Chester's TJ build - Page 43 - JeepForum.com
post #631 of 925 Old 11-07-2013, 09:09 PM
gst95dsm
Chop, Wheel and Rebuild..
gst95dsm's Avatar
Originally Posted by yellow_snocone View Post
Sounds like a plan. You basically measure 90 degree from your lower arms right?
Yup... at ride height. Just mock up your lower shock mount on the axle. The semi-hard part is determining the height of the tower. You need to think long and hard about your shock and if you are happy with their compressed and extended length. Don't get greedy and think you can have to much in either direction because you'll either be into your tub, or unseating your spring. If you're using a 10' travel shock... I'd go 5 up and 5 down. This makes the cut critical if you're using a tapered shock tower because obviously it's height determines the size of the notch in the frame.
gst95dsm is offline
post #632 of 925 Old 11-07-2013, 09:16 PM Thread Starter
yellow_snocone
Thanks Nate I may need a refreasher on measuring up/down travel shock lengths
Military Jeepers
S.W. New Mexico region
yellow_snocone is offline
post #633 of 925 Old 11-07-2013, 09:21 PM
gst95dsm
gst95dsm's Avatar
No prob, nice thing about our community here is all the experts we have to pull from (I'm NOT including myself in that btw)
gst95dsm is offline
post #634 of 925 Old 11-07-2013, 09:23 PM Thread Starter
yellow_snocone
Everything I know I learned from jeep folk even some of my home improvement skills.
Military Jeepers
post #635 of 925 Old 11-07-2013, 09:26 PM
aw12345
Before you finish weld anything cycle the suspension, full, bump, full droop and full flex both ways at ride height with the rear springs out.
So the towers are angled right for needed shock clearance through the entire suspension travel. Remember Nate has long arms makes the axle move less front to back than short arms.
aw12345 is offline
post #636 of 925 Old 11-07-2013, 09:28 PM Thread Starter
yellow_snocone
Thanks Art, more then likely I will be working on the 4 link as well to make sure everything fits the way it should.
Military Jeepers
post #637 of 925 Old 11-08-2013, 02:22 AM
Imped
Imped's Avatar
I prefer to use full, hard bump as the determinant of the position of the shock mounts. Set the axle as high as it can possibly go and adjust the bump stops to stop it just before the first point of interference--remember, the foam insert will completely compress so leave it out of the equation.
Since the position of the upper and lower shock mounts are floating (you're free to put them wherever you want) the only thing that matters is the distance between them at full bump. Use zip ties to keep the shock compressed 1/2" before completely bottoming out--the eye-eye measurement is the distance you need to set the upper and lower mount bolt holes apart from each other with the axle at full bump. Roughly determine where the lower mount is gonna go (just deal with one side right now) and tack it there....make sure it's easy to remove and only tacked on strong enough to hold the shock. It's likely you'll need to adjust it laterally before you burn it home.
Bolt up the shock and make sure you can fit the tower in the space required at the height it needs to be at. Only cut the frame once you've firmly established that you're happy with the location of the mount, especially if the tower is tapered. When going through the process, work through it slowly and methodically. Common sense goes a long way here....don't overcomplicate it and it'll all go well. If you're considering running longer and/or a different shock in the future, acquire the extended/compressed lengths and use those to setup your mounts instead of your current shocks. I would also consider mounting the towers up as high as possible and just setting the position of the lower mounts to agree with your shock travel and up/down bias....once the tower is burned in, it's in. The lower mounts are much easier to cut off and move/replace in the future if you do end up switching to a different length shock.
Hopefully that all makes sense. My best advice--set everything up at full bump and let ride height be what it will be. Full bump is what matters.
OlllllllO
IndyORV
Imped is offline
post #638 of 925 Old 11-08-2013, 03:31 PM Thread Starter
yellow_snocone
Thanks Connor, I think that's a good way to explain it. I'm sure once I'm under there doing the work it will make even more sense then it does now but I understand what you wrote.
Military Jeepers
post #639 of 925 Old 11-20-2013, 06:24 PM Thread Starter
yellow_snocone
Outboard brackets are in, only thing left are the corners and its chop chop.
Military Jeepers
post #640 of 925 Old 11-24-2013, 10:53 PM
2002TJX65
Nice jeep! very similar to mine!
03 Rubicon: Build in Progress
02 TJ: Built and totaled
86 CJ7: Sold
2002TJX65 is offline
post #641 of 925 Old 11-24-2013, 11:08 PM Thread Starter
yellow_snocone
Thank you. Yours is coming along nicely
Military Jeepers
post #642 of 925 Old 11-24-2013, 11:20 PM
2002TJX65
Slowly but surely. I'm about to install my Clayton 4 link rear, and front long arms and radius arms as well
86 CJ7: Sold
post #643 of 925 Old 11-24-2013, 11:30 PM Thread Starter
yellow_snocone
You certainly got that kit for a steal
Military Jeepers
post #644 of 925 Old 11-24-2013, 11:39 PM
2002TJX65
Suuuuure did! That's the way I roll!
86 CJ7: Sold
post #645 of 925 Old 11-24-2013, 11:56 PM Thread Starter
yellow_snocone
Haha Its always great when you get an awesome deal
Military Jeepers
black tj , military jeep , work in progress
Daddy's power wheel TJ build (Slow build) Ratm Jeep Builds 15 02-04-2014 10:59 PM
Jeep Build: Minty White Country XJ Build GTEIS300 Jeep Builds 34 01-20-2013 11:42 AM
2000 TJ Build - LCG First Time Build japete01 Jeep Builds 82 06-07-2012 10:50 PM
JeepWJ26 Build--Johnny Cash Build JeepWJ26 Jeep Builds 31 01-09-2012 12:15 PM
JeepDVL45's 'Bruiser' Build -- A Daily Driver's slow build JeepDVL45 Jeep Builds 41 08-11-2011 10:44 AM
