Chester's TJ build - Page 46 - JeepForum.com
post #676 of 925 Old 12-03-2013, 09:55 PM
gst95dsm
Chop, Wheel and Rebuild..
gst95dsm's Avatar
It's not a big deal though man, You did a good job integrating the two, I wouldn't fuss with it.
gst95dsm is offline
post #677 of 925 Old 12-03-2013, 10:11 PM Thread Starter
yellow_snocone
Your probably right Nate I'm sure it's fine
Military Jeepers
S.W. New Mexico region
yellow_snocone is offline
post #678 of 925 Old 12-03-2013, 10:11 PM
JJeeper09
I had A to Z on my last tj. Yes they sit lower but it's due to the bottom of the tub. I think you should extend the rockers and just cut the rocker to fit. Like savvy and other corners do.
JJeeper09 is offline
post #679 of 925 Old 12-03-2013, 10:16 PM
gst95dsm
gst95dsm's Avatar
That's ALOT of work for a small cosmetic issue. We are all hyper critical when were building. When it's all together (and black) no one will care.
gst95dsm is offline
post #680 of 925 Old 12-03-2013, 10:44 PM
JJeeper09
I know. But having an extended rocker may be worth it, with a stretch. But I understand. I'm just saying an extended rocker would look and function better..
post #681 of 925 Old 12-03-2013, 11:11 PM
Imped
Imped's Avatar
That would bug the piss out of me, just my opinion. I'd go with LJ-length sliders and blank corners for a very clean end result.
OlllllllO
IndyORV
Imped is offline
post #682 of 925 Old 12-04-2013, 03:49 AM Thread Starter
yellow_snocone
Honestly it's not too bad but I may modify something to make it flush. If I were to do it all over again I would do the same thing but measure the distance for LJ rockers and have Bryce from MoabFab make the adjustment with the final cut and get some LJ sliders. I'm very happy with my corners and was aware they were going to need some adjusting in this area since I ordered them without pre cuts for the sliders.
Military Jeepers
post #683 of 925 Old 12-04-2013, 10:22 AM
kyle_craig
Originally Posted by yellow_snocone View Post
Another slight update.
Very nice looking cut. As far as the gap goes, I say just run it unless it really bugs you that badly. Adding an inch of 3/16" to the bottom of the corner would be a cheap easy fix if it really bugs you. Otherwise, I don't think it will be that glaring once its all painted and on the Jeep.
kyle_craig is offline
post #684 of 925 Old 12-04-2013, 08:41 PM
aw12345
I agree, just extend the bottom of those corners a bit and nobody would ever know the difference, Or if the slider comes up a bit short get some angle and extend it. Adding some steel isn't a big deal period, just a lil time with the glue gun and it's all better
aw12345 is offline
post #685 of 925 Old 12-06-2013, 10:23 AM Thread Starter
yellow_snocone
Ya that's the idea just add to the corners
Military Jeepers
post #686 of 925 Old 12-07-2013, 06:44 AM
jermeyg
Hey man nice work so far!
jermeyg is offline
post #687 of 925 Old 12-07-2013, 06:50 AM Thread Starter
yellow_snocone
Thanks Jeremy
Military Jeepers
post #688 of 925 Old 12-07-2013, 04:21 PM Thread Starter
yellow_snocone
Little more work and prep. Evap canister deleted
Now to decide where will be the best place to locate it.
EDIT: Heres a good write to look through for the Evap canister
http://www.rubiconownersforum.com/fo...-pictures.html
Military Jeepers
post #689 of 925 Old 12-07-2013, 04:26 PM
Imped
Imped's Avatar
Mine is bolted to the bottom of the tub inside of the frame rail. Hidden, protected and clean.
OlllllllO
IndyORV
Imped is offline
post #690 of 925 Old 12-07-2013, 04:27 PM Thread Starter
yellow_snocone
Thats a good idea. I'm sure I'll have plenty of room there with the new fuel tank.
Military Jeepers
black tj , military jeep , work in progress
Daddy's power wheel TJ build (Slow build) Ratm Jeep Builds 15 02-04-2014 09:59 PM
JeepWJ26 Build--Johnny Cash Build JeepWJ26 Jeep Builds 31 01-09-2012 11:15 AM
