 link. I left the crossmember in for now just to keep things square. I'll cut it out tomorrow before I do the perchs and then I'll weld in a new on for the body mounts. I just might reuse it for the sake of keeping the work load down.
Military Jeepers
post #729 of 925 Old 12-14-2013, 06:28 PM
gst95dsm
gst95dsm's Avatar
Originally Posted by yellow_snocone View Post
Thanks Nate
Sounds good Kyle, just so you know though, that crossmember is double walled and a mother f-er to cut out. It's a VERY substantial crossmember so Jeep must have done that for a reason. I know a part of the reason is that the shocks mounts to it but I figured it was fairly crucial to keeping the frame from twisting. Anyways…. you need some kind of crossmember there, and if it's any less stout than that factory one, I would supplement that with a stronger crossmember at the very rear, like what I did, or similar.
gst95dsm is offline
post #730 of 925 Old 12-14-2013, 06:34 PM Thread Starter
yellow_snocone
Oh yay its going to be a fine sunday then
Military Jeepers
post #731 of 925 Old 12-14-2013, 08:54 PM
gspup
If you trust your welds I wouldn't bother with drilling to plug weld. A beefy rear crossmember by bumper should do the trick just fine.
gspup is offline
post #732 of 925 Old 12-14-2013, 08:57 PM Thread Starter
yellow_snocone
The welds have some good penetration but just for added peace of mind I'll put some plug welds in since I'll be grinding the welds down for appearances
Military Jeepers
post #733 of 925 Old 12-14-2013, 10:19 PM
aw12345
Nice progress Kyle, I think it was a smart move to not weld in the shock towers yet since you do not know where the axle will end up yet or how up and down travel works out with the relocated spring buckets. Same goes for that crossmember On my Jeep I simply cut a chunk out of it to get needed clearance and added a second crossmember. I prefer to get things done with the least amount of work
aw12345 is offline
post #734 of 925 Old 12-14-2013, 10:23 PM Thread Starter
yellow_snocone
Thanks Art, I agree the best outcome with the least amount of work needed is always a plus
Military Jeepers
post #735 of 925 Old 12-14-2013, 10:26 PM
gst95dsm
gst95dsm's Avatar
Yeah now that I think about it, it was probably smart not to cut in the shock tower. Maybe if you had measured it out before dissasembly. I was just thinking about how easy the cutting and welding would be out of the rig. haha.
gst95dsm is offline
black tj , military jeep , work in progress
Daddy's power wheel TJ build (Slow build) Ratm Jeep Builds 15 02-04-2014 09:59 PM
JeepWJ26 Build--Johnny Cash Build JeepWJ26 Jeep Builds 31 01-09-2012 11:15 AM
